Everything posted by Carlston
Help with determining proper dampers for 3T Superb, rough roads
Rear Shock Absorbers - Standard 1JA 1K0513029JE 3C0513049AR 3C0513049CP Rear Shock Absorbers - Heavy Duty 1JB 3C0513049BN 3C0513049BP Rear Shock Absorbers - Sports 1JC 3C0513049BD 3C0513049BE 3C0513049BF 3C0513049BG Rear Shock AbsorberS - Higher Vehicle Chassis 1JD 3C0513049AR 3C0513049AS Notice that the 3C0513049AR rear shock absorber is listed for both build code 1JA and 1JD. So in total, there are 10 different rear shock absorbers listed for the Superb MK2 as follows: 1K0513029JE https://www.autodoc.co.uk/car-parts/oem/1k0513029je?search=OEN 1K0513029JE 3C0513049AR https://www.autodoc.co.uk/car-parts/oem/3c0513049ar?search=OEN 3C0513049AR 3C0513049AS https://www.autodoc.co.uk/car-parts/oem/3c0513049as?search=OEN 3C0513049AS 3C0513049BD https://www.autodoc.co.uk/car-parts/oem/3c0513049bd?search=OEN 3C0513049BD 3C0513049BE https://www.autodoc.co.uk/car-parts/oem/3c0513049be?search=OEN 3C0513049BE 3C0513049BF https://www.autodoc.co.uk/car-parts/oem/3c0513049bf?search=OEN 3C0513049BF 3C0513049BG https://www.autodoc.co.uk/car-parts/oem/3c0513049bg?search=OEN 3C0513049BG 3C0513049BN https://www.autodoc.co.uk/car-parts/oem/3c0513049bn?search=OEN 3C0513049BN 3C0513049BP https://www.autodoc.co.uk/car-parts/oem/3c0513049bp?search=OEN 3C0513049BP 3C0513049CP https://www.autodoc.co.uk/car-parts/oem/3c0513049cp?search=OEN 3C0513049CP
If you are looking for aftermarket rear shock absorbers, you don't need to know whether your car has 3C0513049BN or 3C0513049BP OEM part numbers if you go with TRW JGT1054T as that aftermarket rear shock absorber is sold to replace both these OEM part numbers. However, also consider Optimal A-1434G and VAICO V10-4256 as these are sold to replace 3C0513049BP. autodoc list just a TRW to replace 3C0513049BN and just Vaico, Optimal, and the same TRW to replace 3C0513049BP. However, as with most aftermarket shock absorbers, it's a bit of a one size fits all approach...or at least each aftermarket shock absorber is often sold to replace a huge number of different OEM part numbers. This means that an aftermarket shock absorber might not even be a close match to the original. KYB for example, sell just one front shock absorber to replace ANY front shock absorber on the Superb MK2. It doesn't matter to KYB whether your car has standard suspension, sports suspension, heavy duty suspension, or increased ride height suspension. Clearly, KYB aren't too concerned about selling you a close match to the original. But this problem isn't just limited to KYB...it's an industry wide problem. Notice that the Vaico is sold to replace the same 20 OEM part numbers as the Optimal. The Vaico is also sold to replace an additional 4 OEM part numbers that the Optimal is not sold to replace. I've put these additional 4 at the end of Vaico's list, ie. 561513049, 561513049B, 561513049C, 561513049D. Optimal A-1434G Rear Shock Absorbers 3C0513049BP (sold to replace the following 20 OEM part numbers) 1K0513029JE 3C0513049AP 3C0513049AQ 3C0513049AR 3C0513049BD 3C0513049BE 3C0513049BF 3C0513049BG 3C0513049BH 3C0513049BJ 3C0513049BP 3C0513049BQ 3C0513049BR 3C0513049BS 3C0513049CE 3C0513049CH 3C0513049CJ 3C0513049CN 3C0513049CP 3C0513049CR TRW JGT1054T Rear Shock Absorbers 3C0513049BP (sold to replace the following 4 OEM part numbers) 3C0513049BN 3C0513049BP 3C0513049CN 3C0513049CP VAICO V10-4256 Rear Shock Absorbers 3C0513049BP (sold to replace the following 24 OEM part numbers) 1K0513029JE 3C0513049AP 3C0513049AQ 3C0513049AR 3C0513049BD 3C0513049BE 3C0513049BF 3C0513049BG 3C0513049BH 3C0513049BJ 3C0513049BP 3C0513049BQ 3C0513049BR 3C0513049BS 3C0513049CE 3C0513049CH 3C0513049CJ 3C0513049CN 3C0513049CP 3C0513049CR 561513049 561513049B 561513049C 561513049D Rear Shock Absorbers sold to replace OEM part number 3C0513049BP https://www.autodoc.co.uk/car-parts/oem/3c0513049bp?search=OEN 3C0513049BP
brake pads
You need to change the brake pads before there's metal to metal contact. However, don't wait that long as metal to metal contact will ruin the brake discs.
