Everything posted by Tell
MIB3 map update
Well the youngsters like to reject the built in maps and use Google Maps etc but neglect to understand the relationship between ACC and the built in maps. Those with EVs and the predictive regeneration.... still you can't tell some people. Google maps aren't produced by a proper cartography company. If they can get a camera car down it, its a road although its a private un made farm track ticks the boxes. Ditto builders roads on estates. They are put in by the estate builder. They get digitised by Google maps and it becomes a fact. Now if you were driving a bull dozer it would be fine. The roads are grubbed up, houses built on them but still they remain in Google maps. Then the mapping companies digitally analyse each other maps and say, hey there is a road here and put it in, when there isnt. The blind leading the blind if good validation isnt carried out. The OS Planning maps are the defacto statutory official maps of the UK. Crown copyright. If it's not on them, it doesn't exist as a passed development. The house numbers are allocated by the LA on these maps with their road names added. They dont have road speeds, those have to be extracted by the cartography companies if they are doing it correctly by writing to the LAs. This they do. Others dont. Road positioning, mapping car or aeriel images. Some cartography companies use synthetic house numbering where they stretch the house numbers equal distance between the start of the road and end of the road. No good if a park is in the middle. Lazy way of doing it. For my sins I did work in health service planning where we used gravity modelling, travel time modelingl for service planning plus all the other management science techniques. At the time when the NHS has planned and had capital to build things. We started to get into GIS as NHS planning just at time when it was abandoned in favour of market management, so I shifted to that but kept an interest in spatial stuff. Well us mathematician dont trust geographers 😀. I'm a management scientist by profession. I did built a microcomputer from chips once... many solder joints. It was an evaluation I was given by someone advising the BBC home computer project. Here you go try building this, my old Senior Research Fellow manager. Had a minor in computer science. Dry solder joint in the power supply stopped it working. Built a teletext decoder once... misspent youth. Anyhow. Zip files. The built in unzip in Windows these days can be used rather 7zip. 7zip can be used but use the most uptodate copy. It seems in anycase the most recent reports of it moaning seems to load fine in the car. Skoda seems to have an ability of not being able to zip their files too well. I say loading up the most recent maps in the car is like hot cakes, get them whilst hot in case they go.
MIB3 map update
I keep three versions back. The complication with the connected services is whether in contract or not. If in contract for map updates then then off line thread isnt for you. If shifting from contract services to a six monthly off line MartiniBs threads are and you need to know your yyyy.mm which is really the map seriel release in the unit. If @MartiniB link as posted above has a latter yyyy.mm then you are in business for a USB map update. It is the same as mib2 its the seriel number of the map release which is the key. Offline maps tend to be released June / November but appear on the file servers earlier discovered by those people that look for them. Also Vag sub brands get lazy at publishing them and drag their heels. Hence you take the first Vag brand one released and dont wait for your tardy brand to publish it. Its all the same. At the minute all releases for June are out and we seem to have the mib2 standard November release as well.
