Everything posted by Former
Fabia mk 4 A/C not cold enough
Yeah it's bad they didn't sort it first time but you will have to take it back to them or another VWŠkoda Dealership if you want this sorted under warranty. You could ask the Dealership if there are any Recalls (VW avoid these usually) or any technical bulletins (TPI? TBS?) on the issue, they keep those quiet, but just asking might show your greater level of intent to get this sorted. Nowadays many rely on the computers giving the answer to them on a plate and/or firing the parts cannon at the car rather than any real interrogation of the information the computers supply and doing diagnostics from that information and using other diagnostics tools (particular the biological electronics they have between their ears). Good luck. Let us know how you get on.
New here.
Hi, welcome Trevor. Er, yes, you might be daft, but hopefully at least it'll keep you out of trouble. 😁 My Skoda ownership only goes back to 1985 and like you I wasn't a fan of the VW style of corporate Dealerships getting rid of the friendly helpful small back street Škoda Dealerships and the car quality actually went down when VW fully took over. Other than perhaps a Golf GTi Mk1 I've never been a VW fan, or German marques generally. I don't know if you saw there's a 'Classic Škoda' section of Briskoda where your knowledge and experience could be very helpful indeed. Only yesterday I was asked if the head bolts need changing with the head gasket (on a 135 engine IIRC) and as I didn't know for sure I didn't want to guess and now I have to search the threads and posts there to confirm what I guess. 'Classic Škoda' - https://www.briskoda.net/forums/forum/173-classic-%C5%A1koda/ In the mid-80s the(friendly and helpful back street ) Škoda Dealership lent me their "flagship of the fleet" Mk1 105 Estelle which they told me they couldn't kill and it's wiliness made up for it's lack of speed but boy was it's steering heavy compared to the Mk2(s) I had. All the best, Nigel.
Hi from the Netherlands
Hi, welcome Julian. Well done on your purchase. Such a very low mileage has many advantages to the actual age of the car, I have a neighbour with a 2016 Vauxhall with the same mileage. It does require that the car has been fully maintained and serviced in a timely manner as such low mileage and perhaps infrequent use can disproportionately effect some items, engine oil being one perhaps. Hopefully you have seen the 'Škoda Yeti' forums section of Briskoda where you can find lots of information about the model in threads and posts there and if necessary by asking the knowledgeable Yeti owners there. If you read and refer to the 'Owner's Manual' you can often save yourself time, hassle and expense and avoid visits to Dealerships. garages, mechanics and auto-electricians and be able to point out this source of knowledge and what you already know. Good luck.
Favorit radiator fan thermoswitch issues (?)
The temperature gauge didn't have figures to save unnecessary worry and concern to driver/owners. Normally the needle I believe would be at (above) the yellow line, possibly higher in hotter climates, how accurate you gauge is and your coolant thermostat, and fan switch are only you can tell by testing them but if your car was previously running fine wherever the needle pointed that is was normal for your car and gauge. Variation from this normal is to be investigated particularly if the engine is running hot (or cold) regardless of where the gauge needle points. I don't know if your coolant thermostat opening at the green line is correct or not but I would expect the fan to switch on above the yellow line on a different car to yours but I am not a 1993 Favorit owner or driver (it has been 30+ years since my wife owned a Favorit). Shortening the two wires may have improved electrical contact, if so it is a good thing. The 82c thermoswitch has to be correct for your model and year and be a good quality part (many modern made parts are not good quality and some are very poor quality or worse). If I am correct I believe with other Škoda models of that period at least you need to get the correct colour plastic band on the thermoswitch. Good that you flushed the engine, did you also flush the radiator and if possible or appropriate flush the heater matrix too. At motorway speeds in other cars the needle would be above the yellow line let alone the green line but if the fan comes in when it should and you have no signs of overheating then I suspect it is as you think and the gauge reads low. I had a car where the thermostat was almost right next to the thermoswitch and neither agreed with the other about temperature, the level of accuracy and tolerance to acceptable margins could be wide. Plus by the 1990s coolant temperate gauges could be biased to go to a certain showing and stay there regardless of real life fluctuations of actual readings. Combined (mechanical) oil pressure and coolant temperature gauge for a 1960s British car. Coolant (electric sender and gauge) for a 1970s British car, markings left off to save drivers' worry (not that the gauges were very accurate anyway).