S3 Winter wheel / brake sizes
I found the below information in the owner's manual. It looks like you need to look in the declaration of conformity (in the so-called COC Document) to find out the Skoda approved tyre sizes. Approved tyre sizes are specified in the technical vehicle documentation and in the declaration of conformity (in the so-called COC Document). The declaration of conformity can be obtained from a ŠKODA Partner (valid for some countries and some models).
This is in the manual for the Superb iV 2020. 17" wheels are only needed if you have the massive 340mm diameter front discs, as 16" wheels won't clear the brake calipers on those. Technical specifications Permitted rim / tire combinations for the installation of the snow chains. Rim size Wheel size 6.5Jx16 ET41 215/60 R16 6.5Jx17 ET41 215/55 R17 Only use snow chains with links and locks no larger than 13 mm.
Octavia 2007 II Combi (1Z5) 2.0 TDI PD vRS 125KW 170hp: Job List - Break disks, pads, callipers, shocks. All round. DIY - Please advise
Front Springs 1K0411105DB (1) 1K0411105DB coil spring 1 paint mark 1 paint mark 1 paint mark red white violet Model data: PR-L58 Front Shock Absorbers 1T0413031HP (8) 1T0413031HP gas shock absorber Model data: PR-G07+2UC+ L55,L58 http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2007/drive_standart/419/hg_ug/411/subcategory/411020/part_id/0/lang/e Front Brake Calipers ATE 1K0615123F 1K0615124F (1) 1K0 615 123 F brake caliper housing red left painted 1 PR-1LL (1) 1K0 615 124 F brake caliper housing red right painted 1 PR-1LL Front Brake Discs 1K0615301AA 8 1K0 615 301 AA brake disc (vented) 312X25 5/112 2 Front Brake Pads 5K0698151 15 5K0 698 151 1 set: brake pads with wear indicator for disc brake free cable ends must be isolated front 1 PR-1LP,1LL https://skoda.7zap.com/en/cz/octavia/oct/2007-419/6/615-615030/#15 Rear Springs 1K0511115BS or 1K0511115BT (1) 1K0511115BS coil spring 1 paint mark 2 paint marks rear blue yellow Model data: PR-1JC+0YC (1) 1K0511115BT coil spring 1 paint mark 3 paint marks rear blue yellow Model data: PR-1JC+0YD Rear Shock Absorbers 1K0513029GB 7 1K0513029GB gas shock absorber for sports suspension rear http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2007/drive_standart/419/hg_ug/511/subcategory/511031/part_id/2562471/lang/e Rear Brake Calipers TRW 1K0615423P 1K0615424P (1) 1K0615423P brake caliper housing red left painted Model data: PR-1KP (1) 1K0615424P brake caliper housing red right painted Model data: PR-1KP Rear Brake Discs 1K0615601AD 7 1K0615601AD brake disc 282X12MM 5/112 Rear Brake Pads 1K0698451G 10 1K0698451G 1 set of brake pads for disk brake rear 260X12MM http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2007/drive_standart/419/hg_ug/615/subcategory/615062/part_id/2550123/lang/e Build Codes G07 = Front shock absorption 2UC = Sports version L58 = Suspension range 58 installation control only, no requirement forecast 1KP = Disc brakes, rear
Brake pad confussion
Minimum thickness is 27mm on the 340mm diameter front brake discs. https://www.autodoc.co.uk/car-parts/brake-disc-10132/skoda/superb/superb-3v3/112399-2-0-tsi-4x4?supplier[0]=3&supplier[1]=833&criteria[100][2]=VA
Can I change from 18" wheels to 16" wheels?