MIB3 map update
Yes the maps have seriel codes known to the unit the yyyy.dd is the code for mib3. Mib2 they are just numbers. One set for mib2 standard, one set for the mib2 high. Those codes are the same across all Vag brands and the map files are interchangeable as long as they are for the same release. Mib3 has I recall three types of infotainment. Youd have to eyeball @MartiniB files. I've seen three for mib3. Two for ICE, one for EVs. When you could freely look at the VW site you could place what worked with what. I believe the third less common file is for large screen models. When you enter your VIN into say the Skoda site it only tells you yours. The logo files that MartiniB publishes you try out each mib3 if uncertain. It only works with the one it's designed to work with. I got a suspicion that the third one is only seen on Audi. When downloading from the portal on the browser you can read, button left on Firefox, the name of the file or when it downloads. Thats the file type and place against @MartiniB navigation links. Then those are the future files you want, bracketed by his posts into VAG navigation unit. As for forward releases. That yyyy.mm is like the mib2 standard release an upgrade will only be actioned if yyyy.mm (new) > yyyy.mm (old ) for mib3. In mib2 there is the developers menu (back end menu). SWDL is the software download command in that. Any file, firmware, maps, pois, logos etc. Can be uploaded to the unit irrespective of whether they are "new" or "old". You can go back versions or write onto itself. Mib1 you could get into this via a very long hold on the menu button. Mib2 they locked that down but with VCDS, Obdeleven etc you can unlock access to the developers menu and the long hold will give you the second screen with the SWDL command on it. You can also update each entity, region etc of the maps. I pass on what some of the map entities are. For example you can update just Iceland in a Europe in a mib2 high. This is one of my tests in playing about with the maps - lot faster than the 40 minute for all of Europe. The heady days of backend menus for mib3 is over, you are locked out as far as I know. Thus you can't reinstall an old map or a map onto itself using the backend developers menu. Its not available. It could be a case of never say never. Vag want to keep wondering hands out of the backend of mib3. You can look at the SWAP / FeC codes, the first screen on the long hold, but not the second screen of the longer hold on the menu button. Edit You'll be pleased to know looking at MartiniB's last mib3 post of file links to the map servers for navigation for Skoda cars, currently only deal with one file type... the other two haven't arrived yet to Skoda 🫡. They are on other Vag cars. https://www.briskoda.net/forums/topic/513799-mib3-map-updates-202406/ Anyhow that check above is the one to get you into the ball park. Then you read off your yyyy.mm from the infotainment unit and compare with the published link of whether its an update. If ofcourse you have subscribed to connect services for map files and its correctly configured, you as primary user, not hiding your identity since you want to murder someone etc... then you should get it automatically. Not good to go incognito in the car with connected services you dont get updates and youd still get nobbled for crimes.
MIB3 map update
Well if you got an active connect services contract for navigation you have no real requirement to update the maps via the download. Its all automatic. The infotainment screen shows you the current release. Under contract map services you should get one monthly. If not under contract then they are made available twice a year. @MartiniB publishes the serial number. Obviously if you get them via the portal the webpage author may not edit that into the front web page. A helpful soul told us where to find that in the files after I'd been asking. The issue at that time was across Vag old mib3 maps were shown, with different file names by brand although all the same update. So now we know how to read the yyyy.mm and they can be placed by their update, date, not filename. Currently only Skoda files are the most update mib3 files which are interchangeable. That may change. Thus its best to look at @MartiniB links if you want the best updated ones rather than the portal of the Vag brands. If you have brand loyalty with offline maps you may be running with old navigation files that you can better. If you use connect services and pay for navigation map file updates and have the connect services set up correctly, then it automatic. MartiniB posts the threads here which cover all Skoda navigation models. https://www.briskoda.net/forums/forum/7-audio-electronics-and-security/ Clear as a bell.
MIB3 map update
Probably use roapy old servers. The faster you can get it off the less likely you'll be exposed to server issues. VW servers tended to be faster but then Skoda has the goodies on them of recent. Doesn't hurt using the Turbo Manager or similar if you experience issues.
MIB3 map update
Yes but if the server has a wobble the download manager can handle it. Where the download managers come in. Mega people are hot on them prior to them offering their own. This is the one that mibsolutions recommend https://www.a5oc.com/attachments/mibsolution-one-fix-download-speed-vag-mib2-1-pdf.184875/ Its all the same stuff, parallel connections. We assume that Skoda has that facility on the server. They probably all do. The Turbo Manager is the one I use. Firefox addon.
MIB3 map update
Reckon download manager is the answer then you also see the incomplete files that you can scrub. I'm probably too use to using the Turbo Manager. Good point making sure you got the space. I might also have a ridiculous 900 Mb connection as well 🫠. Started on rural wireless broadband moving from fibre in London to wobbly roof aerial rural broadband. Two years of getting up in the night to cokes these big downloads. Turbo Manager comes into it with that. Then on full fibre to the property and installed Asus mesh, outing the OpenReach router. Like living in a hotel in London now... mesh and fibre. 4g is rubbish thou in these parts.