Insurance, is it legal robbery?
Yeah, corporate and personal greed, yet another American influence to our country, not that we didn't have some of it home-grown just not on the industrial scale as the "land of opportunity". Our house builders were on to it fairly well back, split the company up one part selling to another to gain profit and avoid tax that one ding the same to another going down a chain, buy a bit of land sit on it for decades, sell it to yourself and get all your different companies to do different bits until the end product of are finally available to sell, but perhaps even have someone retain the land. Motor trade is very incestuous and gives an illusion of a wider range of choice than actually exists. Remember 2008, where are those that made the mistakes and where are those that are paying for their mistakes. Life's a bitch and then you die. 😄 Last time I had some rust removed from my old car I said to the chap that ran the business (took over from his mum and dad) that there wasn't a replacement or repair section for the bit of bodywork with the rust and he said they didn't need them as they could make their own, second generation repairer and probably last.
Headlight coding
The info I saw for that part number seems confused perhaps it was superseded, one shows H& bulb plus LED daylight running lights other and what you put suggests to me it might be full LEDs and I'd be guessing rather than knowing and can't check now. So I'll leave this for someone that does know for sure or can check, sorry.
Headlight coding
What type of headlight is it LED, that self adjusting thing or old incandescent?
Stop/Start issue / Battery Question
Occasional preventative recharges with an appropriate battery charger following the instructions in the car's 'Owner's Manual' and in the booklet for the charger maintainer. Or if the car is to be lefty for weeks without use (not good for the car or battery) then disconnect the battery or connect up the charger maintainer to both recharge and maintain. Up to you which charger maintainer you choose to buy and use, personally I think the CTek are overrated, over priced and valued based on the two copies of the same CTek model a mate has which giving varying results to each other, not good for the high price - but many users like them. Lidl/Aldi sell perfectly good and long lasting charger maintainers for £15-£20, a neighbour's had one in regular use for years. and I've known of plenty of others that have bought them and use them. High price doesn't give much higher quality, I've had a cheap charger for 40+ years, stills works fine now. I bought and have used for a few years now a Ring 804 Smartcharger for my wife's 2015 VWŠkoda Fabia Mk3 the current model is 904. 4-amps is more than enough, it takes a little longer but generally lower amps is better than higher (faster) amps for the battery. Other makes. models and suppliers are available. - https://shop.ringautomotive.com/rsc904-4a-smart-battery-charger-maintainer.html Batteries like about 20C weather temperature and IIRC self-discharge twice as much at 30c and twice as much again at 40C, plus at those temperatures the air-con is going to be used more so bear in mind recharging for summer as well as winter. Some recharge at the same time they swap to or from winter tyres. I always recharge to the Ring showing "FUL" even if that takes two sessions as the VW battery computer system only goes to about 80% to allow for regenerative top ups from braking and the battery will appreciate going to 100% even if the computer system will have it back to about 80%. Less wear on the battery means less work and wear on the alternator as they work with and for each other. HTH. Good luck.
Hello from Sweden
Hi, welcome Fredric. Sorry I don't have a clue about towbar wiring but see you have posted in the Fabia Mk3 forum, if you don't get a reply there or see any relevant threads with a search (via Google back to Briskoda can often work best) then also have a look or search and/or ask in the Audio, Electronics and Security forum. - https://www.briskoda.net/forums/forum/7-audio-electronics-and-security/ HTH.
