Everything posted by DieselMonte
DieselMontes BarnFind Subaru Justy
Manual states they're to be gapped between 0.45mm and 0.55mm. Split down the middle at 0.50mm
Ha! They're Ring lamps I got of marketplace for 20 euro. Funny the ring spotlamps I put on the Monte recently came with covers, but these didn't.
What Knob said that? Most of that is probably coming from it being run with low fuel (and old fuel) for a bit. Should be about 20l of fresh fuel in it now. Have been chucking Redex down it too to try clear things out. Points are connected as the old ones were, did take photos to help remember what wire goes where. That filter is literally weeks old but considering how cheap they are I think I'll just keep changing them until that ****e is cleared out of the tank. One more thing, forgot to include pictures of the new lights in a previous post. Initial plan was to hide them behind the covers when I didn't need them, but these are far too big for that. My bad for taking a chance on ones on marketplace. Probably still going to use them however. I think they do look correct on this sort of car. I am a sucker for yellow lamps on any car however. Anyone have any opinions on these lights?
Update time: Had this thing idling away in the garage and it just died on me and wouldn't restart. No spark. Day after that I got my big load of parts so saw to putting them on. New HT Leads Points Did take the distributor off to fit them because the screws holding the Points in were ready to strip. Marked it so timing should be relatively close to before. Checked the fuel filter I put in a few weeks ago, definitely doing its job, have yet another one I'll replace it with soon. Still no spark, however I have it narrowed down to the coil. Traced the positive wire to the coil and put the timing light to it. Lead up to that white box. Just to be sure I did the same to the wire coming from the other side of the box that goes onto the positive of the coil. So It's getting power to the coil, but no power comes from the big lead that goes to the distributor. Have a coil ordered, should be here Tuesday. Also still to come are: -New Cap -Rotor -Carb Rebuild kit Other things I got in that care package that I haven't mentioned are: -Timing belt -Accessory Belt -Valve Cover Gasket -Spare Plugs. One more thing to mention. Said before the backbox was solid but just the tailpipe looked crumbly I was very much wrong there. It's leaking from the gasket and on the weld where the exhaust goes into the backbox. No wonder it sounded so angry. To fit the backbox I got I'll need to have the mid section redone as it goes from 2" at the manifold down to 1.5" to the rest of the system. My backbox is a 2" one. It's a more or less straight piece of pipe from the manifold to the backbox so shouldn't be *too* expensive. Should sound quite nice and maybe even give a bit more pep when it's done.
DieselMonte's 2012 Monte Carlo Project. (175hp 6 speed swapped)
Happily I this didn't need paint, PDR guy did a fantastic job and much cheaper than I'd thought too. 70 euro to have it sorted, and it was a fair dent, looked worse in person. Now you honestly could not tell there was ever any dent.
Dungadungadun's Fabia mk2 Estate
H&R one then?
Have been driving it a bit more (on private roads), still rough on light throttle but runs fine once you're putting the pedal down. Got it up to 70 even and it felt really solid, Handles pretty decent too although I suspect some bushes will turn to dust once it starts getting driven regularly.
Still waiting on my big order to come, but in the meantime I got these lamps, intending to put them behind the blanks for the foglamps. Thought they'd be too big but looks like they'll be a perfect fit. My reasoning for putting them behind the blanks is so that I can put the blanks over them when I'm not using them, keeping the "original" look. Sort of how I did the spots on the Monte but this time completely hiding them.
Did a job on the intercooler to make it sit tighter. And changed the spot lamps hopefully for the last time. 7 inch halogen lamps this time Very very tight fit. But they do fit. Will be changing the main lights back to halogen soon. LED bulbs were not the silver bullet for improving lighting I was led to believe
Fabia mk2 Monte Carlo undertray.
I've been looking around breakers yards for an undertray for mine and not one has one available here. I still have mine but its broken in places. New genuine are still available for around 90 euro so worst case you can still get them. Spurious ones on ebay would be cheaper still. It's a bit of plastic so not much to go wrong. I have been able to make a standard undertray work on my car (which also has a larger intercooler) by making a piece of wood to bridge the gap between the front of the undertray and the bumper. Hoping to get a new undertray (or one in better shape) to use to do a proper job on.
Dogbone/Lower Torque Mount Polybush Fitted
Looks like they changed the design a bit since I bought mine. Mine doesn't have the purple ring in the centre
1.6TDI N75 Weirdness
Stevie wonder could do it. 5 minute job tops. Only thing that might be annoying is the vacuum lines being a bit annoying to get off. They should slide off but you might need something to wedge between the pipe and the bit on the n75 itself. Should loosen it up enough to come off.
Went and got a timing light since I figure I'll need it for this at some point. New air filter put on, old one was rotten Have a big order of stuff for this coming in the next week or so. Seems to be clearing itself out a little bit more. Might have a thermostat stuck open as It takes a while to heat up while idling and the temp goes off the bottom of the gauge once you start driving and air gets through the radiator. The closer to operating temp it gets the better it runs at part throttle.
There's one of these being broken over in Ennis, might get the intake manifold off it incase I ""need"" to put a weber on. Seemingly the hitachi carb on this is a complex ******, so putting a weber in its place will simplify things a lot and (from looking at old forums) give a fair bit more power than the standard carb. Could always go really mental and put three 40mm Mikuni carbs on it, like what subaru America did to their bonneville speed record justy. That's a FWD 1l justy there, apparantly they squeezed 120hp out of it, naturally aspirated I might add.
As am I, astounded how well the paint came up Showed it to someone this evening and they thought It was repainted, wouldn't believe such old paint could come up that well. I Absolutely love this thing. I'll be ordering more odds and ends for it and hopefully I'll be able to track down a rebuild kit for that carb. It'll probably clear itself out with some more driving, but if I can get a kit I'll take it apart and clean it properly.
More Piccies Needed to take it to put petrol in, have sussed the fuel float is stuck, will probably free itself up with some driving me thinks. On advice from a friend I raised the idle, it tried to idle just around 500rpm before, raised to 1000 now. Slow as anything and I did need to hold the choke a fair bit to get it to smooth out, but it is running, driving and amazingly, extremely comfortable.
Skoda Fabia 2 facelift Gear Lever mechanism
My 2012 has the same mechanism as the first one if that's any addition.
This is the more or less finished product. Its pitch black outside but hopefully I'll get some pics in the morning. Cleaned up well, thick layer of film came off the inside glass. I waxed the outside of the glass as I find it improves visibility massively in the wet. I've yet to have a problem doing it to any car I've owned. Some religious bits in the car still from the previous owner. I took them out, cleaned them and put them right back in. Didn't feel right to remove them.
Everyone seems mad for me to get the wheels done but I'm not in a rush. I'm not necessarily trying to make this look new, just trying to freshen it up to enjoy. Don't really mind the scruffy wheels on this if I'm honest. Might do them or have them done at some point but it's not a priority. Almost definitely needs one. Every time you drive iti, it's clearing up more and more. Presumably old fuel still in the system and gumming everything up isn't helping either.
Too many photos to put in one post but I've finished polishing the paint, wasn't glazed or waxed in that photo, so might come out a bit glossier when I'm actually finished. And I used trim restore on the bumpers, Didn't get a good before/after shot like I did the bonnet, so I did one on the boot trim. Took the plates off for probably the first time, as evidenced by the imprint of the numbers behind them. Not sure whether I'll keep the old plates or maybe get new metal ones. Might put a jap/square plate on the front as it seems one might fit it better than the original one
New spark plugs put in, they made a noticeable difference. Revs a lot more freely now, still a bit stumbly under 2000 rpm when you're driving it however. Clears up above that. Sounds quite nice with an open intake. Only Like this because the air filter I ordered has still not arrived. Got the wheels off it to get tyres on. Pretty good shape underneath considering. And you can see why I needed new tyres. All of them were like this And one was like this Got some ditchfinders fitted for 50 euro a corner. All the driving this will see, they should be fine.
Cracking away at it while I get stuff sorted with the mk1(s) Still haven't gotten a logbook for the vrs so just gonna put it aside for the moment.
Not much done to this, done quite a lot of driving and I've had/have a few other projects to take care of too. Picked up these 2 things recently. Snap Seal and naviwax. Tested it out on this and got great results. Have had a bit of bad luck since, gust of wind knocked a roadsign down onto the bonnet. Left a decent dent but no paint work needed seemingly. Should be sorted next week hopefully. Lastly wired the DRLs to come on with the sidelights, finally. Very easy to do, used my own wiring with a relay, signal from the sidelights and a wire from the relay to one of the drls. For some reason once you get power to one, it sends power to both DRLs. Pic of what no lights looks like And just the DRLs on their own. These can still be switched on and off as skoda intended too. Helps light up the sides of the roads and all it cost me was the price of a relay. Should have done it years ago.
Jacked it up on one corner to get as much as I could out. Fresh fuel and New filter in Ran for a bit and looks like it's running clear fuel through the filter. Couldn't get every drop out but as much as I could. Ordered spark plugs which should be here tomorrow. Seemingly a place not too far from me does 145/12 tyres for 50 a corner. Should be OK for the driving this will see.