MIB3 map update
You may need a different browser / download manager. If it's a problematic connection using a download manager addon to Firefox can solve it. This is the fix I recommend to one person and it did it. https://www.briskoda.net/forums/topic/532458-columbus-map-update-2025-2026-mib2-high/page/2/#findComment-5958751 That was on the mib2 high file thread but may help with you. Dodgie servers create problems and connections. Download managers iron things out. The mibsolutions people swear by them since their servers are pretty bad. You'll see the addon talks about multi threading. You just install it. I just leave it sitting there once installed. Didn't configure it. There it's sat for several years. Different browsers may also work better. That was a GitHub project which works across browser. I reckon it could be built into some now.
MIB3 map update
If in Europa you can do better than that with @MartiniB files. The thread labelled 25.02 has Europe in it more recent. Its the old trick. Vag websites dont show the most recent files at times. Currently its across all sites more or less you can better what a Vag site is saying. Its like libraries of old where new books come in but are waiting for the plastic film, the stamp page etc. The Vag file server has the file but the web site designer hasn't edited the page yet. This page for the latest mib3 navigation files that the vin lookup may not have (that has 2025.05 for Europa):
Radio stations Logos database updates
That's not going to be mib3 friendly though. The taxing one for new owners of Vag cars since 2020 kitted out with mib3 putting logo management onto their own locked down import files or OTA where missing logos exist since Phonostar their contractor doesn't have them in their database. Mib2 you can top up via assorted methods. The issue with mib2 is where people delete them on mass and have to get them back. VAG no longer offering the database as the first step. In the UK stations come and go, logos change so without a user solid way of doing it, the tail is wagging the dog, the case with mib3. Where that web site will come in handy for anything other than mib3... plus the Phonostar extraction of their logos or using that radio net website. The manual method going back to the horses mouth is the media.info website as in this example. I've only had to do that on 2 or 3 stations, the rest were in the car's system. If there is a new station you just look it up on the media info website logo for VW cars and add it to your USB. As VAG stopped publishing the logos their saved one on a stick, I augment with the ones I got off the media info site. If you use the Kodi radio de app logos are sometimes useful for where the database doesn't have it in and you enter by IP and need the logo... a thousand and one uses of logos. Rasberry Pi apps as well. All of which is no good for mib3. Eg. Mib1 / 2 method. Boot and braces: https://media.info/radio/stations/times-radio/logo-for-vw
Seems Seat / Cupra then have the rough edge of this, not having the part number in the files if you need to do it outside OTA. As I said those without connect services contracts were getting firmware updates and radio updates over the air. Probably the firmware was pushed out as a fix why it was free. That contained the logo database update but you can't be certain that you'll always get these firmware updates if Vag decide they aren't critical where paid or not. Like for mib2 they didnt offer the latest firmware, you only got that if it was a fix for a bug. Thus if you only get those OTA and the radio update as a job lot that's problematic. Why you need the logo update file... if only they had the Seat / Cupra IDs in them. So yes Škoda has the best of both worlds on this 🙌 .
- Radio stations Logos database updates
- Mib3 Map Updates 2025.02-06
I think you are into the curse of the Middle East, African and Turkey set up cars. The question is whether it has a regular infotainment system then a retrofitter can enable what hasn't been enabled. No GPS aerial may be stuck. Certainly the Turkey ones can be turned on via ODIS coding via an authorised dealer. If the Skoda site is pointing to European maps that would suggest its authorised for Europe. If you did manage to zoom out with those loaded and saw Europe then you would still need the RoW navigation FeC. Probably better experts on mib3 FeCs on the board here but unless they got an ODIS license they wont be able to do anything. Vag put pay to the hobbyist hacking of these units with mib3. No tool kits except authorised equipment and software. The availability of the mib3 Israel map probably means it's sold on something or they are planning too. Previously no cars were sold with Middle East maps by the Vag group, you had to enable that. More challenging now. As mentioned East Yorkshire Retrofits that has a presence on this board have offered to remotely enable aspects of mib3 for a cost if the buyer, buys that Vag adapter. They would look up your Vin and see what's actually in the car. That's my best advice. They are licensed to do this work.
