Tell
Everything posted by Tell
  1. It is a mib3 isn't it. They are shown on the screen by pushing the right button. It's what the Seat folk have been doing but unlike Skoda they can't update since it's not in the manifest file. It could be your unit isn't in the manifest file. This was an old issue with mib2 POI import VW left off particular units so they never kept the POI import up to date on their website. People on mib2 high found a way of circumventing that. Mib3 is locked down so no tinkering with import files they are all encryption signed. I showed an example of the manifest file on the Seat link. It's MartiniBs original link file from the phonostar website. You use to be able to look at the firmware files and deduce the code missing. I think when I checked those I couldn't find a manifesto file in the firmware that tallies, but somebody may have done that now. Perhaps I was looking in the wrong place. The IDs you'd think you would find in the firmware file. You did with mib2. Probably in an SQL database in the firmware. Something for the youngsters to look for. You say, yep this is the firmware file, where is the ID that this works with this. How mib2 worked anyhow and VWs repeated mistake.
  2. Whilst you won't find it listed on the phonostar site the question is whether your units infotainment is defined by the SK in the file that steers it. Presentation is covered in the PDF that @MartiniB referenced in the original post. It has to be exact. If the file is presented one layer down in the file tree it won't see it. So two issues is the infotainment unit identified in the file... tricky to find out and secondly presentation. For Skoda you are looking at the SKs https://www.seatcupra.net/forums/threads/radio-logos-update.472858/#post-5048490 But the issue is you don't really know the code for the unit. Somebody probably does. It wouldn't work if it's not in the manifest. I asked about Mac because they put in additional characters which stops the validation if CleanMyDrive isn't used. That was OK for you but you can't poke about in these files and re save them.
  3. I asked about Mac incase CleanMyDrive drive. So not that. Presentation is the next.
  4. Exfat you want. Are you using a PC or Mac ?.
  5. Every ŠS Mk3.FL came with one... 😉. I joke. Perhaps his dealer left it in by accident. It's these ones that skip the adapter out https://www.google.com/search?q=usb+c+sandisk+reversible&client=firefox-b-m&sca_esv=1c4a2bf3bd651b6a&sca_upv=1&sxsrf=ADLYWII5nNY_f_7GelplCpJB6kXnJiFcPQ%3A1725460041460&ei=SW7YZo3gG8OUxc8P4LbjuAk&oq=usb+c+sandisk+reversible&gs_lp=EhNtb2JpbGUtZ3dzLXdpei1zZXJwIhh1c2IgYyBzYW5kaXNrIHJldmVyc2libGUyBRAhGKABMgUQIRigATIFECEYoAEyBRAhGKABSKxDUNgMWJg9cAB4ApABAJgBrAOgAfQSqgEJMC44LjIuMS4xuAEDyAEA-AEBmAIMoALBEsICBBAAGEfCAgYQABgWGB7CAgsQABiABBiGAxiKBcICBBAhGBXCAgcQIRigARgKmAMAiAYBkAYIkgcJMS44LjEuMS4xoAfBOw&sclient=mobile-gws-wiz-serp
  6. Ah but one adaptor isn't like the next... that's the issue. On the Seat side a Retrofitter fitter that was selling firmware updates had one client with one of the ones that didn't pass data... I asked "what was the solution". The guy said 50% of them don't work with data. Then as I said or didn't one guy said get one with a "flashing data light". Seems an awful hassle, a Sandisk reversible dual stick is the answer or if you got a modern laptop just a USB C stick. Other than that it's pop luck with adaptors or find one that says in the spec for data.... you might even find one with a data light 🫣. It will be the "charge only" one that are sold only for charging. Not all pins wired. Chinese parts bin which people drop their hands on.
  7. It's adapters that cannot work sometimes due to all the pins not being connected for data. Best to treat yourself to a dual / reversible stick with USB C on oneside, USB A on the other. Suppose to be adaptors which flash for data, I'd just buy a drive for the job. It's been said to me get a "data adaptor" but Skoda folk on mib3 map upgrades say get a dual reversible stick. It's the data bit that is missing. I'd splash the cash to get the job done. We're assuming the file is unzipped and presented correctly. The unit's themselves have a Skoda ID that matches up with the download so as long as the Superb Mib3 has the correct ID the file expects, presentation is correct and it's not hampered by the pin connections it will work.
  8. They have probably just downgraded their servers. The other thing is to factory reset your dongle thing if you haven't done it already. Skoda car stick. Presumably that puts out wifi to the car.
  9. Rural here going to the big Welsh smoke on the M4 so those hold ups are usefull and any local rural ones we now see. Mib2 high for trips to England so see the new road and traffic reports... mind you using my car on the our NHS tourists trips to get treated. More comfy but get to see the rural ones on our local run around. Probably Skoda's end of life service on mib2 connected services. Guess it will be the same for mib3 eventually. I'd put your issues down to Skoda internal mib2 connected services being run down on old hardware. Could be a minority of Skoda drivers took mib2 connected services and still use them. They never came to Seat in that form.
  10. Probably a system issue of the data passing more slowly through their systems before it gets transmitted out to you or their polling to the car. On the positive side using old maps still works well with FM and @pcbbc modules. Many more traffic reports than you ever got with the Trafficmaster system.
  11. Wo Yes worth trying out with the old maps. It could be you are just seeing an influx of a lot of reports that just takes a bit longer to build up. Over the air Inrix with the Skoda board magic you experience more traffic reports than you ever got with Trafficmaster so may be just a lot of data coming down.
