Everything posted by T07
Egr cooler- oem manufacturer
Good spot!
So the nrf Egr cooler I fitted has failed. Does anyone know the manufacturer of the Egr coolers currently to make sure I get a decent one? The old one was benteler but can’t find one after market. Oem is about £450 but mahle coming in about half that. But don’t want to get another lemon part 04L 131 512 BQ 2.0tdi cupa engine Thanks
Intake manifold compatibility 2.0tdi
The charge cooler comes out without having to touch the pump. not sure on the compatibility of that van wezel part to be honest. Looks right though
Worth checking into this one whether it’s compatible https://www.onlinecarparts.co.uk/van-wezel-14762726.html
Have been down that road and the second hand part failed unfortunately
They should all be revisions of the same part. Not sure how to work out what order they came in. Usually alphabetical but sometimes not. I would avoid a used part if possible.
This should give you a list of compatible part numbers https://www.skoda-parts.com/spare-part/04l129711ac-intake-manifold-skoda-32179.html
Rear Brakes
It won’t change how clean the rear discs are? I personally don’t see the issue on the rear discs, look pretty normal
Rear Brakes
Gdb2042 are what I have fitted and no issues at all.
What should be in this cubby hole / storage area?
https://www.skoda-parts.com/spare-part/5e58671459b9-storage-box-skoda-36795.html that might be it?
Help finding rear axle stud replacement (Octavia III Combi)
Dealer should be able to get it for you. for part number try here https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/805/5/500/500020
What's your quick interior clean methods?!
Microfibre and either spritz or an apc to wipe the dust and marks off every so often. Then when doing a big clean, apc then some dressing such as carpro PERL or dressle works well. Haven’t found anything better than autoglym glass polish for interior glass. Doesn’t leave any streaks. leather seats, a wipe over with leather cleaner every so often. Don’t use a combined cleaner/conditioner cream on these, just sits on the surface. Use a spray on sealant every so often. Dodo juice supernatural sealant had been very good from my experience
Leak from rear wiper has killed the motor
Hey, check out VIKA Wiper Motor in the AUTODOC app https://m.autodoc.co.uk/vika/13159197
Which coolant?
Mannol do vw coolant that is green or yellow also just to confuse matters
Brake disc size
Is there not something simple to tell with these? The 340s have a small bend in the calliper carriers and the 312s are flat/straight?
Octavia III randomly braking on the highway
Do all models have the feature that’s meant to gently apply brakes when wipers are on to keep them dry? Might be something to do with that not functioning correctly?
Keeping and skimming discs when replacing pads. On car, off car?
Hey, check out ATE Brake Disc in the AUTODOC app https://m.autodoc.co.uk/ate/7013633
Checklist before purchase!
Coolant leaks seem to be an issue (certainly on mine). Have a look for staining around the expansion tank that indicates something not right. Also check from a cold start if there’s alot of steam out the back. It’ll go away with a warm engine though so make sure dealer hasn’t warmed it up before you. The expansion tank lid should also click into place. If it doesn’t then likely it’s been on and off quite a bit.
Front brake pads
Trw have been the best fit I’ve found. Likewise the brembo from eurocarparts were poor and also had pagids that delaminated
Skoda Octavia VRS 2.0TDI (CUPA EA288) high oil consumption
- IAT - Intake Air Temperature sensor - location and removal
I opted for a used cooler. New one was around £800 or so. Nowhere could get it other than the dealer. You may have a slightly different version though so may be able to find one cheaper? There was no high pressure Egr on mine, not sure if this was introduced to the Octavia but appears on other revisions of the part from golf’s, tiguans and passats. I also now have yellow coolant due to uv dye!- Headlight washers
Yes you can, but think it’s only possible with vcds or OBDeleven.- Battery replacement
You should really get the new battery programmed to the car or it won’t know there is a new battery fitted and charging won’t be adapted to a new battery- Mk3 Workshop Manual
It takes me to a Dropbox link, so likely that they’re blocking downloads then - IAT - Intake Air Temperature sensor - location and removal