Its a genuine one of these VAS6154/6154A that retrofitters with fully licensed Vag software can remotely legally make changes to the car. Mib3 is locked down at a level that didnt occure with mib2 where hacks were used. Vag got that back under control with licenced access to the back end. So yes if I p've understand the question, that's the answer.
I'm wondering whether that falls into the European import into Israel. Is that where you are. The Middle East countries dont come with maps. If so it wont have a Middle East navigation FeC. The issue comes up in Africa. Think Turkey also. You have to find a retrofitter to make it work. Yes it was Turkey where the guy was most upset that the dealer car had Turkish maps but his hadn't. Was told to find a retrofitter. You can buy a dongle which a retrofitter patches into to do it remotely. East Yorkshire Retrofit in the UK gave that bit of advice. The Turkish one found a retrofitter locally. Does that make any sense. Israel / Europe.
Yes so basically where the firmware is deemed to need updating you'll get a radio logo update even if out of contract for connect services but if you dont satisfy those condition you wont get a radio logo update. If a Skoda or VW you can use the files. Seat / Cupra not since they never wrote the SE descriptor into those files of recent. You trade the money you saved by not maintaining connected services with holes in the logo radio screen and reduced functionality of not being able to send POIs to the car, turn the heating on if an EV etc. Think I'd pay up myself if I had an EV just to remotely turn the heating on and the POI functionality.
But was it over the air triggered by the use of that file. Have you got your LBC logo. Reckon MartiniB issues are round the unzip process. Some pesky implementations of it about. Seems latest 7zip or built in Windows managers does the business. Older zip programs struggle with some of the newer implementations. The other issue is where it doesn't appear on the virtual cockpit but on the main unit. You delete from favourites and reapply. Another one where that happens on mib3.
On the later I suspect it's like the map updates you are finding ones yet to be "released". If OTA is supported on out of connect service contract then the mib3 logo files beat the OTA becoming available which might be triggered by a firmware OTA. That's my theory. Yes I've yet to see which mib3 updates streams belong to which. Its going to be on the firmware. That's where you inspect mib solutions to see which hardware they are talking about. LG etc. Ateca / Karoq is on one set. Formentor / Skoda ? (MQB Evo) Is on another. EVs on another... the logos probably associated with the firmware - it's those part numbers you see in the files. The map files seem to be across. My two pennies worth. I can't see it will be only Seat / Cupra getting OTA out of connect services contract. Bet Skoda and VW are getting them. Those give you firmware, firmware + logos, or just logo. Whether you can get a logo updates out of contract OTA without a firmware update, not sure. These are just reports I'm reading spurred by publishing these logo links on the Seatcupra board.
Was it really an OTA or gave it a kick to get one. Seems something more is going on with these files. As far as the logo graphics are concerned Phonostar manage them for Vag so if they have holes in their files then you see those holes in Mib3. I'm hoping @MartiniB can throw some light on how out of contract Seat's get the firmware updates and logo updates. These seem to be pushed like a digital TV box. Vag decides they are eligible and gets them. May be they see these as critical updates to firmware so are rolled out for free. Question is whether the firmware update then triggers the logo update over air. The files in this thread with no SE in the descriptor aren't seen by Seat or Cupra, why I was surprised to find out units were being updated. Anyone.... may be it's common knowledge to the inner circle of mib enthusiasts.
Eek but what do you think of this ? https://www.briskoda.net/forums/topic/520105-radio-stations-logos-database-updates/page/8/#findComment-5959372 Seat users getting logo updates out of contract. I'm not sure whether that's a result of getting a firmware update pushed to the unit then the radio logo update. Anyhow it's been happening.