Warning Lights
Bold italics added to highlight what I put before you continue with your mistake. Spot the similarities. I was referencing Ootohere's post where he's put up the driving info for the filter from the 'Owner's Manual', something I often do but Ootohere had already done this. I hope you're not trying to jump on to a running bandwagon and tripping yourself up but just making a mistake or two as I do many times a day. 😁
Battery Coding question
I'm a bit lost, did you charge the new off the car before fitting it to the car or charged it up after fitting to the car (following the instructions in the Owner's Manual and charger maintainer manual. VW computer system only want to go to about 80% charge leaving room for energy recovery from braking to charge the battery, part of VW's pretence at more fuel saving and lowering emissions on large, heavy cars with over-sized wheels and tyres often only carrying the driver or one passenger. Then you are trusting two computer systems for a read out. On a modern car the battery is very low when it has difficulty starting the engine, by this time the car's computers would be moaning and throwing up warnings and unseen error codes and probably giving all sort of unexpected issues. Before you connected the battery did you check the terminal post clamps were clean on the inside or clean them if required, battery terminal posts were clean, the terminal clamps were securely fitted to the battery terminal posts. Have you checked the voltage from the alternator with engine running. Do you have a constant drain like an added device to the car which remains switched for long periods when the engine (is and) isn't running. Have you checked the battery 'coding'. For some comparison, at 2-3 years old when I connect the 4-amp charger to the 60 Ah AGM battery in my wife's car (the one 'coded' on 25/6/2021 above) it took about 4-5 hours to top it up when it's wasn't really low and about 14-15 hours on a cold winter's night when it's was a bit lower but higher than most would bother to recharge it.
Heater windcreen - how do I tell if it is an original screen
I'm not an expert in anything so I'd check with other Mk3 Octavia owners on the forum on this site what makings they have on their factory original heated windscreens. I see the VW AG but no VW or Škoda emblem or logos and as Berisford has pointed out it seems the same as that one on the Polish site which has it as a "SIESCAM" / SISECAM which might be perfectly good heated screen and possibly a supplier to car manufacturers but I've no idea or if they supply to VWŠkoda with a Škoda emblem. As well as asking other Mk3 Octavia I'd test the screen heating in same or similar way to Geoff's suggestion. Apologies to @s88urd i missed your post and so just echoed what you had already put.
- BCM module
Skoda Fabia mk3 Airbag light
If you've not already done so you could look those codes up on the internet and see video for general information and possible routes to fixes. Or depending on how far you want to go yourself have a look at the diagnostic techniques this chap uses, there are plenty of others but to me this chap seems thorough and admits when he makes mistakes and shows real world working. - https://www.youtube.com/@mrautoservices7354 HTH. Good luck.
Mileage
AG Falco looks after his cars far, far above average., I too would certainly buy one of his cars if I wanted that type of car. As a non-VW or VWŠkoda fan whose wife bought a 2015 Fabia 1.2 TSI 90ps SE 5-speed manual at 18 months old (10k-miles) I can give you my experiences with that and very general info from what I've read on Briskoda of later Mk3s. Current mileage is something over 70k-miles (I forget figure). 1.2 (4-pot) engine is fine, VW 4-pots have always sounded a bit rough to me and I'm used to BMC/BL engines of the 60s/70s and no doubt the 3-pot sound worse but the 1.2 90PS is very capable. Normally there's just the one or two of us in the car but the few times there's been 4 (reasonable weight) adults in the car the extra weight has been noticeable to me a bit (as a previous driver of cars much lighter than lardy modern cars, particularly VWs) but still very capable. There are various sounds from the engine bay at various time but if you have a VWŠkoda already you they won't matter to you. On my wife's car and other earlier Mk3s the front dampers are poor quality and "mist" oil potentially just about from brand new, well that was the case with the replacement dampers the Dealership fitted (to replace the factory originals that "misted" enough to fail their MoT at 6 year old and 41k-miles). There has just about always been noises from the underside when going over traffic calming and up and down potholes, very bad on my wife's car in the very cold of winter, others have had the same and spent money, time and hassle on unsuccessfully trying to