Everything posted by imart143
Ash load in DPF
Manufacturer of part, not car, recommends machine cleaning on 150000 miles, resetting ASH volume. you can do it or no. like lifetime oil in gearbox and other ****.
All season options for Kodiaq 4x4
i have these, on 2WD, and will buy them again. Bridgestone Turanza All Season 6 235/45 R20 W (100) XL https://www.blackcircles.com/brands/bridgestone/turanza-all-season-6/235-45-r20-w-100?tyre=46696682 also other sizes available.
Ash load in DPF
There seems to be a huge disconnect between what car manufacturers say about Diesel Particulate Filters (DPFs) and what actual parts makers and service technicians recommend. Car manufacturers often treat the DPF as a component that lasts until it completely clogs up, after which the official recommendation in the dealership is usually an expensive total replacement. However, automotive component manufacturers and repair professionals recommend preventive cleaning of particulate filters, particularly DPFs, between 150,000 and 200,000 miles. The main focus here is the clearance of accumulated residual ash, which cannot be burned off during normal vehicle driving or standard regeneration (since active and passive regeneration only handle soot, not ash). Letting the ash accumulate until total failure puts extreme thermal stress on the ceramic core and raises backpressure, which can heavily strain your turbo and engine. Doing a professional cleaning at higher mileages helps prolong component life and avoids a costly full replacement.
How can i tell what fuel filter i need?
Timing Kit Fitted by Garage, car now stumbles under power at lower revs.
If they were changing the chain at the service, they had to remove the spark plug wires. These wires eventually get burnt, and mechanics often pull them by the wire itself instead of the metal connector, which irreversibly damages the inner core of the wire. Also, the third wire (on the 3rd cylinder) runs close to the turbine and suffers from overheating at the factory and often breaks.
little AI but you will get a point This engine features what is known as a "floating" camshaft sprocket. This means the sprocket does not have a keyway, dowel pin, or slot to lock it into a fixed position on the shaft. As long as the center bolt is loose, the sprocket can rotate freely 360 degrees around the camshaft. The factory procedure for setting the engine to TDC (timing alignment) looks exactly like this: Locking the engine: The crankshaft is set to Top Dead Center (TDC) and locked using a special timing pin screwed into the engine block. The camshaft is locked from the rear end (near the vacuum pump) using a specialized flat alignment plate tool to keep it perfectly horizontal. Installing the chain with loose bolts: The new chain and guides are mounted onto the engine. At this point, the center bolt of the camshaft sprocket must be loose. This allows the sprocket to rotate independently and adapt to the teeth of the chain as it's being installed, without moving the actual camshaft, which remains firmly locked by the tool. Activating the tensioner: The pin is pulled from the new hydraulic chain tensioner so it can extend and fully tension the chain. Only when the tensioner takes up all the slack does everything sit in its ideal position. Torquing down at true zero: While both the crankshaft and camshaft are still 100% locked in place, and the chain is fully tensioned, the mechanic must use a counter-hold tool on the sprocket and torque the new camshaft center bolt to the exact factory specification (torque plus angle). Where did the mechanic most likely make a mistake? If the mechanic did not loosen the sprocket bolt when installing the new chain, or if they torqued the bolt down without using a proper counter-hold tool (relying solely on the locking tools inside the engine block/head to resist the tightening force), the locking tools flexed or bent slightly under the heavy pressure. At the exact moment the bolt was torqued, the sprocket "pulled" the camshaft a degree or two out of alignment. The result is exactly what you are experiencing—an engine that seems to run, but suffers from "incorrect timing" under load because the ECU detects a mismatch between the crankshaft sensor and the camshaft sensor.
Skoda Fabia Monte Carlo 1.2 TSI CBZB - Alternator belt tensioner replacement and Water pump recommendations
yeah gates or dayco, for example, OE timing belt for 1.5 tsi engine is made by Dayco. For the Volkswagen Group's 1.5 TSI engine (brands such as DADA, DPCA), Dayco produces the main camshaft timing belt (catalog number 941060, 20 mm wide and 163 teeth) and the smaller oil pump or water pump belt/belt (catalog number 941160, 81 teeth). It is about Dayco HT (High Tenacity) patented technology, better known in the automotive world as "White Belt". The white layer on the inside of the teeth is a special film of PTFE (Teflon) patented by Dayco and bonded to the basic nylon-aramid (Kevlar) fabric that covers the belt teeth. Extreme friction reduction: When the teeth of the belt fit into the grooves of the pulleys, friction occurs that over time "peels" ordinary rubber belts. Teflon dramatically reduces this friction. The belt slides smoothly and almost completely eliminates wear on the fabric of the teeth. Protection against lateral wear: The belt moves slightly left and right during operation and hits the edges (flanges) of the pulleys. The white PTFE layer also covers the lateral parts of the teeth, protecting the belt from lateral "backlash" and cracking at the edges. Modern 1.5 TSI engines have high direct injection pressures and develop enormous temperatures under the hood (over 120°C). Classic rubber would harden and crack over time. The Teflon and advanced HNBR rubber from which the belt is made remains elastic and stable for years Internal structure (fiberglass): Behind that white layer and the rubber, inside the belt are strands of high-modulus fiberglass woven into a spiral. These ensure that the belt does not stretch at all over the years and kilometers, thus keeping the engine's timinge perfectly accurate. you dont need that for alternator belt, but i read this on Autoteile.