I would say you have a mib3... this one from above Mib3 (Superb Mk3.FL and similar) Tiguan 3G5 035 820 Q "FM3-E3-DWBC4-EU-SE-MQB-PC", "FM3-E3-DWBC4-EU-SK-MQB-PC", "FM3-E3-DWBC4-EU-VW-MQB-PC", "FM3-E3-WBC4-RW-SE-MQB-PC", "FM3-E3-WBC4-RW-SK-MQB-PC", "FM3-E3-WBC4-RW-VW-MQB-PC", "FM3-E3-WBC4-US-VW-MQB-PC", "FM3-E3-DWBY4-EU-FO-MQ2-PC", "FM3-E3-DWBY4-EU-SK-MQ2-PC", "FM3-E3-DWBY4-EU-VW-MQ2-PC", "FM3-E3-DWBY4-W2-FO-MQ2-PC", "FM3-E3-DWBY4-W2-SK-MQ2-PC", "FM3-E3-DWBY4-W2-VW-MQ2-PC", "FM3-E3-HWBC4-RW-VW-MQ2-PC", "FM3-S-NDWBY4-EE-SK-MQ2-PC", "FM3-S-NDWBY4-EE-VW-MQ2-PC", "FM3-S-NDWBY4-EU-SK-MQ2-PC", "FM3-S-NDWBY4-EU-VW-MQ2-PC", "FM3-S-NWBY4-R2-SK-MQ2-PC", "FM3-S-NWBY4-R2-VW-MQ2-PC", "FM3-S-NWBY4-RW-SK-MQ2-PC", "FM3-S-NWBY4-RW-VW-MQ2-PC", "FM3-S-NWBY4-W2-SK-MQ2-PC", "FM3-S-NWBY4-W2-VW-MQ2-PC", "FM3-S-NWBY4-W3-SK-MQ2-PC", "FM3-SM-NDWBY4-EE-SK-MQ2-PC", "FM3-SM-NDWBY4-EE-VW-MQ2-PC", "FM3-SM-NDWBY4-EU-SK-MQ2-PC", "FM3-SM-NDWBY4-EU-VW-MQ2-PC", "FM3-SM-NWBY4-R2-SK-MQ2-PC", "FM3-SM-NWBY4-R2-VW-MQ2-PC", "FM3-SM-NWBY4-RW-SK-MQ2-PC", "FM3-SM-NWBY4-RW-VW-MQ2-PC", "FM3-SM-NWBY4-W2-SK-MQ2-PC", "FM3-SM-NWBY4-W2-VW-MQ2-PC", "FM3-SM-NWBY4-W3-SK-MQ2-PC", "FM3-S-NWBY4-RW-SK-MQB-PC", "FM3-S-NWBY4-RW-VW-MQB-PC", "FM3-SM-NDWBY4-EE-SK-MQB-PC", "FM3-SM-NDWBY4-EE-VW-MQB-PC", "FM3-SM-NDWBY4-EU-SK-MQB-PC", "FM3-SM-NDWBY4-EU-VW-MQB-PC", "FM3-SM-NDWBY4-RW-SK-MQB-PC", "FM3-SM-NDWBY4-RW-VW-MQB-PC", "FM3-SM-NDWBY4-W2-SK-MQB-PC", "FM3-SM-NDWBY4-W2-VW-MQB-PC", "FM3-SM-NWBY4-R2-SK-MQB-PC", "FM3-SM-NWBY4-R2-VW-MQB-PC", "FM3-SM-NWBY4-RW-SK-MQB-PC", "FM3-SM-NWBY4-RW-VW-MQB-PC", "FM3-SM-NWBY4-W2-SK-MQB-PC", "FM3-SM-NWBY4-W2-VW-MQB-PC", "FM3-SM-NWBY4-W3-SK-MQB-PC", "FM3-S-NDWBY4-EE-SE-MQB-PC", "FM3-S-NDWBY4-EE-SK-MQB-PC", "FM3-S-NDWBY4-EE-VW-MQB-PC", "FM3-S-NDWBY4-EU-SE-MQB-PC", "FM3-S-NDWBY4-EU-SK-MQB-PC", "FM3-S-NDWBY4-EU-VW-MQB-PC", "FM3-S-NDWBY4-R2-SE-MQB-PC", "FM3-S-NDWBY4-R2-SK-MQB-PC", "FM3-S-NDWBY4-R2-VW-MQB-PC", "FM3-S-NDWBY4-RW-SK-MQB-PC", "FM3-S-NDWBY4-RW-VW-MQB-PC", "FM3-S-NDWBY4-W2-SE-MQB-PC", "FM3-S-NDWBY4-W2-SK-MQB-PC", "FM3-S-NDWBY4-W2-VW-MQB-PC", "FM3-S-NWBY4-R2-SE-MQB-PC", "FM3-S-NWBY4-R2-SK-MQB-PC", "FM3-S-NWBY4-R2-VW-MQB-PC", "FM3-S-NWBY4-W2-SE-MQB-PC", "FM3-S-NWBY4-W2-SK-MQB-PC", "FM3-S-NWBY4-W2-VW-MQB-PC", "FM3-S-NWBY4-W3-SK-MQB-PC" Content Downloadable Size 2023.12.20 2023.12.20 162 MB https://www.phonostar.de/download/vw/MQB3_OI_JND_Europe_v1.31.48b.zip 2024.05.17 2024.11.07 1,13 GB https://www.phonostar.de/download/vw/MQB3_OI_JND_Europe_v1.31.50.zip 2025.01.14 2025.02.20 166 MB https://www.phonostar.de/download/vw/MQB3_OI_NonGP_JND_Europe_v1.31.56.zip 2025.01.08 2025.05.26 833 MB https://www.phonostar.de/download/vw/MQB3_OI_JND_Europe_v1.31.56.zip 2025.03.19 2025.06.11 167 MB