resolve it by replacing obvious parts so I've not bothered and it passes MoTs (not that MoTs mean that much as you possibly know). Interior fabric on my wife's car isn't the best quality but it's holding up fine. The UK VWŠkoda cambelt con was dropped a couple of years ago (too late for us unfortunately). Brakes and tyres won't be factory at 100k-miles so that's just usual s/h car stuff. You could look and see which models and years had the fuel rail bolts shear I can't remember it being on the 1.2 but I could well be wrong. There was a battery recall which I think would be more about VW ballsing-up the battery program rather than any battery. The newer the car the more important maintaining a reasonable battery state of charge becomes if you don't want warnings and a short life to the expensive battery. Just prior(?), during and after Covid years radio quality seems to have dropped and perhaps other issues (starter relays that doesn't like the cold on some 2018(?) 2019(?) models. Throttle body issues on some others - see the threads and posts on here for details. It appears to me the Mk1 Fabias were well made then general overall quality drops off with the Mk2 and later Mk2 and perhaps more so with the Mk3 but that's not to say the Mk3s are bad cars generally overall they are good within reasonable expectations (but I'd always think to look for an older Toyota or Honda for the same money if I ever wanted such a car). With a turbo it's history particular what VWSkoda call a "service" and their "maintenance schedule" timely work to these would be a minimum standard (rather like an MoT) (very, very few people would work to AGFalco schedule in my decades of experience). I changed the "filled for life" coolant on my wife's car and would do so on a 100k-mile car and I changed the manual gearbox oil on my wife's car and would certainly on a 100k-mile car unless it was under say 5-6 years old. I use a bit better oils than VW suggest and my wife noticed an improvement on the gear changes. The engine also now benefits from better oil now I'm able to do those too. As always you also buy on condition and be aware that a car with good cosmetics could be a poor runner or hidden faults and a scruffier car could have excellent mechanics, electrics/electronics. HTH. Good luck
Warning Lights
I can understand your your loss of faith in the car, and I'm no VW fan, but things might not be anywhere near as bad as you might think and very easily recoverable at no real monetary cost (little electric, some small amount of petrol) Modern cars don't suit short journeys and infrequent suitable use - but that's what many of them get so adding in things like motorway or spirited back roads driving and very occasional preventative battery recharges can avoid some issues. The state of charge of the battery can be too low for the car's computer systems even if the headlights seem bright enough and the engine starts, the engine will start even if the battery is very low, far below what the computers systems like. All sorts of unexpected warnings, unseen error codes and issues can be from just the battery being too low for the car's computer systems there are numerous threads and posts where this has been found to be the case. The stop/start not being active when it should is the first warning that the battery state of charge is too low, if this is missed or ignored for too long and/or too often then the battery gets progressively further from full recovery. Driving the car even on the motorway nay not always be fully sufficient as it depends on how much electric is being used and/or or low and worn the battery is. Check the state of charge of the battery, better still fully recharge the battery to 100% using an appropriate battery charger maintainer following the instructions in the car's Owner's Manual and for the battery charger maintainer. Lower amps charger (say 4-amps) will take longer to fully recharge the battery but generally will give a better recharge and if you can't fully recharge the battery in one go take two or three. Or it may be better for you to just have the reassurance of buying a new battery (and getting it 'coded in correctly). Personally I always fully charge the new battery to 100% before fitting to be sure that is the way they start when first fitted to the car (it shouldn't take too long as a new battery charged off the car). Just getting the existing battery to a reasonable state of charge and following the driving instructions for the particle filter should help you at least in the short term. And you certainly want to check when the spark plugs and engine oil filter were lasted changed but that's just engine more important obviously is service and maintenance of brakes (fluid, pads, discs, tyres) and tyres (tyre age, wear/damage (tread and sidewalls), wheels). Good luck, let us know how you get on.
