Carlston
Everything posted by Carlston
  1. As 3Q0512011HD, 3Q0513049FN, 3Q0513049FP isn't listed against Monroe 376195SP, I would have have gone for Sachs 318202 as that is listed against all three of these OEM part numbers. 3Q0513049FN and 3Q0513049FP are listed as standard rear shock absorbers for the standard ride height, front wheel drive, Superb MK3 without DCC. Rear shock absorbers for the Superb MK3, standard ride height, front wheel drive, without DCC (7) 3Q0513049FN Rear shock absorber 1JA (7) 3Q0513049FP Rear shock absorber 1JA https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/5
  2. 6R0411105AK is a front spring for the Fabia MK2 VRS. That car uses a 1.4 petrol engine which weighs a lot less than a 1.9 diesel engine, so 6R0411105AK won't be suitable for the Fabia MK2 1.9TDI. 6Q0411105BF is the lowered ride height front spring used by the Fabia MK1 VRS, so that spring should be suitable for a lowered ride height Fabia MK2 1.9TDI. The Fabia MK1 VRS and Fabia MK2 VRS both use the same 6Q0511115AA lowered ride height rear springs. So that rear spring is a good choice for a lowered ride height Fabia MK2 1.9TDI. The Fabia MK1 and Fabia MK2 are based on the Polo MK4. The Fabia MK3 is based on the Polo MK5. Lowered ride height front spring (from Fabia MK1 VRS) 6Q0411105BF https://www.autodoc.co.uk/car-parts/oem/6q0411105bf Lowered ride height rear spring (from Fabia MK1 VRS and Fabia MK2 VRS) 6Q0511115AA https://www.autodoc.co.uk/car-parts/oem/6q0511115aa?search=OEN 6Q0511115AA Bilstein B4 22-196309 front shock absorber for lowered ride height https://www.autodoc.co.uk/bilstein/632782 Bilstein B4 19-196312 rear shock absorber for lowered ride height https://www.autodoc.co.uk/bilstein/633947
  3. Top mounts can come with or without the bearings. Here's a photo of a twin pack with the bearings. SKF VKDA 35122 T Top strut mount with bearing(s) https://www.autodoc.co.uk/skf/1363452
  4. The Octavia MK2 VRS uses 312x25mm front brakes discs, so 16" rims will clear the front brakes calipers. Octavia MK2 16" rim specification (use with 205/55R16 tyre) 6.5Jx16 ET50 5/112 57.1 Alcar 9915 6.5Jx16 ET50 5/112 57.1 steel rim (actual photo of rim) https://www.oponeo.pl/felga-stalowa/alcar-kfz-9915#22789063 https://www.mytyres.co.uk/rims/details?vehicleId=183006013861926000&rimCode=ALCAR9915
  5. I've seen two different OEM part numbers for the foam and jack kit for the Octavia MK3 VRS, and these are 5E0093860C and 5E0093860F. Perhaps take these two OEM part numbers along to a VAG parts department, and ask them what the difference is. They might not know. Although they might both be suitable. The 5E0093860F might simply be an updated version of 5E0093860C, but you would need to check. You won't be able to use a front spare wheel smaller than 17" diameter because 16" rims won't clear the front brake calipers on the big 340x30mm front brake discs. When you get the foam and jack kit, try one of your normal wheels in the spare wheel well to see if it fits with the carpet flush. If it doesn't, you need a spare wheel that isn't so wide. If you do need a narrower tyre than 225, you could use a 205/50R17 fitted to a 6.5Jx17 ET38 5/112 57.1 steel rim from the Kodiaq. This rim specification is available from