Everything posted by Carlston
What more comfortable tyres to fit to 215/45/16 rapid elegance alloy
In some countries outside Europe, the 16" option on the Rapid was 195/55R16 6Jx16 ET40 rather than 215/45R16 7Jx16 ET46 that the European Rapids were fitted with. The 195/55R16 6Jx16 ET40 option would give similar comfort levels to the standard 15" option, ie. 185/60R15 6Jx15 ET38. ET35, ET38, and ET40 offsets could all be considered with 6Jx16 rims fitted with 195/55R16 tyres. These rims are fitted to the Scala/Kamiq so there is plenty of choice. Steel 6Jx16 rims from the Scala/Kamiq are available with the ET35 and ET40 offsets, and 6Jx16 alloy rims from the Scala/Kamiq are available with the ET35 and ET38 offsets. 6Jx16 ET35 5/100 57.1 and 6Jx16 ET38 5/100 57.1 alloy rims (from the Scala/Kamiq) https://eshop.skoda-auto.cz/cs_CZ/alu-kola/c/alloyWheels?q=%3AscoreDesc%3ArimDiameter%3A16%22%3AcarType%3AScala%2B%282019%2B%29%3AcarType%3AKamiq%2B%282019%2B%29&text=# Alcar 6664 6Jx16 ET35 5/100 57.1 steel rim (from Scala/Kamiq) (7.44kg) https://www.mytyres.co.uk/rims/details?vehicleId=1077003525243802724&rimCode=ALCAR6664 Alcar 6977 6Jx16 ET40 5/100 57.1 steel rim (from Scala/Kamiq) (7.44kg) https://www.mytyres.co.uk/rims/details?vehicleId=1087670437300671588&rimCode=ALCAR6977 Continental AllSeasonContact 2 195/55R16 87H (Euro label B B 71dB) https://www.camskill.co.uk/m139b0s7952p221968/Continental_Tyres_All_Season_Car_Continental_Conti_All_Season_Contact_2_195_55_R16_87H_TL_Fuel_Eff_%3A_B_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_71dB Vredestein Quatrac 6 195/55R16 87H (Euro label C B 70dB) https://www.camskill.co.uk/m139b0s7952p202114/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_195_55_R16_87H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_70dB Another option could be 195/60R15 on the standard 15" rims, ie. 6Jx15 ET38 5/100 57.1. 195/60R15 is a slightly cheaper tyre size than 195/55R16, is slightly more comfortable than 195/55R16, and keeps the gearing closer to standard. Outside diameter of tyre 215/45R16 599.9mm 195/60R15 615mm (2.5% bigger outside diameter compared to 215/45R16) 195/55R16 620.9mm (3.5% bigger outside diameter compared to 215/45R16) 6Jx15 ET38 5/100 57.1 alloy rims (from Fabia MK3/Rapid) https://eshop.skoda-auto.cz/cs_CZ/alu-kola/c/alloyWheels?q=%3AscoreDesc%3ArimDiameter%3A15%22%3AcarType%3AFabia%2BIII%2B%282014%2B%29%3AcarType%3ARapid%2B%282012-2020%29&text=# Alcar 7760 6Jx15 ET38 5/100 57.1 steel rim (from Fabia MK3/Rapid) (8.02kg) https://www.mytyres.co.uk/rims/details?vehicleId=799637973241959524&rimCode=ALCAR7760 Continental AllSeasonContact 2 195/60R15 88H (Euro label C B 71dB) https://www.mytyres.co.uk/rshop/tyre/Continental/AllSeasonContact-2/195-60-R15-88H-EVc/R-496077 Vredestein Quatrac 6 195/60R15 88H (Euro label C B 70dB) https://www.camskill.co.uk/m138b0s7993p202144/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_195_60_R15_88H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_70dB One other option for the 15" rim, is 5.5Jx15 ET40 5/100 57.1 from the Fabia MK4. At just 6.6kg for the Alcar 4055 steel rim this is a particularly light rim. Compared to a 6" rim width, a 0.5" narrower 5.5" rim width will slightly improve the ride comfort further with the 195/60R15 tyre size. Alloy rims from the Fabia MK4 are also available in this specification and although not quite as light as the 6.6kg steel rim, 7.2kg is still quite light. 5.5Jx15 ET40 5/100 57.1 alloy rim (from Fabia MK4) (7.2kg) https://eshop.skoda-auto.cz/cs_CZ/alu-kolo-hadar-15-fabia-iv/p/6VA071495A+FL8 Alcar 4055 5.5Jx15 ET40 5/100 57.1 steel rim (from Fabia MK4) (6.6kg) https://www.mytyres.co.uk/rims/details?vehicleId=1360399348768339044&rimCode=ALCAR4055 Set of four wheel trims for 5.5Jx15 ET40 5/100 57.1 steel rims 6VA071455 (from Fabia MK4) https://eshop.skoda-auto.cz/cs_CZ/sada-poklic-calisto-15/p/6VA071455