Req. help with Felicia (Fun) 1.6MPI Clutch Cable
Unfortunately I have a few decades experience of the English motor trade and a lot of the experiences aren't good to bad or very bad and even cons so that's why I started doing work on my cars myself as often I could do a better job just because I cared more to and I'm mechanically inclined or can do brilliant work plus I loathe(d) working on our own car(s) (but don't mind doing small jobs on other people's car). If you need any general advice on working on old cars I can offer very general advice, one point is always take your time, be patient and double and treble check before, during and after doing the work. I once fitted a clutch cable to my FIAT in a mate's garage and when I asked my mate to start the car so we could check the clutch worked OK the car leapt forward as I had put fitted something back-to-front, good thing it was a very short car otherwise it might have hit the rear wall. Goes to the old adage "measure twice cut once", or in my case check thrice, obviously I none neither or well enough that time. Good luck, let us know how you get on.
Fabia 4 Start/Stop battery
Interesting this ties in with what another poster has put, with a different VWŠkoda model, with EFB+ and 49Ah. My wife's 2015 Fabia manual, 90ps, SE the batteries were offered at 60Ah to 70Ah, perhaps another reason the batteries don't last as longer on the more recent cars - or for VW fans perhaps the EFB+ batteries are so much better than the previous EFB batteries they fitted (and/or perhaps VW have improved their alternators and starter motors).
Then don't, save your time and energy. That's because you left it too late. If you hadn't had left it so long you could have got many more years reliable use out of the battery with very, very little, very very easy (not even) work. Why did you bother with the Ctek in the first place. Yes I will, thank you. Yes you do waste money when you don't have in regard to the $400 batteries. Who said it wasn't(?). Not necessarily - but I put up the vid to hopefully amuse you and build a bridge but it didn't work, my mistake. Up to you what you do, forget me but if you tone down and turn down some of the stuff you put you could possibly get along with more posters more often. You can ignore me and I'll try to ignore bits you put I don't like, 'ow's that for a deal.
. . . part two . . . VWŠkoda 'Owner's Manuals' used to put to change the battery at 5 years and later I believe changed to 4 years (VWŠkoda car warranty is only 3 years in UK) but some owners/drivers only get to just over 3 years before they (think) they need to change the battery. Other owner/drivers get many more years out of the battery with very little (very easy effort). The 12v battery is one of the most oversold car parts because of batteries being changed prematurely and very prematurely but it's each to their own if if someone wants to buy an expensive battery and possibly also pay for the 'coding' that is their choice just seems a waste of money and resources particular if it's also through a lack of knowledge to make a more informed choice. But I do fully understand that sometimes it's personally better to pay out to avoid hassle, "hassle money" was a term a mate used in his business. Unfortunately here many that used to use the old across the terminals gauge would sell you a new battery even if the one you had was OK. @Exkiwi for you if you're interested, see from 6:42 on this video for a load tester from before the days of H&S, the amusing but always informative John twist, dealing with very old British cars in the US of A, some that used double 6v batteries to get 12v, different case materials and other stuff from way back - but the principals remain the same. - https://www.youtube.com/watch?v=UnbQ2G5K2zI
Sorry but that's not correct. It maybe an indicator of the car's owner/driver use, abused and/or neglect of the battery through not knowing and understanding or caring, that's the more likily. A battery is getting quite low, or has been taken quite low, to get to the stage of Xmas tree dash lights but often a full(to 100%) recharge of the battery using an appropriate battery charger maintainer and following the instructions in the car's 'Owner's Manual@ and charger's instructions can revive the battery for much more reliable use. Of course if the battery has been flogged too much and or too frequently then the chances of useful revival diminish possibly to a point of no return. The stop/start is the first thing to not work and this is a first early warning, if ignored continuously then things progress badly. Far too many owner/drivers think if the headlights seem brighter enough and the engine starts then the battery state of charge can't be too low for the computer systems but by the time the battery has difficulty starting the engine the battery has been flogged badly and if the engine can't be started by the battery unless it's a one-off drain t he battery has been flogged to near death if not practical death. VW . . . (rocks, press the wrong key again, part two to follow)