mytyres Foam and jack kit (includes everything except the spare wheel) 5E0093860C 5E0093860F https://eshop.skoda-auto.cz/cs_CZ/sady-pro-vymenu-kol/c/setsToChangeWheels?q=%3AscoreDesc%3AcarType%3AOctavia%2BIII%2B%282017%2B%29&text=# Alcar 9021 6.5Jx17 ET38 5/112 57.1 steel rim (from Kodiaq) (205/50R17) https://www.mytyres.co.uk/rims/details?vehicleId=672860434273997936&rimCode=ALCAR9021 Another spare wheel option is a 7.5Jx18 ET50 5/112 57.1 steel rim from a VW iD.3. Alcar 9373 7.5Jx18 ET50 5/112 57.1 steel rim (from VW iD.3) (225/40R18) https://www.mytyres.co.uk/rims/details?vehicleId=1258516952071017584&rimCode=ALCAR9373
  6. The Skoda accessory catalogue list many alloy rims for the Kodiaq with the correct specification, eg. diameter, width, offset. They are often identical to the factory rims except for the OEM part number. They are not a modification because they conform to the car's Certificate of Conformity, ie. they are all Skoda approved. Skoda alloy rim accessory catalogue https://www.skoda.co.uk/_doc/639a0118-4da5-446b-a786-86e1f789b57b The "skoda eshop cz" website lists most of the alloy rims (with photos) that are in the Skoda alloy rims accessory catalogue. https://eshop.skoda-auto.cz/alu-kola/c/alloyWheels?q=%3ApriceAsc%3AcarType%3AKodiaq%2B%282016%2B%29&text=# Skoda approved rim specifications for the Kodiaq 6.5Jx17 ET38 5/112 57.1 7Jx17 ET40 5/112 57.1 7Jx18 ET43 5/112 57.1 7Jx19 ET43 5/112 57.1 8Jx20 ET41 5/112 57.1 8.5Jx20 ET38 5/112 57.1 If in doubt, check what tyre and rim combinations are shown on the Certificate of Conformity. The 6.5Jx17 ET38 5/112 57.1 specification is available as a steel rim. Alcar 9021 6.5Jx17 ET38 5/112 57.1 steel rim https://www.mytyres.co.uk/rims/details?vehicleId=639488607098401904&rimCode=ALCAR9021
  7. It's an average figure for Australia. Global petrol prices https://www.globalpetrolprices.com/Australia/gasoline_prices/
  8. 6Q0511115AA Rear coil spring 0YC 1 orange paint mark 1 blue paint mark 2 white paint marks https://www.lllparts.co.uk/catalogs/skoda/CZ/FAB/697/5/511/511020
  9. In Australia, petrol is 87p/litre. In the UK, it's £1.44/litre.
  10. 3 green dots and 2 brown dots is 6R0411105AK, not 6Q0411105AE. 6R0411105AK Front coil spring L63 3 green paint marks 2 brown paint marks https://www.lllparts.co.uk/catalogs/skoda/CZ/FAB/697/4/411/411030
  11. There should be a weight plate fixed to the B-pillar that you should be able to see when the driver's door is open. Take a photo of that to see the maximum axle weights, as it's easier to see the details on a computer screen. If you've got 235/45R20 tyres, 2.2Bar (32psi) in all four tyres can support over 2,000kg. Pumping them up to 2.7Bar (39psi) front and 3.2(46psi) rear can support over 2,600kg, (ie. over 1,200kg on the front axle, and over 1,400kg on the rear axle). If you're not carrying much weight in the back perhaps try 35psi front and 32psi rear. This can support over 1,000kg on the front axle and about 1,100kg on the rear axle, for a total weight of over 2,100kg. Excessive tyre pressures is sometimes used to improve handling. However, I expect this is more to do with driving flat out around a smooth racetrack, and not day to day driving on the UK's bumpy and potholed filled roads.