Wheel size conflicting advice
Compared to the 225/40R19 tyre size, 215/55R17 has a 0.9% bigger outside diamete and 225/50R17 has a 0.9% smaller outside diameter...as shown in the chart below. In general, less than 1.5% difference is considered insignificant. Outside diameter of tyre 225/40R19 662.6mm 215/55R17 668.3mm (0.9% bigger outside diameter compared to 225/40R19) 225/50R17 656.8mm (0.9% smaller outside diameter compared to 225/40R19) 215/55R17 and 225/50R17 have the same standard load index...as shown in the chart below. Standard Load index 215/55R17 94(670kg) 225/50R17 94(670kg) ETRTO approved rim widths for passenger car tyres 215/55R17 6.0-7.0-7.5 225/50R17 6.0-7.0-8.0 As you can see in the chart below, there's slightly more protection from kerbing damage with the 225/50R17 tyre size compared to the 215/55R17 tyre size when both are fitted to a 7J rim. This is because the sidewalls on the slightly wider 225/50R17 tyre size bulge out slightly more than the narrower 215/55R17 tyre size...when both are fitted to 7J rims. Rim protection from kerbing damage when fitted to a 7J rim 215/55R17 good 225/50R17 very good Continental AllSeasonContact 2 215/55R17 94V (Euro label B B 70dB) https://www.camskill.co.uk/m140b0s8825p220589/Continental_Tyres_All_Season_Car_Continental_Conti_All_Season_Contact_2_215_55_R17_94V_TL_Fuel_Eff_%3A_B_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_70dB
Part Numbers - Exploded diagrams etc?
google "LLLPARTS CATALOG" to find this website that has the Skoda parts catalogues. Skoda parts catalogues https://www.lllparts.co.uk/catalogs You can also use these two links for the European version of the Octavia MK2 (model years 2004-2008) and the European version of the Octavia MK2 (model years 2009-2013). It's the same website as the above. Octavia MK2 (model years 2004- 2008) (European version) https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/419 Octavia MK2 (model years 2009-2013) (European version) https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/663
Spare wheel and accessories
The 18" spare wheel replacement kit with OEM part number 5E3093860B can't be used with the Octavia MK4 hybrid as shown in the link below. 18" Spare Wheel Replacement Kit 5E3093860B (for Octavia MK4) Limitations - it is not intended for cars equipped with the Škoda Sound system (subwoofer in the spare wheel). Not possible for cars with hybrid drive (Octavia iV) and CNG (G-TEC). https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola-18/p/5E3093860B
Kodiaq wheels on a enyaq
7Jx18 ET45 5/112 57.1 alloy rim TRINITY 57A071498 8Z8 (from Karoq) (12.9kg) https://eshop.skoda-auto.cz/cs_CZ/alu-kolo-trinity-18-karoq/p/57A071498++8Z8 Alcar 9383 8Jx18 ET45 5/112 57.1 steel rim (13.26kg) (from Enyaq) https://www.mytyres.co.uk/rims/details?vehicleId=1313955427855111280&rimCode=ALCAR9383 https://www.oponeo.pl/felga-stalowa/alcar-kfz-9393#24387288 Wheel trim for 8Jx18 ET45 5/112 57.1 steel rim (from Enyaq) 2 5LA601147 Wheel trim for steel rim 8Jx18 ET45 5/112 57.1 5LA601147 Z31 Bright chrome https://www.lllparts.co.uk/catalogs/skoda/CZ/ENY/1080/6/601/601010