I must admit I forgot you were outside UK. In the England at least the Dealership doing any work isn't always as reassuring as it should be. As I put before much of the data entry for the battery is for the benefit of VWŠkoda rather than strictly necessary but again if I owned or worked for a Dealership or garage (not that I ever would) I would want to give my customers (who I'd not view as something I'd stepped in that wasn't cleaned up from being deposited on the ground) some reassurance by following factory protocol as much as possible. Perhaps "NOT" and "NoOESNorm1" are Dealership protocol(?) - as longer as the battery charges correctly via the VWŠkoda computer system and charging system that's all that really matters here. I put an AGM battery into my wife's 2015 Fabia (even though it doesn't have the correct level of heat insulation for engine bay AGM fitment) and even though we don't often see minus Celsius and very rare double digit minus Celsius you may have seen I very occasionally fully (to 100%) recharge the battery with a "smart" (they are not) charger maintainer as the car gets lots of very short journeys. Batteries like about 20C and self-discharge IIRC twice as much at 30C and twice as much again at 40C (we once had 40.2C where I live in England) so this needs taking into consideration too, plus of course in warmer weather the air-con is more likely to be used more. Battery / charging issues are the number one cause of breakdown callouts in the UK it is very, very rarely a faulty battery but usually a charging problem or just driver/owner use / abused / neglect of the battery and the more modern the car (and to some extent owner/driver) the more likely "battery" problems. (I've put up various threads on this but can't remember how to get to them at the moment, slowly car owners are learning, and remembering, how important the car's 12v battery state of charge and health is to particularly more modern cars. Good luck.
82Ah, you use a lot of electricity. 😄 Is that correct to the battery fitted (not 72Ah as in a previous post?). For the sake of reassurance if I was a commercial concern I would leave the battery three letter code as VWŠkoda have it (JBC?) or use one of their other three letter/character codes (you had Varta? (VAO) and I would have have 1111111112 if it was 1111111111 from factory. Perhaps the computer system objected to something there but with car use it settled itself, as long as the battery is an AGM and 82Ah(?) things should be fine but if you wanted to enter the (correct) three letter/character code for the Varta battery fitted and certainly correct the 82Ah if your battery is 72Ah, leave the battery serial as it is.
@Exkiwi things are different in England at least, if not UK, to Australia, New Zealand and Tasmania (as well as Europe and USA). Generally if you wanted to do a load test it would be a DIY one as very few old school battery load testers are about and I doubt they're used commercially, it's modern computer battery tester electronics now. (Of course now someone will say about some old village garage in the middle of nowhere that has an "uld skool" one that can be used if Fred is working there that day. 😄) A chap from Tasmania used to say to go to a "shop" to get this and that done, and borrow tools! and I would explain that I live in Northamptonshire a county of motorsports engineering yet I'd have to ask an older mate who he knows that might know somewhere doing the stuff the chap from Tas would just nip to a "shop" for. Time and patience will also tell how much the battery holds and performs but many car owners have very little stock or out of stock of one, the other, or both - and no access to a load tester or knowledge or inclination to do a DIY test. This is a general (VWŠkoda) car owner's site and whilst there are some specialists members (not me) the majority aren't so they only want to go so far before going to a Dealership. garage, mechanic or auto-electrician (even though often they themselves might do a better job than the professionals they pay, in England at least, from my decades of personal experience).
You could look for the Škoda emblem/logo on the screen glass, an aftermarket screen will not have this but other marking. A Škoda replacement screen even though not factory original would also have the Škoda emblem/logo of course, but you'd hope if someone had gone to the trouble of fitting a VWŠkoda part that it'd be the correct one (you can only hope with the English motor trade).