  12. The Octavia MK3 uses XTREME 7.5Jx19 ET51 5/112 57.1 alloy rims. The Octavia MK4 doesn't use EXTREME alloy rims because the offset is not correct. The Octavia MK4 uses 7.5Jx19 ET48 5/112 57.1 rims. Also note that the Octavia MK4 uses bigger outside diameter 225/40R19 rather than the 225/35R19 on the Octavia MK3. The Octavia MK2 uses 18" rims with a specification of 7.5Jx18 ET51 5/112 57.1, so you could use the 7.5Jx19 ET51 5/112 57.1 EXTREME rims on the Octavia MK2. Bear in mind, that the very low sidewall height of the 235/35R19 tyre size makes the tyres and rims very susceptible to pothole damage. Perhaps look at non-standard 235/40R18 tyres fitted to 7.5Jx18 ET51 5/112 57.1 alloy rims from the Octavia MK3. Compared to the 225/35R19 tyre size, the 235/40R18 doesn't just add 10mm to the tyre width but a massive 20% to the sidewall height. So when you hit a pothole, the tyre will provide a lot more cushioning and resistance to pothole damage. Another thing to bear in mind is protection from kerbing damage. The sidewalls on a 235/40R18 fitted to a 7.5J rim will bulge out a similar amount to a 225/45R17 fitted to a 7J rim, and will therefore provide a similar level of protection from kerbing damage. 7.5Jx18 ET51 5/112 57.1 alloy rim https://eshop.skoda-auto.cz/cs_CZ/alu-kolo-gemini-18-octavia-iii/p/5E0071498G+FL8 ETRTO recommended rim widths 225/35 7.5-8.0-9.0 235/40 x.x-x.x-x.x (7.5-8.0-9.0 would be logical but ETRTO's 8.0-8.5-9.5 recommendation is not logical) 245/45 7.5-8.0-9.0 As you can see in the chart below, these two tyre sizes have a similar outside diameter. When the 235/40R18 tyre size has just 2.55mm of tread wear, it will have exactly the same outside diameter as a new 225/35R19. Outside diameter of tyres 225/35R19 640.1mm 235/40R18 645.2mm (+0.8% larger compared to 225/35R19) Continental AllSeasonContact 235/40R18 95V XL https://www.camskill.co.uk/m141b0s10013p152848/Continental_Tyres_All_Season_Car_Continental_ContiAllSeasonContact_Continental_Conti_All_Season_Contact_235_40_R18_95V_XL_FR_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_72dB
  13. 215/50R17 is a massive 7.3% bigger than the standard 185/60R15 tyre size. I would be surprised it that size didn't rub on full lock, or when the suspension fully compresses. More than about a 1.5% to 2% increase in outside diameter compared to the standard tyre sizes, can start to make the car feel too highly geared. It's rare for the speedo to not over-read when using more than a 5% increase in outside diameter. Often the speedo will start to over-read with a smaller increase than 5%. 17" tyres tend to be a lot more expensive than 15" tyres. For excellent comfort and a cheap tyre size, perhaps look at 185/65R15 or even 195/60R15. With the standard 6Jx15 ET38 5/100 57.1 rims 195/60R15 would probably be my choice as it's a good fit on the 6J rim width, and only increases the gearing by 2.0% compared to the standard 185/60R15 tyre size. There's a good choice of secondhand alloy rims with the standard 6Jx15 ET38 5/100 57.1 rim size, because the Golf MK4 and the various clones used this size around the years 1998-2003. However, the Golf MK4 used a bigger outside diameter 195/65R15 tyre size. Outside diameter of tyres 185/60R15 603mm 185/65R15 621.5mm (+3.1% compared to 185/60R15) 195/60R15 615mm (+2.0% compared to 185/60R15) 195/50R16 601.4mm 195/55R16 620.9mm (+3.0% compared to 185/60R15) 205/45R17 616.3mm (+2.2% compared to 185/60R15) 215/40R17 603.8mm 215/50R17 646.8mm (+7.3% compared to 185/60R15) Examples of 185/65R15 and 195/60R15 all-season tyres, which could be fitted to the standard 6Jx15 ET38 rim size. Notice how much cheaper they are than the 17" tyre sizes. Vredestein Quatrac 6 185/65R15 88H (£57.05+shipping) https://www.camskill.co.uk/m138b0s7990p202115/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_185_65_R15_88H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_70dB Vredestrein Quatrac 6 195/60R15 88H (£62.90+shipping) https://www.camskill.co.uk/m138b0s7993p202144/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_195_60_R15_88H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_70dB Examples of 195/50R16 and 195/55R16 all-season tyres, which could be fitted to a 6Jx16 ET35 5/100 57.1 rim from the Scala/Kamiq. Vredestein Quatrac 6 195/50R16 88V XL (£87.60+shipping) https://www.camskill.co.uk/m139b0s8824p202112/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_195_50_R16_88V_XL_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_70dB Vredestein Quatrac 6 195/55R16 87H (£79.55+shipping) https://www.camskill.co.uk/m139b0s7952p202114/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_195_55_R16_87H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_70dB Examples of 205/45R17 and 215/40R17 all-season tyres. Continental AllSeasonContact 205/45R17 88V XL (£116.80+shipping) https://www.camskill.co.uk/m140b0s7953p165266/Continental_Tyres_All_Season_Car_Continental_ContiAllSeasonContact_Continental_Conti_All_Season_Contact_205_45_R17_88V_XL_FR_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_72dB Continental AllSeasonContact 215/40R17 87V XL (£130.20+shipping) https://www.camskill.co.uk/m140b0s8783p188385/Continental_Tyres_All_Season_Car_Continental_ContiAllSeasonContact_Continental_Conti_All_Season_Contact_215_40_R17_87V_XL_FR_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_72dB Alcar 6664 6Jx16 ET35 5/100 57.1 steel rim (from Scala/Kamiq) (actual photo of rim, ie. not generic) https://www.mytyres.co.uk/rims/details?vehicleId=1206402849694839908&rimCode=ALCAR6664 Wheel trim for 6Jx16 ET35 5/100 57.1 steel rim (from Scala/Kamiq) (about £49 for a set of four) https://eshop.skoda-auto.cz/cs_CZ/poklice-lhoste-16/p/658071456A 6Jx16 ET35 5/100 57.1 alloy rim (from Scala/Kamiq) (about £149 each) https://eshop.skoda-auto.cz/cs_CZ/alu-kolo-nanuq-16-scala-kamiq/p/654071496B+8Z8
  14. Your 205/40R17 tyre size is too small for the Rapid and Fabia MK2. The standard 215/40R17 would have provided a little more rim protection from potholes and kerbing damage. 5J0601025T is a Fabia MK2 rim with a 7Jx17 ET41 specification. The Rapid uses a 7Jx17 ET46 rim, which is the same as the Fabia MK3 uses. The Rapid and Fabia MK3 use a 215/40R17, whereas the Fabia MK2 uses a 205/40R17. 7Jx17 ET46 5/100 57.1 alloy rim (for Rapid and Fabia MK3) (uses 215/40R17) https://eshop.skoda-auto.cz/cs_CZ/alu-kolo-torino-17-fabia-iii-rapid/p/5JA071497AAJX2 Maybe consider 205/45R17 fitted to a 6.5Jx17 ET40 rim from the Scala/Kamiq as that would provide a little more rim protection from potholes than 215/40R17 due to the slightly higher sidewalls.