Question about gemini rim
If the rim doesn't have the OEM part number cast into it somewhere (usually on the back) then it's a fake. It looks like the number you are looking for is something like 5E0601025AJ HA7, as shown in the chart below. Octavia MK3 parts catalogue 4 5E0601025AA Aluminium rim 7.5Jx18 ET51 C3S GEMINI 5E0601025AA 8Z8 Diamond silver 4 5E0601025AJ Aluminium rim 7.5Jx18 ET51 F18 GEMINI 5E0601025AJ HA7 Anthracite metallic (grey) 4 5E0601025AK Aluminium rim 7.5Jx18 ET51 CL3 GEMINI 5E0601025AK FL8 Black metallic https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/6/601/601080 Notice that the below alloy rim GEMINI isn't a factory rim because its OEM part number doesn't have the format xxx601xxx. Alloy rims with the format xxx071xxx are from the Skoda accessory catalogue, which are about 60% cheaper than from the usual parts catalogue with the xxx601xxx format. They are often the same alloy rim, except for the different OEM part number cast into the back. Skoda do this so that the alloy rims in their accessory catalogue can compete on price with aftermarket alloy rims. 7.5Jx18 ET51 alloy rim GEMINI 5E0071498E HA7 (as shown in the Skoda accessory catalogue) https://eshop.skoda-auto.cz/cs_CZ/alu-kolo-gemini-18-octavia-iii/p/5E0071498E+HA7 Photo of factory alloy rim showing the location of the OEM part number 5E0601025AJ
Converting Karoq SE-L with space saver spare wheel to full-size spare wheel
The quote, "Only for Karoq 4x4 with basic boot floor and standard rear seats" is from Skoda. Skoda don't sell the Karoq 4x4 kit for the Karoq 4x2 because it's not plug and play on that car. Hence, it only fits if you modify it such as using a longer wheel mounting bolt.
The mounting bolt supplied in the Karoq 4x4 kit is too short for use in the Karoq 2x4, if using a full-size spare wheel...so a longer mounting bolt is required.
The Karoq 2x4 uses the 57A093860B kit, not the 57A093860C kit which is for the Karoq 4x4...as shown below. However, it's possible to use the Karoq 4x4 kit in the Karoq 2x4's wheel well...but a longer mounting bolt will be required if using a full-size spare wheel. 57Q093860B (for Karoq 4x2) Only for Karoq 4x2 with basic boot floor and standard rear seats https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola-18/p/57A093860B 57A093860C (for Karoq 4x4) Only for Karoq 4x4 with basic boot floor and standard rear seats https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola-18/p/57A093860C Some bolts for mounting the spare wheel (some other length mounting bolts might be available with different OEM part numbers) 3G0803899E 99mm length mounting bolt https://www.skoda-parts.com/spare-part/3g0803899e-bolt-for-mounting-the-spare-wheel-skoda-29256.html 5Q0803899 127mm length mounting bolt https://www.skoda-parts.com/spare-part/5q0803899-bolt-for-mounting-the-spare-wheel-skoda-41620.html 3G0803899D 184mm length mounting bolt https://www.skoda-parts.com/spare-part/3g0803899d-bolt-for-mounting-the-spare-wheel-skoda-41621.html 3G0803899A 214mm length mounting bolt https://www.oemvwshop.com/3g0803899a-bolt-for-spare-wheel-mounting-p739422/
Wheels
There are plenty of alternative alloy rims in the Skoda accessory catalogue to choose from, such as the below 16" rim that would normally use 205/60R16 on the Octavia MK4. 6.5Jx16 ET46 5/112 57.1 alloy rim 5E0071496L 8Z8 https://eshop.skoda-auto.cz/cs_CZ/alu-kola/c/alloyWheels?q=%3AscoreDesc%3AcarType%3AOctavia%2BIV%2B%282019%2B%29%3ArimDiameter%3A16%22&text=#
Rim and Tyre Recommendation.
