Danoid
Everything posted by Danoid
  1. Do you remove the bungs first then put the axle stands there? Last thing I want is them to pop in and rattle around. I forgot to say I looked at my 2016 Superb and don’t see that panel you posted in the first picture at all, how odd
  2. As the oil filter is on top, I would buy an oil extractor and leave the sump plug alone. Sorry read it wrong, thought you were going to DIY
  3. So i’m still a bit confused and surprised there’s not more replies as people are doing their rear brakes on here. So just to confirm, use trolley jack on the sills with a hockey puck adaptor, 100% correct? If you don’t have a death wish and not just doing a tyre change you should be using an axle stand, but where? I’m guessing for the fronts you’d put the axle stand here? (If the picture does not post online, it’s the one with the rubber bung) If you do put your axle stand here do you remove the bung first, then place axle stand with a protective top? For the rears I can see a cover, I’ve only tried to remove it with my fingers and couldn’t but I’m going to guess it’s like the front with a rubber bung, either way is this where you put the axle stand for the rear?
  4. Not sure if you can disable the dimming, but it would not necessarily dazzle other drivers but it would be annoying which is why it dims on and off.
  5. You need what I have, which is an old office chair with the back removed, can wheel about then like Davros
  6. Oddly enough I was looking at oil pumps yesterday not electric though. Found out the superb’s oil filter is removed from below so waste of time getting an oil extraction pump :(
  7. I wish I had the cream leather as like you said makes it look airy and also less hot in summer. Gliptone liquid leather is what you need, as soon as leather seats look shiney it’s dirty :( It makes the car smell amazing too with its leather smell, though if you apply it without gloves it does smell like you’ve been fisting a cow
  8. Simplest terms, mib2 is what’s in that car. mib2.5 is a larger screen, looks like a nightmare for sun as well (can’t confirm), less buttons and the buttons aren't buttons as it’s touch sensitive. Might be other things too to do with software but not sure
  9. Just noticed the cream interior yum yum. Does look like the front drivers seat is a bit shiney so get some Gliptone on that :d
  10. You can’t just swap your battery on these cars as it needs coding in first. Personally i’d wait until Monday and go for a longish drive. In my mind turning as much electric gadgets off as possible will recharge the battery quicker
  11. You said vacuum and not hoover ❤️
  12. I got a used one on PCP, didn’t have too much wiggle room I managed like £2k off and 2 services
  13. I thought all Superbs had HDC and it’s automatic at least in DSG’s. I might be wrong but I thought when going downhill you use the brakes to get your speed then don’t touch the pedals
  14. The wife’s Fiat 500 had an advisory on MOT for some corrosion on the rear axle. I looked underneath and the paint is flaking so needs some protection. I found out this is pretty common for Fiats so i’d like to do some preventative maintenance. I was looking around on the internet and found two products of interest, one is POR-15 and the other Bilt Hambee hydrate 80 (treats the rust) then UC from the same company Has anyone used either on here? I did look at hammerite underbody seal but it sounds like it stays sticky forever which sounds grim to me
  15. Put the seat base all the way back, then all the way forward, then get into your position. press and hold set for about 3 seconds then immoderately press 1 (has to be within 10 seconds) but do it straight away.
  16. Exactly that, when I’m eco is disengages then tend to coast a lot more, so I can apply the brakes for longer. At first I hated eco as the driving experience is more clunky feeling with lag etc but i’ve got use to it, I keep meaning to put it back into normal driving mode but keep forgetting
  17. I’ve found driving in eco with DSG to clean the rears up lovely, it still looks like my pads are like an 1” too small as the outer edge of disc looks untouched (but weird) but at least the middle has come up better at 36k or so
  18. That’s most likely it as it’s when I leave the car for ages. I’ve only done around 6k miles in 4 years and once a year it goes on a 4 hour holiday drive. Other than that sits on my drive thinking “who has bought me...” 😀
  19. That works as expected just rarely it’s still turned on despite the car being turned off for a week
  20. Bit of an odd one here and very rare but sometimes when starting the car the passenger seat is already on max. I know if you drive, stop then return it remembers, but today it happened and last time I drove it was a week ago Very odd and so rare i’m not too fussed, unless someone else has had this and found the problem
  21. Noticed the dashboard cluster needles look like mini lightsabers
  22. What I don’t understand as well is when Skoda lift the cars it looks like it’s done on the sills but just use flat pads and doesn’t cause any damage. Is that because it’s lift at all 4 points and load is spread?
  23. Thanks, though that panel area seems scary to me. i saw a trolley jack pad from power flex which looks stepped so taller one side than the other which looks like it’ll be perfect, I have emailed them to confirm first though. Is your axle stand flat? Mines more like a V shape but not fussed if I need to buy more. I need to buy a new trolley jack anyway because when I used it on my Passat the back of the trolley jack lifted in the air
  24. That’s the standard jacking points, is this where you use your trolley jack, if so do you use the hockey puck to protect the sills from crushing? Also where do you put the axle stand?