  15. It's a TRW front brake system, so perhaps try using TRW brake pads. TRW would have done a lot of R&D as it's their brake system, so should work perfectly. TRW GDB2114
  16. 340x30mm ventilated front discs and 310x22mm ventilated rear discs are used on the Superb MK3 272PS/280PS. 312x25mm ventilated front discs and 300x12mm solid rear discs are used on the Superb MK3 220PS. According to Brembo, the discs weigh as follows. So the 272PS/280PS models use discs that are a lot more substantial than the discs on the still quite quick 220PS model. Weight of each front disc 340x30mm 10.8kg (+25.6%) 312x25mm 8.6kg Weight of each rear disc 310x22mm 6.8kg (+33.3%) 300x12mm 5.1kg Brembo diagram showing 10.8kg weight for 340x30mm ventilated front disc Brembo diagram showing 8.6kg weight for 312x25mm ventilated rear disc Brembo diagram showing 6.8kg weight for 310x22mm ventilated rear disc Brembo diagram showing 5.1kg weight for 300x12mm solid rear disc
  17. SKF is top quality and £45 is not expensive. It's easy to fit because the wheel bearing has already been pressed into the hub by the manufacturer. It's a very common part as it's used in a huge number of VAG cars not just the Rapid. SKF front wheel bearing kit 6R0407621A https://www.autodoc.co.uk/skf/1362679
  18. You should be able to order the correct spare wheel kit that includes everything you need except the actual spare wheel, eg. foam, jack, etc. Just give the VAG parts department the OEM part number which is 5E0093860E The dealer should be able to confirm that this OEM part number is correct. For the spare wheel, you could purchase either a 6Jx15 ET43 5/112 57.1 steel rim or a 6.5Jx16 ET46 5/112 57.1 steel rim, with either a 195/65R15 or 205/55R16 tyre. If you're currently on 15" wheels, then a 15" spare wheel makes sense. If you're on 16" or larger wheels, then a 16" spare wheel makes sense. However, you could use a 15" spare wheel with 16" or larger wheels. When fitting a spare wheel that is smaller than the wheels on the car, just treat it like a space saver spare wheel and don't exceed 50mph. One advantage to using a 15" spare wheel instead of a 16" spare wheel, is that it weighs a little less. Foam and jack spare wheel kit 5E0093860E https://eshop.skoda-auto.cz/sady-pro-vymenu-kol/c/setsToChangeWheels?q=%3ApriceAsc%3AcarType%3AOctavia%2BIII%2B%282017%2B%29&text=# Alcar 7755 6Jx15 ET43 5/112 57.1 steel rim (from Octavia MK3) https://www.mytyres.co.uk/rims/details?vehicleId=502374009556452464&rimCode=ALCAR7755 Alcar 8667 6.5Jx16 ET46 5/112 57.1 steel rim (from Octavia MK3) https://www.mytyres.co.uk/rims/details?vehicleId=502374009556452464&rimCode=ALCAR8667
  19. The 205/55R16 from the Superb MK2 is probably fitted to a 7Jx16 ET45 rim, as this is the usual rim size for the Superb MK2. If it is the 7Jx16 ET45 rim size, the actual width of the 205/55R16 tyre will be about 220mm. This is about 5mm too wide to fit in the spare wheel well without lifting the carpet. So it might be best to purchase another steel rim, such as a 6Jx16 ET43 5/112 57.1 steel rim from the Karoq. This will allow you to fit the correct 215/60R16 tyre size for the Superb MK3, and then it will fit flush in the spare wheel well. The reason for the 6Jx16 ET43 Karoq rim, is because if you use the 6.5Jx16 ET41 rim from the Superb MK3, the spare wheel won't fit flush in the spare wheel well. This is because the actual width of a 215/60R16 tyre fitted to a 6.5Jx16 rim is about 221mm, which will raise the carpet.
  20. None of the tyres in that review are suitable for track days. Within one or two laps they would overheat, including the test winning Goodyear EfficientGrip Performance 2. Most owners don't take their Yeti around a race track.