16" rims tend to weigh less than 17" rims. That should help reduce fuel consumption, but not by much. For comfort and economy, the 16" and 17" options on the Superb MK3 are far better than the 18" and 19" options. So perhaps concentrate on the availability and price of your favourite tyres to help choose between the 16" and 17" options. 6.5Jx16 ET41 5/112 57.1 steel rim (for Superb MK3) (8.47kg) https://www.oponeo.pl/felga-stalowa/alcar-kfz-8426#24360987 Set of four wheel trims for 6.5Jx16 ET41 5/112 57.1 steel rims 3V0071456 (for Superb MK3) https://eshop.skoda-auto.cz/cs_CZ/sada-poklic-hermes-16/p/3V0071456 6.5Jx16 ET41 5/112 57.1 alloy rim NYOTA (for Superb MK3) (9.9kg) https://eshop.skoda-auto.cz/cs_CZ/alu-kolo-nyota-16-superb-iii/p/3V0071496++8Z8 6.5Jx17 ET41 5/112 57.1 alloy rim TRITON (for Superb MK3) (11.7kg) https://eshop.skoda-auto.cz/cs_CZ/alu-kolo-triton-17-superb-iii/p/3V0071497++8Z8 Continental AllSeasonContact 2 215/55/17 94V (Euro label B B 70dB) https://www.camskill.co.uk/m140b0s8825p220589/Continental_Tyres_All_Season_Car_Continental_Conti_All_Season_Contact_2_215_55_R17_94V_TL_Fuel_Eff_%3A_B_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_70dB
Front Anti roll bar diameter (1.4tsi 150bhp)?
Autodoc are selling the 24mm bushes separately. 24mm ARB bushes https://www.autodoc.co.uk/febest/14133447
Tyre size question
245/40R18 needs at least an 8" rim width. 245/40R18 fitted to an 8Jx18 ET44 or 8Jx18 ET45 rim might fit the Octavia MK3...although there's always a risk of rubbing or the tyre sticking out of the wheelarch when pushing the limits. 245/40R18 has a slightly smaller outside diameter than the 17" Octavia MK3 Scout tyre, ie. 225/50R17...and has an actual inflated width of only 9mm more than this 17" tyre size, ie. 4.5mm more each side. 8Jx18 ET44 5/112 57.1 black metallic alloy rim VEGA 3V0071498P FL8 (from Superb MK3) (12.2kg) https://eshop.skoda-auto.cz/cs_CZ/alu-kolo-vega-18-superb-iii/p/3V0071498P+FL8
Tyre size question
The 19" Extreme rims are only 7.5" wide. According to ETRTO, 235/35R19, 235/40R19, 245/35R19, and 245/40R19 need at least an 8" rim width. According to ETRTO, 255/30R19 and 255/35R19 need at least an 8.5" rim width. However, some owners have fitted 235/35R19 and 235/40R19 tyres to their 7.5" width rims...although this is against ETRTO's rules. Skoda have never sold 19" rims for the Octavia MK3 that have a rim width of more than 7.5"...so 235/35R19 and 255/30R19 have never been approved by Skoda for fitment to this car...because Skoda along with all the other major car brands don't fit tyres to rim widths that aren't approved by ETRTO.
I doubt the 1.4 petrol 150HP would have 25mm bushes, that's likely to be reserved for the most powerful front wheel drive cars such as the 2.0 petrol 220HP. There are sellers on ebay who can supply the build codes for about 3.60 Euros (about £3.00). Skoda factory options https://www.ebay.it/itm/226420178252
From the Skoda Superb MK3 parts catalogue, it looks like most cars with build code 1X0 (front wheel drive) have OEM part number 3Q0411303 for the front anti-roll bar...which uses 24mm bushes. The exception for front wheel drive cars, is that if that car has build codes 1X0+TH8 then the OEM part number is 3Q0411303R for the front anti-roll bar...which uses 25mm bushes. Anti-roll bar bushes 24mm 3Q0411303 https://www.autodoc.co.uk/febest/14133447
Tyre specs 94h / 98V
This tyre won the 2024 allseason tyre review on tyrereviews. 2024 allseason tyre review (on tyrereviews) (Continental AllSeasonContact 2 won) https://www.tyrereviews.com/Article/Best-All-Season-Tyres-2024.htm Continental AllSeasonContact 2 215/55R17 94V (Euro label B B 70dB) https://www.camskill.co.uk/m140b0s8825p220589/Continental_Tyres_All_Season_Car_Continental_Conti_All_Season_Contact_2_215_55_R17_94V_TL_Fuel_Eff_%3A_B_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_70dB
Anyone running on CrossClimate 2 225/50R18 MICHELIN CROSSCLIMATE 2 SUV ?