  12. The only thing you can do is try a reboot, a long press on the on/off button till you see the splash screen. There are no other user controls. Just leaving the car powered off for 20 minutes may be sufficient to give the same results although elements of the infotainment system are kept live with mib3 connect services outside the 20 minutes so a reboot may be helpful. The fix all to infotainment systems where the program goes wrong.
  13. A bit normal that mobile phone companies steel your credit if you don't use the device for two months or so. I buy a 120gb EE SIM of Amazon, £60 for my tablet and bin it each year and buy another one. Think they are loss leaders. Handy for mobile hot spots in hotels where the wifi is no good, expensive or slow. They work in Europe if activated before you travel. Popular with canal boat people etc... cheap per gb data. On your other issue no telling how they interface the traffic data with connect services. It probably gets piped to Germany and slowly piped out.
  14. Tell replied to RodDuggan's topic in Skoda Karoq
    You have to have the whole lot. Europe is broken into zones, so those fragments are the zones. Over the air as you drive it updates by area. A trick apparently you can use with over the air connected services is to start a route across Europe, that forces an update of the whole lot. For offline you update the whole lot. It's just the design of connected services and over the air. No meddling now with the files as mib2 standard. They are signed which protects the integrity of them.
  15. Tell replied to RodDuggan's topic in Skoda Karoq
    It shouldn't do unless it have an esoteric infortainment system. You see on Drive2 sites some alternatives. Reckon you can rest assured that if it took the update it's the correct one. They would screen for incorrect updates. The VIN is really there to control access to their website of updates because they are sniffy. There will be "Mib4" ones coming along where you'll have a branch I reckon.
  16. Tell replied to RodDuggan's topic in Skoda Karoq
    On 6. Have you tried out the trusty mib2 high trick of opening and closing the door everything 15 minutes. VAG cars power down at 20 minutes so 15 minutes gives you a grace period. It's like when you have the radio on and it shuts down. It won't shut down if you open and close the door at 15 minutes. I update mine with SWDL in Mib2 high so there is no roll back. These will have a roll back but if you fool it to think you are still there it will keep going moving forwards rather than a restart from a restore point in the update. My two pennies worth.
  17. These are the 2024/25 June 2024 European release. Skoda have officially released the 2024/25 maps for Europe if you had a Skoda VIN, fear not the direct link is this: https://infotainment-cdn.skoda-auto.com/base/maps/OI_P119_EU_202425_Offline_Update.zip VW have not as yet put the file up on their map site but again we have the link: https://navigation-maps.volkswagen.com/vw-maps/EUR_12PR119_FCT3WS-23131_Offline_Update.tar Both are identical... so the story goes. No sign of Seat thou. All files are interchangeable.
  18. Thank you very much... got that working. One for @MartiniB based on this post There is a ECE 2024/2025 which tallies with the results shown in the database. I see they are churping about it: https://www.briskoda.net/forums/search/?q=CE2024/2025&quick=1&type=forums_topic&item=524268 on a search for ECE 2024/2025 so it's slipped out which I quess it's why we are talking about it as confirmed @c34 ... I had been wondering where the June release had got to. I don't think I missed @MartiniB 's posts on it but perhaps I did.
  19. I believe we might need a SQLite addon engine to open these files ?. https://nds-association.org/nds-tools/ Need a tutorial / short note on how to load up the missing bit.
  20. Great you have answered my question of how to find the release date and tally with the online ones. Well done.
  21. Because you didn't take a back copy, you will be stuck. Your unit isn't a mib2 standard and neither is it a mib1 standard... if it was this would be the solution. Over to RN315 Amundsen experts... but since you said you guessed it was an RN315, you'd be in a better position if it wasn't. That's the mib1 standard update for 2023 which people have got going: https://www.briskoda.net/forums/topic/511425-amundsen-mib1-maps-update/#comment-5871892 I'd google the serial number on the map card and see whether it's classified as mib1 standard from adverts for the card you have. The second method, google the unit's infotainment part number if you can get that to show. If you can place it to an Amundsen Mib1, then you are in luck and can follow that will. Some frigging about is required... hmm but then you have lost your copy of the map file if you didn't take a copy. At this point, you do a shout-out for someone to give you a copy of the contents you'd accidentally deleted. On Seat mib1 standard, that was done for two guys that failed the newbie test of not taking a copy before messing about with it. I pass on anything prior to mib1.
  22. Yes you sign up for a TomTom Mapshare account. http://www.tomtom.com/mapshare/tools Identify the missing bits and provide evidence as far as possible. You get a tick mark if accepted then wait a year or so for it to come out in the release. It's a production cycle. Depends where you enter into it. Crowd sourcing the missing stuff.
  23. I do it's all in the connection type. They shifted to modern connections with mib3. (USB C). https://www.viewsonic.com/library/tech/usb-c-usb-b-and-usb-a-whats-the-difference/ Left top line USB A = mib1 / 2 Right top line USB C = mib 3 / 4 That's the socket you'll plug a lead into the car's presented area for a USB cable.
  24. Oval USB connections being USB3 it's mib3. If the rectangular USB plugs mib2/1. Mib3 came in on 2020 models and beyond. So can be placed by year unless they were fitting older infotainment units after 2020. No SD card reader it's a mib3/4.