it was, but not any more. go for INA, Gates ... In the original OE (Original Equipment) box under the catalog number 03C145299Q, there is an automatic tensioner (spanner) which for the Volkswagen Group (VAG) first installation is usually produced by Gates or Litens (which closely cooperates with the INA / Schaeffler groups). this pump on photo is produced by NIDEC GPM, Germany producer for OE VAG engines.. now produced in Jiaxing, Zhejiang, China.
Issues with Mk 4 1.5 TSI
my car had some issue, on half empty road, warn of colision popped and car itself braked to the floor, driver behind me avoid collision in inches. why is it doing? luckily it happened only 2-3 times in 2 years, no matter of weather or dirt. car decelerate and brake itself without reason, dangerous. i wanted to turn off all assistant stuff (i can do it in settings, its 2019), because i have 35 years of driving experience on motorbikes and cars, never caused a car crash, but it is helpful sometimes.. help to avoid car crash.
Advice on essential maintenance before looking at mapping
for best performance and security, whole car must be checked, low milege but also low year of production, shocks and rubber parts gone with time. brakes, brake fluids etc.. check everything, for your own sake and for sake of others. when ii tuned my 1.5 tsi from 150 to 180 ks, my first ride after warm up was pretty dangerous.. :-D
Severe coolant leak 1.2 EA111 CHF 3 cylinder engine
coolant also can get mixed with oil, not entering combustion chamber. not visible oil in coolant, but coolant in oil.
change oil no matter what, high quality oil and filter, intake air filter..
Ottocast issues
i have ottocast, but flat one. sometimes it wont self connect, then i manually tapping on display few times and after few times it connects, in settings i choose to connect when phone is off, so when i enter in the car, start engine, i dont turn of multimedia till 1 minute pass. then it connects itself good, sometimes about 2 of 100 connections fails, then manually reconnection fix problem.
Another Oil Consumption Topic
Bad maintenance and high mileage, sport driving style increase wear of piston and rings and engine consumes oil. too much oil in exhaust dpf cant burn and get clogged. EGR also have lifetime, and egr pipes get clogged. i hope you didnt pay car much.
What are they?
Opinions for new shocks+springs
i never had ones. but sure stiffer than stock.
if 88 in xour nick suggest you are born in 1988, than you are to aged to have stiff car suspension. it will become unconfortable. if you like it, go on, aif not, stay with basic B4 which are like OEM.
Karoq diesel engine oil 4x4 - recommendations / manufacturers?
VW Specification: VW 508 00 (petrol/diesel dual standard for 0W-20) or traditional VW 507 00 for long-life 5W-30/0W-30. if you living ih cold climate zone use 0w20, if you live in hot climate, than 0w30. manufacturer, i like Shell (Shell Helix Ultra Professional AV-L 0W-30) Shell, Castrol, Aral, Liqui moly...
Button panel adding functions
Broken spark plug - ruined engine? 1.4TSI CZCA
1.4 yes, only 1.5 no.
never drive engine with any noise. stop at moment. try to find missing part. easiest thru spark plug hole. if valves are not damaged, it will go. if cilinder wall is damaged, its old school cast iron cilinder wall liners which can be machined. no new engine needed.
Long life servicing
depends on your driving habits, if you live in colder areas with lot of short starts and stops, short trips, even 0w20 can be ok. i switched to 0w30, 30000 kms is no-go, 15000kms is maximum, i change oil once a year on about 8000-10000 kms, i dont drive much, but my drives are 90% short trips, about 10 kms rush hours. filters are cheap, i take Mann oil filter, Febi, Bluechem or Valeo air and pollen filter for about 8€ each, changing once a year. also aware that on your gearbox service probably has never been done.
Oil level...
i never checked warm oil because i cant pull out dipstick, affraid to brake it.
Cambelt and water pump replacement pricing
with a oil sump out, oil pump belt which is in oil bath should also be replaced.
- 6 replies
- 1
- #skoda
- l&k superb
- superb mk3
- 2.0 tdi
Tagged with:
Oil level...
on my 1.5 tsi DPCA is capacitiy 4.3 L with a filter (Manual), when i put that amount of oil, when it cools out completely, almost touches maximum line. 1 mm lower.