  21. This website claims that they ship to Switzerland. However, I know nothing about them so you would need to do your own research to make sure that it's a reputable firm. Or look elsewhere. I prefer ebay/amazon, etc. as it's easy to get a refund if the goods don't turn up. Switzerland FedEx < 10kg 508 CZK FedEx < 20kg 653 CZK FedEx < 30kg 1,029 CZK https://www.skoda-dily.cz/nahradni-dil/3v0071497bfl8-hlinikovy-disk-17-triton-skoda-41373.html
  22. The Debica Presto UHP2 was tested in the following tyre review, and didn't come anywhere near the winning Goodyear EfficientGrip Performance 2. The Goodyear lasted 51,340 miles, whereas the Debica only lasted 30,600 miles. However, it's best to use all-season tyres in the UK if you use the same tyres all year round. 2022 Auto Bild Summer Tyre Test https://www.tyrereviews.com/Article/2022-Auto-Bild-Summer-Tyre-Test.htm
  23. There's an Italian seller listing five new 3V0601025A 8Z8 Triton 6.5Jx17 ET41 rims on ebay who will ship to Switzerland. https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p4432023.m570.l1313&_nkw=3V0601025A+8Z8&_sacat=0https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p4432023.m570.l1313&_nkw=3V0601025A+8Z8&_sacat=0 What are the OEM part numbers for the alloy rims? This will tell you if they are from the accessory parts catalogue or the much more expensive factory part numbers. From the accessories catalogue the Triton rims should be about 225 CHF each not 365 CHF, ie. almost 40% less. Skoda alloy rim accessories catalogue https://www.skoda.co.uk/_doc/639a0118-4da5-446b-a786-86e1f789b57b TRITON 6.5Jx17 ET41 5/112 57.1 alloy rim 3V0071497B FL8 black 3V0071497 8Z8 silver "skoda eshop cz" also shows the cheaper accessory part numbers, ie. 3V0071xxx format https://eshop.skoda-auto.cz/ Expensive factory part numbers are listed here, ie. 3V0601xxx format https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/6/601/601070
  24. Here's three standard ride height rear springs for the Octavia MK3 1.8TSI 4x4 estate (and other models). The 4x4 uses multilink rear suspension so these rear springs should also fit the VRS models as that also uses multilink rear suspension. These should raise the rear end by about 25mm compared to the lowered ride height rear springs such as the 5Q0511115S. Bear in mind that the 4x4 estate would normally use rear springs about two weight ranges higher than the front wheel drive estate, because of the extra rear weight caused by the four wheel drive system. gknautomotive lists 5Q0511115H as being suitable for the 4x4 estate without a towbar, and the 5Q0511115J as being suitable for the 4x4 estate with a towbar. 5Q0511115G has an 11.75mm wire diameter so should have a similar stiffness to 5Q0511115S, ie. one weight range higher than your standard 5Q0511115R. So a 5Q0511115G should be suitable for a front wheel drive car with towbar. Sachs 994999 matches 5Q0511115G https://www.autodoc.co.uk/sachs/15244190 Sachs 992100 matches 5Q0511115H https://www.autodoc.co.uk/sachs/15244135 Sachs 992101 matches 5Q0511115J https://www.autodoc.co.uk/sachs/15244136
  25. Your rear ride height looks lower than Swirly's car fitted with the same Eibach R19953 rear springs matching OEM part number 5Q051115S. Swirly182's car with 5Q0511115S rear springs Autodoc lists three springs matching 5Q0511115AA. Bilstein 36-301904, Kilen 63145, Lesjofors 4285746. They are all probably the same spring, just sold under different brands. Unfortunately, none of them lists the specification such as length and wire diameter. However, in the Skoda parts catalogue they are shown as two weight ranges higher than 5Q0511115S. 5Q0511115AA https://www.autodoc.co.uk/car-parts/oem/5q0511115aa?search=OEN 5Q0511115AA Did the mechanic check the condition of the upper and lower underlays for the rear springs? If they are worn, that can cause a loss of rear ride height. Upper underlay for rear spring 5Q0512149A https://www.autodoc.co.uk/topran/16203018 Lower underlay for rear spring 5Q0512297D https://www.autodoc.co.uk/topran/16203019 Your front ride height looks too high. Has someone fitted standard ride height front springs? If so, you might be better off fitting standard ride height rear springs, rather than 5Q0511115AA rear springs. As 5Q0511115S rear springs hasn't raised the rear end much, 5Q0511115AA might not raise it much either. Although 5Q0511115AA will be about 10% stiffer than 5Q0511115S, the uncompressed length of 5Q0511115AA will be shorter than 5Q0511115S so that the unladen ride height of the car will be about the same.