What will fit depends on the diameter of the front brake discs. 14" wheels will fit over 256mm diameter front brake discs. 15" wheels will fit over 288mm diameter front brake discs. 195/65R15 fitted to 6Jx15 ET35 rims are listed as a winter tyre size on the Scala. 16" are always going to fit the Scala and Kamiq. You could even fit bigger 312mm non-standard front brakes with when using 16" wheels. It sounds like some Skoda dealers are simply saying that if a certain car model didn't come out of the factory with those size wheels that you can't fit them. Even though they will physically fit.
Front Coil Springs - Which Part is Correct?
Draper 14173 Coil Spring Compressors https://www.amazon.co.uk/Draper-14173-Coil-Spring-Comssors/dp/B0001K9Q2W/ref=sr_1_1?dchild=1&keywords=draper+14173&qid=1633963913&qsid=258-4143725-5817839&sr=8-1&sres=B0001K9Q2W%2CB01BKNY0BA%2CB0001KA0JU%2CB0001K9PGE%2CB0108APBRI%2CB06XXBWPRM%2CB07CRNT3S8%2CB000VMC758%2CB0002BUVGK%2CB004OTOL0I%2CB00205OQPI%2CB0001K9WNA%2CB000TOLSDK%2CB0108LGLU8%2CB000MQ7X9I%2CB0001K9RXA%2CB01EHSXUZW%2CB000PJAF1A%2CB00BWPZ0DO%2CB00HNUX9A8
WHEEL SIZES
No, they won't fit. They are not from the BMW 5 series as the seller claims. They are from a 20 year old BMW 3 series and the rims have the wrong tyre size on. On the BMW they originally came with 205/55R16 but someone has fitted 225/50R16. If they had wanted 225s, they should have changed to 225/45R17 which is a much more common and cheaper size. BMW wheels don't fit VW group cars including Skodas as the PCD and centre bore are wrong. BMWs also use a different type of wheel bolt...conical instead of spherical. Skoda Superb MK2 2.0TDI 140PS – Center Bore: 57.1 mm – PCD: 5x112 – Thread Size: M14 x 1.5 Tire Rim 205/55R16 94V 6Jx16 ET50 2.3 / 2.1 205/55R16 94V 7Jx16 ET45 2.3 / 2.1 Skoda Superb MK2 2.0TDI 170PS – Center Bore: 57.1 mm – PCD: 5x112 – Thread Size: M14 x 1.5 Tire Rim 225/45ZR17 94W 7.5Jx17 ET49 2.4 / 2.2 225/40ZR18 92Y 7.5Jx18 ET46 2.4 / 2.2 https://www.wheel-size.com/size/skoda/superb/2012/#trim-20tdi-eudm-168
Maybe the brake pads were changed at some point to cheap aftermarket pads as opposed to good aftermarket pads. As you can see from the below link, good aftermarket pads don't have to be expensive. TRW Front Brake Pads - Build Code 1LA (for 340mm diameter front discs) https://www.autodoc.co.uk/trw/11288579
New (old) wheels
I would rather have Uniroyal RainSport 5 205/55R15 88V than 195/50R15. It's a rare size and they're not cheap but compared to the low sidewall height 195/50R15 the ride would be a lot more comfortable. Uniroyal RainSport 5 205/55R15 88V https://www.camskill.co.uk/m53b0s289p188338/Uniroyal_Tyres_Car_Uniroyal_RainSport_5_-_205_55_R15_88V_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_A_NoiseClass%3A_2_Noise%3A_71dB 205/55R15 was a size used on the Audi A1 fitted to a 6.5Jx15 ET34 rim. Audi A1 2010 1.6TDI Tire Rim 205/55R15 88V 6.5Jx15 ET34 2.1 215/45R16 90V 7Jx16 ET34 2.1 https://www.wheel-size.com/size/audi/a1/2010/
New (old) wheels
With the pepperpots you've got a choice of eight different tyre sizes. 185/55R15 185/60R15 185/65R15 195/50R15 195/55R15 195/60R15 205/50R15 205/55R15 185/60R15 is one of the most popular tyre sizes to use with 6Jx15 ET38 5/100 rims. It's a standard combination on the Fabia MK3. Vredestein Quatrac 6 185/60R15 88H XL https://www.camskill.co.uk/m138b0s7989p202141/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_-_185_60_R15_88H_XL_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_2_Noise%3A_70dB 195/55R15 would also be a good choice for the 6Jx15 ET38 5/100 rims. Vredestein Quatrac 6 195/55R15 89V XL https://www.camskill.co.uk/m138b0s7992p202143/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_-_195_55_R15_89V_XL_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_2_Noise%3A_70dB
Tyre size
235/35 or 235/40 aren't legal on a narrow 7.5J rim as you can see from the Toyo links below. You need at least an 8J rim for these tyre sizes. Tire Size Tread Depth (mm) Overall Diameter (mm) Overall Width (mm) Approved Rim Width Range (inch) 235/35 R19 91W XL 8.8 647 241 8.0-8.5-9.5 https://www.toyo.co.uk/tirefinder/index/width/235/aspect/35/rim/19 Tire Size Tread Depth (mm) Overall Diameter (mm) Overall Width (mm) Approved Rim Width Range (inch) 235/40 R19 96W XL 7.6 671 241 8.0-8.5-9.5 https://www.toyo.co.uk/tirefinder/index/width/235/aspect/40/rim/19 wheel-size.com is also showing an 8J rim for the 235/35 tyre size Skoda Octavia MK3 2.0TSI Tire Rim 225/40ZR18 92Y 7.5Jx18 ET51 2.2 225/35ZR19 88Y 7.5Jx19 ET51 2.2 235/35ZR19 89Y 8Jx19 ET45 2.2 https://www.wheel-size.com/size/skoda/octavia/2016/
Winter tyres 195/65/15 ?
Skoda Fabia MK2 1.2TDI Tire Rim 165/70R14 85T 5Jx14 ET35 2.1 / 2.2 185/60R14 82T 6Jx14 ET37 2.1 / 2.2 185/55R15 82T 6Jx15 ET43 2.1 / 2.2 195/50R15 82H 6Jx15 ET43 2 / 2.1 195/55R15 85H 6Jx15 ET43 2.1 / 2.2 205/45R16 83V 6.5Jx16 ET43 2 / 2.1 https://www.wheel-size.com/size/skoda/fabia/2014/#trim-12tdi-eudm-74
Hi fellers. Proud owner of a rust bucket Fabia MK1 from Romania, chiming in
It depends how you drive it. It's all about economy and low end torque that's the selling point of that engine. Cruising at 56mph on the motorway isn't going to be a problem. Car insurance should also be cheaper with so little engine power. If it had been tuned up to produce 75HP with maximum torque coming in at a much higher 3,750rpm then top gear flexibility would have been ruined along with fuel economy. Of course, the market has now moved on and we have 1.0 litre turbo charged fuel efficient petrol engines producing excellent torque from 2,000rpm.
The 1.4MPI 8v engines appear to be OHV. It looks like the Octavia MK1 used a similar engine with engine code AMD. Skoda Octavia MK1 1.4 8v 1,397 cc (85.3 cu in) 4 cyl OHV 60 PS (44 kW; 59 hp) at 4500 rpm 120 N⋅m (89 lb⋅ft) at 2500 rpm AMD 1999–2001 https://en.wikipedia.org/wiki/Škoda_Octavia#Engines
Take a look at the white build code label/sticker in the boot. Which engine code have you got? AZE, AZF, AME, AQW, ATZ ? The engine code might also be on a label on the engine/cambelt cover. 1.4 MPI 2000–2003 I4 AZE/AZF 1397 cc 44 kW (60 PS; 59 hp) at 5000 rpm 118 N⋅m (87 lb⋅ft) at 2600 rpm 1.4 MPI 1999–2003 I4 AME/AQW/ATZ 1397 cc 50 kW (68 PS; 67 hp) at 5000 rpm 120 N⋅m (89 lb⋅ft) at 2500 rpm https://en.wikipedia.org/wiki/Škoda_Fabia#Engines
Cost of brake replacements
If the pads/discs are worn more on the inside that could indicate a sticking caliper, although because Skoda cars tend to use one piston sliding calipers they might wear more quickly on the inside anyway.
New Battery Problem On Standard Skoda Superb 1.6 TDI 2012
You could use it to test the battery voltage, but if I was using a dumb car battery charger I would connect up a constant voltmeter possibly using something like this cigarette lighter socket with crocodile clips and with an LED/LCD cigarette lighter voltmeter plugged into it. You can then see what voltage the dumb car battery charger is charging the car battery at. However, I wouldn't try fully charging the car battery using a dumb car battery charger, because if you keep charging the car battery when the battery is full you will damage it permanently (and new car batteries aren't cheap): https://www.ebay.co.uk/itm/402994537554?hash=item5dd458a452:g:C1sAAOSwqglg7~37
An underhand upselling technique?
Build code 1KU means that you have 300mm diameter solid rear brake discs. https://www.autodoc.co.uk/car-parts/brake-disc-10132/skoda/superb/superb-estate-3v5/115168-2-0-tdi?supplier[0]=3&criteria[100][1]=HA These should fit the 312mm diameter front brake discs on the Superb MK3. EBC DPX2150 Front Brake Pads https://www.ebay.co.uk/itm/263091310141?epid=248957621&hash=item3d4176ce3d:g:VY8AAOSwuxpZa2Xo These should fit the 300mm diameter solid rear brake discs on the Superb MK3. EBC DPX2153 Rear Brake Pads https://www.ebay.co.uk/itm/291600255351?hash=item43e4bac977:g:5j8AAOSwReBZdJt4
I've got this Bosch 12V C1 car battery charger. It cost about £35 including postage from amazon.de It's a very modern battery charger and an led light comes on when the battery is fully charged. It will charge all 12V car batteries including the latest stop-start AGM models. There are no settings to set, so its as simple as it gets to use, and it won't overcharge the battery. Notice the four LED lights in the photo. Standby, Charging, Full, and ! if there are problems. The charge rate is 3.5 Amps which is close to the maximum charge rate that is recommended by the battery manufacturers for many of the typical car battery sizes and models. https://www.amazon.de/-/en/189-999-01M-battery-charger/dp/B00RP3DEW6/ref=sr_1_1?dchild=1&keywords=bosch+12v+c1&qid=1633439463&qsid=260-8735091-6284542&sr=8-1&sres=B00RP3DEW6%2CB00EALQM9S%2CB005XVTW0A%2CB0924XTRV7%2CB00B1RH3KG%2CB0032BKLI0%2CB003VEILMG%2CB003JY81VO%2CB08GKYW5KS%2CB07MBFY5ZH%2CB003JY828G%2CB01N4F9YRD%2CB06XYPXVFC%2CB002B552QY%2CB07R2FGH4Z%2CB00FAMAB4S Yuasa recommends a 3A charge rate for their 12V 50Ah AGM battery, a 4A charge rate for their 12V 60A AGM and 12V 70A AGM batteries, a 5A charge rate for their 12V 80A AGM and 12V 95A AGM batteries, and a 6A charge rate for their 12V 105Ah AGM battery. https://www.yuasa.co.uk/batteries/automotive/ybx9000-agm-batteries.html
What battery charger are you using? Many so called automatic battery chargers don't turn off but keep charging at a low level, and as soon as they get a bit of charge in them the charge rate drops to a very low level. If a battery charger keeps charging a car battery that is fully charged, it will damage it. Here's one example that looks like it's from the 1970's and best avoided as although it's marketed as an automatic battery charger it really is quite dumb as it's unable to detect when the battery is fully charged...and therefore keeps charging even when the battery is fully charged. If you don't have stop-start, then this Varta would have been a much better choice than the battery that you linked to on eurocarparts. Varta Battery 12V 63Ah D15 027 https://www.ebay.co.uk/itm/251195560237?hash=item3a7c6c112d:g:~rYAAOSwaPdg0N~N
2017 Citigo - To buy or not to buy
If it's been used by learners, the clutch will be worn and might soon need replacing.
