fabia mk1 steering light on yet again !
Had quick look and I think its now 6q2423291ax Dont seem to be any available but there a few after market ones on autodoc. Try breakers. I use www.partsgateway.co.uk They check with over 150 breaker yards and you get quotes via email etc.
Skoda Octavia MkII maintenance & service
Sorry was thinking of the 1.6 diesel. I think your right mk2 chain mk3 belt. Alasdair
Headlight bulbs
Was recomended by mechanic mate to try philips xtreme vision pro150 h7 They are pretty decent and won't break the bank. He said that the 200% brighter don't seem to last long. Anything got to be better than the standard halogens. Whats the condition of your lenses Mine were starting to go a bit cloudy so polished them up with a holts kit. Made a fair bit of difference on both my sons fabia and my old octavia. .
First one I noticed is timing belt. I do mine every 50000 miles or 5 years. If its anything like the 1.9tdi do the water pump at the same time. Alasdair
Revs at idle seem high until warmed up? Is this normal?
Only had the car a few months as reckoned the old 1.9tdi was past getting an MOT without a lot of work. Did notice that the heaters seem to work as said before temp starts rising. The 1.9tdi seemed to warm up faster although before I sorned it it was struggled to get to temp probably due to bad thermostat. As long as its normal I am happy. Alasdair
Advice wanted - MoT failure emissions - would you scrap or save?
I cleaned the EGR etc and it was absolutely choked. Also cleaned pipes and intercooler which had some oil in them. Not sure if it helped emisions but car seemed to run a lot better. So far I havent had MOT problems. Did the same on an old Toyota lucida a few years ago plus blocked egr as it was fairly simple and didnt need to plug it in . The amount of gunge that was there I am surprised the engine actually ran. Worst was the intake. Who honestly thought an EGR system was a good idea. Alasdair
Many thanks. All before have been older 1.9tdi and didn't do it noticeably. Makes sense as this car is newer and has more electrics etc. Maybe the battery is getting a bit weak. Will put it on overnight charge and see if it helps. Seems to take at least 20mins to warm up and revs to drop most days especially when its below freezing and car is getting used for only two 5-10 mile journeys most days. Glad its norrmal. I was thinking it might be a idle sensor problem etc. Seem to be having a run of work needing done on my cars and my sons (bearings,clutch,ball joints and thats just the start of the list, and yesterday his needed a new battery so dont need anything else at the moment. Alasdair
Hi have a 12 plate 1.6tdi that the revs sit at 1100rpm when at idle. Sometimes its 1000 and randomly its 1200 rpm I have been trying to monitor it and it seems to do this until the temp gets to 90 and then rpm eventually drops to normal 850/900rpm. Seems to be at 1100rpm for a good while before dropping. Car does seem to take a while to reach 90 degrees. All my previous other octavias didn't do this. Just wondering if this is normal. It has been -3c so I am hoping being a diesel 1.6 and due to the cold weather its taking longer to warm up. Electric fan was coming on after engine switch off when at correct temp which I thought may be a failed DPF regen but thats stopped now its got colder. The fan not coming on might be pure coincidence. Car seems fine otherwise (apart from needing a service) with no fault codes or warning lights. Alasdair
Advice needed on new headlight bulbs - 1.2 HTP
I used to have a stock from lidl. They were good bulbs but my lidl only seems to have H4 these days. Spoke to my MOT tester mate and he said try Phillips Xtremevision pro150. He fits them to his cars and reckons they are about the best for the money he has come accross. £25-£30 per pair. He did say that the headlights have to be alligned properly as they are a good bit brighter.
Maybe turbo seals starting to fail if its done 250000. Had one that used a small amount of oil and was a bit smoky if idling for too long. Few oil spots on rear but nothing serious. One day filled the entire car park at tescos when they went completely. You definitley know when they fail. Got a second hand turbo cheap from the local scrapyard. Glad you got it through eventually. Alasdair
If the 1.2 is anything like my sons then the headlights could be needing polished. His were going a bit yellow and slightly cloudy. I changed for new standard H7 bulbs and cleaned/polished them as it was an advise on the previous MOT and it made a big difference. I also find that over time halogen bulbs seem to lose their brightness with age. I have tried 150% and 200% brighter bulbs in the past and yes there brighter but don't seem to last as long. Worth keeping a standard spare in Gbox. Might be worth getting the alignment checked as well. His were very low and the friendly guy at MOT tweeked them up a bit. Still not the best but a lot better. Was thinking of fitting some driving lamps where the front fogs should be. Alasdair
Help in identifying the wire
Not sure but it looks very like a vaccum pipe or perhaps evap? if it smells of fuel.
Loss of all power electrics
Not on a skoda but old volvo 940 used to randomly stop and then not start especially when hot. Ran great 99% of time but sometimes just would not turn over. All lights on but nothing. Usually started after a few attempts but eventually nothing. Had to call out garage as it happened in fourcourt after filling up They traced it to wiring either to the alternator or startermotor etc. I can't remember exactly but it was a small cable that I assume ran from ignition switch. Cleaned spade connector and it was fine for years after that. Car electrics are a nightmare. Have a seat altea that the radio comes on by itself, doors lock and unlock for no reason and interior light comes on randomly when driving but only at night and rear wiper randomly starts and stops half way and if I use the spare key it locks itself in engine imobilsed mode and won't come out of it. No idea what the problem or maybe multiple problems are. I think it may be a bad connector behind dash/fusebox area. Car is a bit damp inside from lack of use so I was thinking maybe some corrosion in a connector somewhere. Alasdair
fabia tyre pressure
The size difference is a lot. We bought the car for my son to learn to drive. The guy who had it before was into mountain biking so I reckon he put bigger tyres on for extra clearance. The car handled terribly. Sort of bounced along the road and steering was not what you would call positive. Tended to follow dips etc in road. I put a cheap set of part worn tyres on it to see and it made a huge difference then as winter was coming got GT radial all season. The car runs great now and the grip in the wet for all season is excellent. Guy at the tyre service said that he had never seen a car with such daft tyres. Alasdair Alasdair
fabia tyre pressure
I run mine at 2 bar for front and 2.1 at rear. I check them regularly as its an old car and the alloys tend to leak slightly at bead seal. Never haad a problem with steel rims but all my alloys seam to leak after time. Resealed one with black sealant the other day as it was reccomended for rusty corroded rims by the tyre service I use and so far its worked well. I run 195/50R15 GT radial all season and prefer them to the 185/55 r15 part worn that were fitted as a temp measure as when we bought the car it had rediculous large tyres on it 195/70 r15. May have been from a Golf but the car was like driving a space hopper plus they are about 3" bigger diameter which confused the hell out of the speedo They just fitted but not by much. Alasdair
Spots on paintwork/bonnet
Could be. My dad always washed bird droppings off as he said it was caustic and would damage the paint. A friend has a car similar. She rarely washes it and its usually either covered in bird droppings or sticky mess from greenfly from the trees she parks it under, Its a standing joke. We reckon if she leaves it any longer it will become part of nature. Her previous car even had a tree seedling growing in the gap for the sunroof. Alasdair
Clutch Issue
I know what you mean. Mine had 4 listed with upto and from dates and vin numbers. Even ended up contacting LUK but in the end I removed old one first and then ordered parts after measuring old one. Reckon leaving it to the garage is the way to go. They or their parts supplier should be able to work out what parts are needed. If they order the wrong part then its down to them. Hopefully they will sort it out for you. Alasdair
Have similar marks on my doors but it was due to sunscreen from the kids. Never did get rid of them. Yours may be from a vehicle in front leaking hydraulic fluid/antifreeze etc thats soaked into the paint. I read that meths or a car cleaning wax polish/colour restorer might help. Try on a hidden place first. Alasdair
Buzzing throttle body + emission fail. 1.2 HTP
Had similar emissions problems on my 1.2. There was a slight leak from the middle section join on the exhaust and that was enough. Mechanic sealed it with black paste and it passed after that. He was surprised that such a slight leak made the affected the emissions. He only noticed it as there was some black soot there. Alasdair
Clutch Issue
Had a look and as usual multiple options. Try https://vehiclelifetimesolutions.schaeffler.co.uk/en-gb/catalog Scroll down to where it says numberplate. Click and change to VIN then enter VIN in the next box and it should tell you which clutch you need or at least some options. From looking there seems to be 10-2010 and after 11-2010 when using numberplate. As far as I know DMF clutch disks dont have springs. Hope this helps. I used it to find the clutch for my MK1 1.2
Clutch Issue
I had a quick look and I see what you mean. Is yours a MK2 or a MK3 as they changed in 2014 also seems to be a few 1.6td engines with different power output. Whats the reg and I will have a look or try puting the reg into www.PartsInMotion.co.uk and see what comes up. Had a 1.9tdi that clutch went but the DMF was still fine. Garage checked dmf and replaced clutch and it ran for another 50000 miles until our postie totalled it. There are solid flywheel conversions for around £200 but not sure which one for your car. If you get the master cylinder done it might work for a while but I reckon at the mileage a new clutch may be needed in the future. Alasdair
I had problems with my EGR. kept coming up with insufficient air flown error codes. I cleaned it as it was pretty bad and checked valve and replaced. Still kept going into limp. On my 1.9tdi pd engine I found there is an EGR cooler at the rear of engine with another valve attached. This was sticking and I assume affecting the EGR circulation. Not the easiest to replace but cheaper than a new EGR cooler I picked one up off Amazon for about £25-00 Alasdair
Clutch Issue
I put my reg into parts in motion website and found that my 1.2 was solid. I think the DMF clutch discs have no springs in them . Not sure of the 1.6td. I know the 1.9tdi had a DMF. Your garage will need one or perhaps two new hub nuts as well. The ones on my MK1 can only be used once. I also had to cut the bottom ball joint off mine as the retaining nuts were turning when trying to remove them from the wishbone. Alasdair
Skoda fabia 1.2 2004, spluttering towards 40mph
If the compression test comes back as ok I would remove plugs and have a look at them to see if any are black etc then get it scanned again. It could be a bad new plug or new coil pack if it ran ok for 2 weeks. I have had random plugs fail within a few weeks before. From experience I now use Bosch or NGK if I can. If the scan comes up with misfire on no1 again you could swap coil pack and plug from number no2 to check. If its still scans as number one after that then I doubt its the plugs or coil pack. Could be a wiring fault to coil pack no1 or perhaps HT leads? Alasdair
Rocket cover removal, barrier ! Oil leak! Help!
Not sure but if its the small pipe that you are pointing at and it needs to be removed then I would just remove it. If its oil then its high up so shouldn't lose much if any. If its coolant then be prepared to top up afterwards. As its high up on the engine I doubt you would lose much of either. Replace with a decent stainless jubilee clip or similar. You could try a small pry bar and see if you could move it enough to remove cover. Be careful not to use to much pressure as the last thing you want is to break it or kink the metal pipe. Can you see where the metal pipe goes? Alasdair
