Everything posted by marineboy
MySkoda App.
I too find the app useful, particularly as I have a kind of OCD issue where I sometimes need to check if I’ve locked the car. Re US gallons, surely you can specify US or imperial units in the settings?
Servicing - Definitive Answers
I’ve just made an appointment with Skoda dealer for my first service, which will be at 10k miles and 2 years. I was asked re pollen filter and brake fluid change and declined both. Pollen filter you can change yourself in 5 minutes. Re brake fluid, I had my previous Golf for 9 years from new. When the warranty expired I got it serviced at a long established and well respected independent garage. I asked re brake fluid changes and the proprietor said he would do it if I wanted but he had never changed the fluid on all the cars he had ever owned and regarded it as unnecessary. When I sold the car after 9 years and 70k miles the brake pedal feel and braking performance were as good as new. But it’s your money and your choice.
Assist systems not working
I thought this would be the case. Started the car this morning and no issues. I knew it was unlikely to be a sensor cleanliness issue because I’d just spent 3 hours washing it 😀
Gave the car a thorough wash and wax this morning. Got back in, ignition on, warning light and message. “Front assist unavailable, sensor impaired” None of the front assist systems are working - ACC, front assist, lane assist. Any ideas whether this is a software glitch which will clear itself eventually, or a hardware fault in either the windscreen camera or the radar sensor? Or something else?
Handbrake position
I have the Kamiq with DSG. I never use the handbrake, just leave the car in Park. Being DSG means hill starts are a doddle. Though I do apply the handbrake on-off every week or so to stop the mechanism from seizing up.
Armrest Height Extender Solution
I couldn’t link to that site but having found the armrest too low for me shortly after buying my Kamiq I made my own solution. Ok, it’s a bit Heath Robinson - a bit of softwood with a layer of rubber on top, fixed with double sided tape for easy removal if I sell the car - but it works and you can’t see it when the armrest is down.
TPMS
Interesting comments re the amount of pressure drop needed to trigger the warning, ie 6 to 8 psi. The fact that my offending tyre was only 3 below the others (and possibly a bit less than that), and there has been no further reduction in pressure over the last few days, leads me to think that the warning was triggered either by a bit of debris on the tyre or sensor or a software glitch.
TPMS
Yes I did check the other tyres. All at 36. And I’ve just checked the suspect one and it’s still 36. I’m thinking perhaps that it does have a VERY slight leak and over the last few weeks since I checked all the tyres its pressure has reduced to the point where it triggered the sensor.
TPMS
Yes I get that but why just one tyre? Or did you mean the sensor on that axle?
TPMS
Out to shops today and shortly after setting off got message ‘front right tyre loss of pressure’. Stopped and checked the pressure, 33psi (normally 36). No obvious nail/damage. So continued (carefully) to shops and back home when I jacked the car up and had a good look all round the tyre. Again, nothing to see. So I inflated back to 36 and left it. Just checked it again after 3 hours and no change. It’s possible that since I last checked it the tyre has lost pressure as they often do over time. Re the TPMS, I’ve had one or two false alarms in my Golf over my 11 years of ownership. I think that it works via the ABS sensor and can be activated if a tyre picks up some mud which alters its rotation characteristics but there was no evidence of that. Has anyone had a similar experience?
Which Kamiq?
+1 for the DSG, particularly with the 1.5 engine. So relaxing and comfortable to drive. As for rear legroom, I would say it’s surprisingly roomy for a car of this modest size. I’m an old geezer and had cars since I was 17 - my Kamiq is the best I’ve ever had.
Engine running ''bongs''
To my mind it makes sense to warn a driver that he or she is leaving the car with the engine running. No doubt complaints about nanny stateism were made when seat belts and air bags were introduced.
Downloading map updates
The only advice I’d give, if you have an iPhone, is to ditch the Skoda nav for Apple CarPlay and Apple Maps. Updates continuously in real time, shows traffic holdups etc.
SatNav issues
AFAIK Apple Maps in the car uses its own GPS. Won’t be affected at all by any car issues other than if the link from the phone to the infotainment isn’t working properly.
Boot liner for ‘23 Kamiq
I would say mine is more rubbery than plasticky or foamy. I doubt it would stand up to having builders’ rubble chucked in the boot but for normal domestic use it’s perfect.
Water leak - how to remove boot compartment trim
Not got round to taking it to the dealer, I’ll leave it till the next (first) service in June and mention it then. But the duct tape bodge is working fine.
What is your favourite thing about your Kamiq?
Re the green moss, I use a toothbrush with a bit of washing up liquid and an old credit card to clean out any stuff between the seal and the glass.
- New car, software update
November Map Updates ?
The other big advantage of Apple Maps is that I can use my iPad or iPhone to save a new destination as a favourite. It saves the hassle of having to enter details on the infotainment screen in the car.
And on a flat road or slight downhill
I find that going down a steep hill the DSG holds onto a lower gear even in auto.
Best car I’ve ever had (and I’ve had a few). Why?: So relaxing to drive Quiet Good seating position though some say it’s too low Good space in rear and luggage compartment Good acceleration with kickdown Great economy (have achieved 60mpg on a long run on A roads) Supple ride but no undue roll Infotainment excellent with very few glitches Great toys - Apple AirPlay, heated seats, rear view camera, and (my favourite which I specced as an option), heated steering wheel 100% reliable so far Long life servicing I think you’ll like yours
New to adaptive cruise control, questions.
Fair point, I was aware of makes like Audi, MB etc which linked ACC to the sat nav and traffic sign recognition and adjusted the speed accordingly but I didn’t know that any Skodas had this capability.
ACC won’t slow the car through curves or any other road layout which needs a reduction in speed, eg a blind crest. It responds only to other vehicles in front which the radar/camera detects. Not sure what you mean re a car at the lights. The ACC with DSG will actually slow to a stop behind a stationary car and then accelerate back to set speed once it moves off. I love the ACC, it makes longer drives so relaxing. The only slight criticism I have is that it is a trifle slow to respond in some cases, eg when it slows the car as it approaches a slower car in front and when I indicate to overtake there is a slight hesitation to kick in. But this is a minor irritation.