Out of the 18" tyre sizes, the Karoq front wheel drive uses the 215/50R18 tyre size, whereas the Karoq 4x4 uses the bigger 225/50R18 tyre size. One of the owner's manuals lists 215/60R16 for use with snow chains but it doesn't make any mention of whether that's for just the Karoq front wheel drive or includes the Karoq 4x4. However, it's best to check the car's CoC (Certificate of Conformity) to see all the tyre sizes that Skoda approves for any particular car. Karoq front wheel drive tyre sizes 215/60R16 215/55R17 215/50R18 225/40R19 235/40R19 Karoq 4x4 tyre sizes 225/60R16 225/55R17 225/50R18 225/45R19 245/40R19
Octavia VRS MKIII - Tyre Size 225 or 235?
Unlike two wheel drive, powerful 4x4 cars don't need particularly wide tyres to get good traction off the line. The late model diesel Octavia MK3 VRS cars changed their front brake discs from 340x30mm (which need 17" rims to clear the front brake calipers) to 312x25mm (which need 16" rims to clear the front brake calipers). If you want high performance, choose the right tyre for the conditions. Perhaps Continental PremiumContact 7 for the summer, Continental AllSeasonContact 2 for a mild winter, or Continental WinterContactTS870 for a very cold/snowy winter. A high performance summer tyre becomes a low performance winter tyre when the temperature drops much below 7 degrees Centrigrade. Unsprung weight can have a big effect on the handling of a car, especially when the road is bumpy. To give you an idea of the potential weight savings of using smaller diameter rims, see the below chart. Figures are only approximate because each rim model will be slightly different. Approximate weight of alloy rims for Octavia MK3 16" rims 9kg 17" rims 11kg 18" rims 13kg 19" rims 15kg Steel rims often weigh less than alloy rims of the same specification. For example, the following steel rims all weigh about 7.6kg. 16" steel rims that weigh about 7.6kg 6Jx16 ET43 5/112 57.1 (from Karoq) 6Jx16 ET48 5/112 57.1 (from Octavia MK3) 6.5Jx16 ET43 5/112 57.1 (from Audi A3) 6.5Jx16 ET46 5/112 57.1 (from Octavia MK3)
Tyre size question
zhz on the other thread, fitted his 245/45R18 to 7.5J rims. According to ETRTO, 245/40R19 need to be fitted to at least an 8" rim width, so will be at least 5mm wider than 245/45R18 fitted to 7.5J rims...as shown in the chart below. Actual inflated width of tyres (measured from sidewall to sidewall, at the widest point) 225/50R17 fitted to 7Jx17 rims 233mm 245/45R18 fitted to 7.5Jx18 rims 237mm 245/40R19 fitted to 8Jx19 rims 242mm 245/40R19 fitted to 8.5Jx19 rims 248mm zhz's thread
Alloy wheel size change?
Your 6Jx15 ET38 5/100 57.1 MATO alloy rims with OEM part number 6V0071495 8Z8 are not original because the xxx071xxx format of the OEM part number means they are from the Skoda accessory catalogue. These MATO alloy rim are still available to purchase from the Skoda accessory catalogue and the Czech price is about £120, although expect UK VAG dealers to charge a little more. One of the standard wheel sizes on the Fabia MK3 is 215/45R16 7Jx16 ET46, so 195/55R15 6Jx15 ET43 isn't going to rub. Although the ET43 offset moves the centre of the tyre 5mm further into the wheelarch, because the 195/55R15 tyre size has a "nominal" 10mm increase in width they should fill the wheelarches a similar amount to the standard 15" wheel size, ie. 185/60R15 6Jx15 ET38...so should look sunken in the wheelarch. You can see in the chart below, that the 195/55R15 tyre size has a slightly smaller outside diameter than the standard Fabia MK3 tyre size. As a general guide, less than a 1.5% difference isn't much. However, when fitting non-standard tyre sizes it's more common to go slightly bigger rather than slightly smaller. For maximum protection from kerbing damage on the 6Jx15 ET43 rim, 205/55R15 could be used. Outside diameter of tyres 175/70R14 600.6mm 185/60R15 603mm 215/45R16 599.9mm 215/40R17 603.8mm 195/55R15 595.5mm (between 0.7% and 1.4% smaller outside diameter compared to the standard Fabia MK3 tyre sizes) 195/60R15 615mm (between 1.9% and 2.5% bigger outside diameter compared to the standard Fabia MK3 tyre sizes) 205/55R15 606.5mm (between 0.4% and 1.1% bigger outside diameter compared to the standard Fabia MK3 tyre sizes) 6Jx15 ET38 5/100 57.1 MATO alloy rim 6V0071495 8Z8 https://eshop.skoda-auto.cz/cs_CZ/alu-kolo-mato-15-rapid-fabia-iii/p/6V0071495++8Z8 Falken Ziex ZE310 205/55R15 88V (Euro label C A 67dB) (summer tyre) https://www.camskill.co.uk/m53b0s289p208326/Falken_Tyres_Car_Falken_Ziex_ZE310_Ecorun_205_55_R15_88V_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_A_NoiseClass%3A_A_Noise%3A_67dB Falken Eurowinter HS02 205/55R15 88H (Euro label D B 69dB) (winter tyre) https://www.mytyres.co.uk/rshop/tyre/Falken/EUROWINTER-HS02/205-55-R15-88H-BLK/D-134927 As you can see in the ETRTO chart below, a 205/55R15 can be fitted to a rim width between 5.5" and 7.5" with car manufacturers usually choosing between 6" and 7", ie. avoided the two extremes of 5.5" and 7.5" rim widths. 6.5 is highlighted in the chart below because that is the standard rim width for a 205/55R15 tyre size, ie. if you can't decide what rim width to fit a 205/55R15 tyre to, then a 6.5" rim width is a good place to start. ETRTO approved rim widths for passenger car tyres 205/55R15 5.5-6.5-7.5 A non-standard 205/55R15 6Jx15 wheel size is a much more comfortable wheel size than the standard 215/45R16 7Jx16. Not only does the 205/55R15 have a higher standard load index than 215/45R16, ie. 88 (560kg) versus 86 (530kg)...but it is narrower and has a higher sidewall height...plus in this example it is fitted to a relatively narrower 6" rim width...which all adds up to a much more comfortable wheel size. To get the 205/55R15 6Jx15 wheel size to feel as hard riding as a 215/45R16 7Jx16 you would probably have to over-inflate it by at least 8psi. Considering it's easy to feel a 3psi difference in tyre pressure, an 8psi difference is a big one.
What size wheels/tyres will fit to Superb III
As you can see in the chart below, the 245/35R21 tyre size has an outside diameter between 5.1% and 6.1% bigger than the standard tyre sizes. If you want a 9" rim width, perhaps look at something like 255/30R21 fitted to a 9Jx21 ET42...although that might rub on the inside. Fitting this tyre size to a narrower 8.5Jx21 ET40 rim would free up an extra 5mm on the inside reducing the chance of rubbing on the inside. You get an extra 2mm on inside clearance because of the different offset, ie. ET40 instead of ET42...and an extra 3mm of inside clearance because of the 0.5" narrower rim, which squeezes the sidewalls together more. Note that there's always a risk of rubbing or the tyre sticking too far out when you start pushing the limits, and it's possible that even a 255/30R21 fitted to a 8.5Jx21 ET40 rim could rub or stick out from the wheelarch. Outside diameter of tyres 215/60R16 664.4mm 235/40R19 670.6mm 245/35R21 704.9mm (5.1% to 6.1% bigger outside diameter compared to the standard tyre sizes) 255/30R21 686.4mm (2.4% to 3.3% bigger outside diameter compared to the standard tyre sizes) ETRTO approved rim widths for passenger car tyres 35 Series 235/35R21 8.0-8.5-9.5 245/35R21 8.0-8.5-9.5 255/35R21 8.5-9.0-10.0 30 Series 245/30R21 8.0-8.5-9.0 255/30R21 8.5-9.0-9.5 Michelin Pilot Sport 4S 255/30R21 93Y XL (Euro label D A 71dB) https://www.camskill.co.uk/m74b0s1134p156359/Michelin_Tyres_Car_Michelin_Pilot_Sport_4S_PS4S_255_30_R21_(93Y)_XL_TL_Fuel_Eff_%3A_D_Wet_Grip%3A_A_NoiseClass%3A_B_Noise%3A_71dB The below VISION alloy rims from the Skoda Enyaq are claimed to weigh 15.3kg each, which isn't much more than some of the standard 19" alloy rims on the Superb MK3. 8.5Jx21 ET40 5/112 57.1 alloy rims VISION (from Skoda Enyaq) (15.3kg each) Black metallic 5LG071491K FL8 Black metallic and red 5LG071491P CZX Black metallic and green 5LG071491AK FJI Silver metallic 5LG071491M 8Z8 https://eshop.skoda-auto.cz/cs_CZ/alu-kola/c/alloyWheels?q=%3AscoreDesc%3AcarType%3AEnyaq%2B%282020%2B%29%3ArimDiameter%3A21%22&text=# As you can see in the chart below, a 255/30R21 tyre fitted to an 8.5J rim is 18mm wider than the standard 235/45R18 tyre fitted to an 8J rim, ie. 9mm more each side. As an ET40 offset moves the centre of the tyre 4mm outward compared to an ET44 offset, the tyre is very unlikely to rub on the inside...except that extra consideration needs to be given to the clearance on the front when the steering wheel is turned to full lock...because of the extra outside diameter of the 255/30R21 sized tyre compared to the standard 235/40R19 sized tyre. However, the extra radius of the 255/30R21 tyre compared to the 235/40R19 tyre is only 7.9mm...so I doubt the 255/30R21 tyre fitted to a 8.5Jx21 ET40 rim would rub on the inside. Considering some owners have fitted 15mm spacers to their 235/40R19 tyres on standard 8Jx19 ET44 rims...I doubt 255/30R21 tyres fitted to 8.5Jx21 ET40 rims would rub on the outside either because the extra outside clearance needed is only 13mm, and the owners who have fitted 15mm spacers have proved that their is at least an extra 15mm of clearance on the outside. Actual inflated width of tyres (measured from outside of sidewall to sidewall, at the widest point) 235/45R18 fitted to 8.0J rim 236mm 255/30R21 fitted to 8.5J rim 254mm
Plastic covers for steel rims
Wheel trims for 6.5Jx16 ET41 steel rims (for Superb MK3) https://eshop.skoda-auto.cz/cs_CZ/sada-poklic-hermes-16/p/3V0071456
battery fit
I recently purchased a new car battery (Varta) from a big ebay seller. However, it wasn't shipped from them but from Tayna...which just goes to show how big Tayna is. It might be the biggest supplier of car batteries in the UK. The packaging was excellent as it was purpose made to ship car batteries, and because Tayna sell so many car batteries they are likely to supply a recently manufactured car battery rather than one that has been sitting around for months. Their prices are competitive too. Tayna car batteries https://www.tayna.co.uk/?gad_source=1&gclid=EAIaIQobChMI-Mz1o9PXiQMVnpJQBh0tyDr1EAAYBCAAEgIjUvD_BwE Here's a chart on common sizes of Varta car batteries. Most Skodas have either size 2, size 3, or size 4. They all have the same width of 175mm, and the same height of 190mm...so it's just the length that varies...which makes it easy to identify the size required. SLA (Sealed Lead Acid) batteries are for cars that don't have stop-start. AGM batteries are for cars that have stop-start. Varta car batteries Size 1 175x190x207mm WxHxL Varta Silver Dynamic SLA 54Ah 530A Short Code:C30 UK Code:012 Weight:12.38kg Varta Silver Dynamic AGM 50Ah 540A Short Code:A9 UK Code:012AGM Weight: 15kg Size 2 175x190x242mm WxHxL Varta Silver Dynamic SLA 63Ah 610A Short Code:D15 UK Code:027 Weight:14.78kg Varta Silver Dynamic AGM 60Ah 680A Short Code:A8 UK Code:027AGM Weight:17.5kg Size 3 175x190x278mm WxHxL Varta Silver Dynamic SLA 77Ah 780A Short Code:E44 UK Code:096 Weight:17.94kg Varta Silver Dynamic AGM 70Ah 760A Short Code:A7 UK Code:096AGM Weight:20.4kg Size 4 175x190x315mm WxHxL Varta Silver Dynamic SLA 85Ah 800A Short Code:F19 UK Code:115 Weight:19.76kg Varta Silver Dynamic AGM 80Ah 800A Short Code:A6 UK Code:115AGM Weight:22.76kg Size 5 175x190x353mm WxHxL Varta Silver Dynamic SLA 100Ah 830A Short Code:H3 UK Code:019 Weight:21.92kg Varta Silver Dynamic AGM 95Ah 850A Short Code:A5 UK Code:019AGM Weight:26.4kg Size 6 175x190x393mm WxHxL Varta Silver Dynamic SLA 110Ah 920A Short Code:I1 UK Code:020 Weight:24.48kg Varta Silver Dynamic AGM 105Ah 950A Short Code:A4 UK Code:020AGM Weight:29.4kg Some prices from Tayna...and these are for Varta's best SLA model which they call Silver Dynamic... Varta Size 2 SLA (Short code: D15) £73.26 + £7.99 shipping https://www.tayna.co.uk/car-batteries/varta/d15/ Varta Size 3 SLA (Short code: E44) £89.71 + £7.99 shipping https://www.tayna.co.uk/car-batteries/varta/e44/ Varta Size 4 SLA (Short code: F19) £104.34 + £7.99 shipping https://www.tayna.co.uk/car-batteries/varta/f19/
Replacing 16" wheels with 15"
The 215/45R16 tyres on the Fabia MK3 use a 7Jx16 ET46 rim specification. Fitting 195/55R16 tyres to wide 7J rims will make the ride noticeably harder compared to fitting the 195/55R16 tyres to narrower 6J rims, such as 6Jx16 ET35 or 6Jx16 ET40. Using narrower 195/55R16 tyres on the 215/45R16 rims (ie. 7Jx16 ET46) will make the tyres look sunken into the wheelarch. The Rapid that is sold outside Europe fitted its 195/55R16 tyres to 6Jx16 ET40 rims. Bear in mind, that the 15" wheels on this Rapid use the same 185/60R15 tyres that the Fabia MK3 uses...so it is only the 16" wheel size that is different from the Fabia MK3, ie. the two cars aren't that dissimilar. Another problem with fitting 195/55R16 tyres to relatively 7J rims is that they don't provide much rim protection from kerbing damage because the sidewalls are stretched rather than bulging out. The below chart helps to explain this lack of protection from kerbing damage when fitting a 195/55R16 tyre size to a 7J rim. As you can see in the chart below, the 195/55R16 tyre size bulges out from the narrower 6J rim more than twice as much compared to fitting it to the wider 7J rim, ie. 12.3mm versus 5.6mm. Amount 195/55R16 tyre bulges out each side from rim 195/55R16 fitted to 6J rim width 12.3mm 195/55R16 fitted to 7J rim width 5.6mm As you can see in the ETRTO chart below, the 195/55R16 tyre size can be fitted to a rim width between 5.5" and 7"...with 6" being the standard rim width for this tyre size, and hence highlighted in bold. ETRTO approved rim widths for passenger car tyres 175/70R14 4.5-5.0-6.0 185/60R15 5.0-5.5-6.5 195/55R16 5.5-6.0-7.0 215/45R16 7.0-7.0-8.0