https://www.phonostar.de/download/vw/MQB3_OI_JND_Europe_v1.31.58.zip What I did become aware of and waiting for @MartiniB comment is that firmware and logos get pushed to people out of contract if you are the primary user and chosen not to go incognito. The thread is where you want to upload the logos yourself and out of contract, but I suspect you might get thd logo uodate if the firmware is updated out of contract. You can fumble with the information screens to find what radio logo database you are on and compare with the above. There is no way to manually enter your own png image for missing logos. VAG closed that route down. Its a gripe of mib3. Haven't got mib3 myself. What I would say is you just unzip those files and present correctly. You can't tinker with mib3 files. It won't see them if you do. Use the latest 7zip for unzip or the latest windows file manager to drag and drop the files onto a blank USB-C. Adapters for type a to c are not recommended since some are not fully wired for data. Reversible memory sticks are liked with a data flashing light on them. So basically if you are in connected services contract, the mib3 file wont be required and it seems least for Seat updates are pushed over the air even if you aren't in contract, but that might be as part of a firmware update. I'd be interested to know whether Skoda out of connect services contract users are getting firmware updates and whether they get the radio logo one as well over the air.
@MartiniB it's become apparent that out of contract Seat mib3 people are getting radio logo updates over air. Whether they get these after an over the air firmware update out of contract then comes thd radio station logo update or whether they get these irregardless. Are Skodas getting out of contract firmware and radio logo updates on mib3 or is this something that Seat / Cupra get. Any views. You have to be logged in as primary user and not hiding yourself.
Columbus Map Update 2025-2026 (MIB2 HIGH)
It downloaded fine in Blighty. 900Mbs connection. Firefox and Turbo Manager 3.0. People swear by these comms managers. Turbo Managers on iffy connections. Something I installed months ago and just leave it there. I did have a very iffy connection some years ago via radio rural broadband. Now full fibre to the premises. These download managers help with Mega files as well. https://addons.mozilla.org/en-GB/firefox/addon/turbo-download-manager/ I see there is one for Chrome. Chrome or whatever, Edge might have a built in one. I dont have a wobbly connection these days. Anyhow that's what they advice when the connection is problematic.
- 53 replies
- columbus
- discover pro
- mib2
- mib2h
Tagged with:
