fr1nklyn
Everything posted by fr1nklyn
  1. I hope it will acceptable in all EU countries if it's verified in any EU country. Otherwise what's the point of the EU? Except the currency which doubled the prices.. 😒 Where do you verify your FEs? I plan to visit this place because it's relatively close to my work https://solti.bg/
  2. Maybe "under the seat" will be my option B - it looks neat btw, good job! I don't have sub and I have a small belt on the right pocket, holding the current 1kg extinguisher. I've ordered this Gloria 2kg Fire Extinguisher made in Germany(not because it matters these days.. :D ) but with a bit shorter than the standard Tornado and other local brands sold in Bulgaria. I did this with the hope that it will fit and will be held in the right pocket with the built-in belt. Should arrive some time next week and I'll provide an update. Even if it doesn't fit, I like it more than the local options in Bulgaria. EDIT: Here is what I've ordered https://www.ebay.de/itm/224461083893 (I'm having some bags there as well :D )
  3. Thanks @leolito ! I was thinking about the boot "pockets" since on the estate there is plenty of room there. Btw are you going to buy also a first aid kit meeting the "DIN 13164" standard?
  4. Hey guys, I need to keep a 2kg fire extinguisher in my car due to legal requirements in Greece and I’m trying to figure out the best mounting spot. My main concern is securing it properly so it doesn’t rattle or move around while driving. I’d love to hear from anyone who’s dealt with this — where did you mount yours, and did you use a dedicated bracket or holder? Any tips on keeping it secure without damaging the interior would be great. Thanks in advance!
  5. Thanks @Dave77 , so it's good to be reported and documented by the dealer then. Yours sound good, mine is more like an old door squeaking
  6. Hey guys, sorry for reviving this old thread but I started to have same creaking sound when I launch the car or turn on the A/C. It’s 2023 Dec Superb III on 45k kms, so this is still an issue on the lately produced FL model. I will go to the dealer because the car is still under warranty, but I hope that they won’t tell me that they will remove the whole dash.. Otherwise I suspect that more noises will appear after that 😅
  7. You may also want to know that DQ381 7-speed often has issues with pressure sensors on the mechatronic till around 2020. It's fixable of course, but... The 6-speed is more reliable but less comfortable. Proper maintenance matters as well.
  8. I think there is only one umbrella by default, so only one missing :) The passenger side is for a snow brush(5E3096011) and I usually swap them when season come ❄️
  9. It has always been 120 on all of my cars.. maybe except one old VW Polo.. but honestly I haven't checked the manual of this one 😐 Thanks @Binx1310 !
  10. I do use 120 Nm for 18" wheels as well. But for 19"s I think it's really 140 https://www.briskoda.net/forums/topic/514557-torque-settings-for-superb-mk3-19-alloys/
  11. Ok, this is now resolved - the hub had to be changed because the car is still under warranty and future claims for related part might not be valid otherwise. I had to pay for the hub, of course 🫠 I would think about the wheel every time I drive on the highway if the dealer used one of those tread repair kits anyway. I've talked with few colleagues what happened, and some of them said that it's not very easy to do a hub thread damage with Lidl's impact wrench which I've used. It was even set to mid-power not to max. And having in mind I had to torque all the bolts with a torque wrench after that. Anyway I've learned my lesson. I'll be more careful next time. I won't use the impact wrench for tightening the bolts, but only for loosening them. And I'll also use a positioning pin as well. Cheer guys!
  12. Yeap, @travs explained similar technic. Seems common, but I haven’t seen it before.
  13. Yes, at least two seems reasonable. This will avoid rim moving. They are like €10-15 for a pair.
  14. I like the black trim more, but never had one on a car. Not sure is this an option while purchasing? I know that the chrome one is defective on many non-FL Superbs - it's peeling off on the rear doors, but not on the front ones. There are many Superbs like that and Skoda claims it's from washing the car with incorrect products. Shame on those people washing only half of their cars
  15. Dry - I never lube the bolts since that may change the actual torque I try to set.
  16. What what, are you pushing the wheel with your feet to the hub while turning the bolts with extension with your hands? You seems to be very flexible. Sorry I asked ChatGPT to draw it for me, but it draw the man beside the tire, not in front of the tire. (I might asked to draw it like 5 y.o. :D ) PS: Sorry I'm just fried at the end of the week. I'm losing it...
  17. Yeap, but thought that it might be helpful to someone facing the same issue.
  18. While looking for tire positioning pins, I found that there are conversion kits to wheel studs like in this video https://youtu.be/Crlu_HfyHeI?is=8QdW8nWgBk9r1lcZ It looks so much easier with them. I know most of the Asian cars have them.
  19. I'll definitely get a pair for the next swap! :) I usually have someone holding the tire and helping me, this why I haven't faced such issues before, but I'll be prepared for the next time.. I was able to contact the Skoda garage and booked for the next week.
  20. Ok, I’ve lifted the car and removed the other 4 bolts, then removed the problematic bolt by hand with a ratchet while the weight of the wheel was pushing it out. The bolt thread is damaged a little but also the thread of the hub somewhere deep inside. I don’t see issues with the hub thread visually but when I tried to turn a good bolt, it’s still spinning at the end and I can’t torque it to 120 Nm..
  21. Yeap, learned that lesson the hard way.. I actually knew about that but couldn’t hold the tire while turning the first bolt carefully by hand, so used the impact wrench.. I had to take a fella maybe or iluse one of those bolt pins(not sure how are they called) which conveniently hold the tire while you put the bolt in. EDIT: These pins I’m talking about are called “tire positioning pins”, e.g. https://share.temu.com/paetW1bQ34B
  22. (sigh) I swapped my winter tires with summer ones, both being on separate wheels. I used impact wrench to tighten them. Then when all were done I tried to torque all wheel bolts to 120 Nm, but one of the bolts keeps turning. Most likely the thread is bad - either on the bolt itself or the hub. All other bolts are torqued properly but this one.. I tried to remove it but I couldn't, so I tighten it again (maybe that was stupid from my side). The car is still under warranty but the dealer will most likely book for after few weeks since it's that time of the year when everyone changes their tires. They don't answer on the phone, I'll try tomorrow again. Wondering should I check with a tire shop instead? Or should try my luck to remove the bolt, by first removing the other 4 bolts on that wheel and then use the impact wrench on the problematic bolt? If it's only the bolt thread not the hub, I'll be very happy guys, but should I try or better don't touch anymore.. ☹️
  23. It shouldn't cause any harm, but if it's about to be serviced next month, don't bother yourself - ask them to do it while servicing.
  24. Why don't you try DSG adaptation? Indies and dealers usually skip this step, as it's not mandatory unless there is an issue or mechatronic is replaced, but many report good results after it's done(including me on my ex-Octy):
  25. I've used many fuel additives: Bardhal BDC, ProTec, Castrol diesel additive, Archoil 6900 and Oilsyn Power DNA, and even 2T ashless oil in my old pump duse diesel :D . In my head, Archoi and Oilsyn seems to quite the engine and make the DPF regenerations less often, but again this is in my head.. 🤓 I've also had good results with Archoil 6400 on a car with blocked DPF due to too many short journeys. It seems to increase the exhaust temperature and actually work in such cases, but I wouldn't use it if there are no DPF issues.
