Everything posted by Dooge
Doug's Race Blue VRS wagon
Finally fitted the rears! Undoing the Triplesquare bolts holding the caliper bracket on was not going to happen without removing the shock absorber, which was easy enough to remove and allowed a decent breaker bar or similar to then fit under the arch and be used without spatial issues. It was very easy to replace them both and all fitted very well.
Interior console Lights colour change possible Octavia 2016?
Not sure on changing colours, I know VW and Seat are set to red, my MK6 Golf GTi was anyway and so is my wife's Leon. I like the idea of red LEDs but not at the expense and hassle of changing it! Pretty sure my lights are white though, mines a 2015.
Correct usage of DSG shift stick
Until @aubrey pointed it out I didn't know the clutches work in reverse, everyday is a school day!
Nobody has ever explained that to me, thanks very much! I've noticed that after putting it into drive, if I let my foot off the brake or go to accelerate too quickly it jumps or stutters, like it's selected the wrong gear. It doesn't do this with start stop. I've never figured out why it does this but otherwise seems healthy and has been serviced on schedule.
Aftermarket Wheels: Offset and Width
If this is a square setup (same front and rear) the fronts will sit quite a bit out. Willitfit.com says the outer edge of the rim will be 18.7mm further than stock. Generally, most people put 15mm spacers on the front and 20mm on rear. I personally think 10mm front and 20mm rear provides a nice look. Here's mine with 20mm rear spacers and 5mm front as an example (mine is lowered 20mm all round) and you can see the front doesn't need loads more. If you can go for a staggered setup rather than square I think you'll get much better results, otherwise I think it'll look overly dominant at the front. That is just my opinion though and depends on the look you are going for.
I was always told apply brake, switch gearshifter to neutral (to take any load off the gearbox), handbrake on, foot off the brake, gearshifter straight to P. Probably a bit overkill as if you have your foot on the brake it won't be moving anyway. I also switch to neutral at lights or any reasonable amount of time stopped for example, again probably overkill but as I do alot of short journeys I'm trying to get as much life out of the clutch packs as possible.
I then fitted the fronts, which was an easy process overall. I undid the brake fluid reservoir and used a caliper tool to push the piston back in. On the drive home, I broke gently for the first 4-5 times then built up to 60-40mph and 70-30mph braking to bed the pads in. They feel sharper than they did before and overly happy with how they feel. The car is also going on for an Inspection 2 and brake fluid change when it has its MOT. Hopefully they don't fail it on the rear discs. Bottom ball joints are still on the list, but I have insurance soon and thinking I'm going to be stung more so than other years.
Small update - ordered some new brake pads front and rear and brake discs front and rear from Autodoc, just over £300 for all which I thought was very good! All for MOT which is due on the 28th, the rear discs were an advisory for being rusty last year. I went with TRW pads (which I think are OEM) and ATE coated discs. These have a matt silver finish which is corrosion resistant and from what I can see is better than painted equivalents. Although I thought about a black finish I'm sure it'll look naff in no time. The pads are all black with a patterned rubber coating on the back, presumably to stop any squealing or vibrating noises. Unfortunately I bought a Triplesquare set for the rear as the caliper carrier has to be removed but the bits were too long to undo the top bolt, doh! I did pull all the slider bolts out, clean and regrease which showed that a few needed replacement with rubber bushes breaking and pitting from corrosion.
Buying used estate - expectation management
It's difficult to say, Octavia's in general have weaping front shocks by year 6 or 7 or a decent bit of mileage, front topmount issues, rear tracking issues on the ones with independent rear suspension. From what I see the 1.6 TDi is ok but all the diesels suffer from high oil consumption, DPF issues (especially short journeys or higher mileage cars) EGR cooler issues and water pump issues but this is wholly dependent on alot of things. If buying diesel, I'd buy one with motorway miles on, the engine would have burnt cleaner and the DPF might not have performed as many regens. The mk2 version of the 1.2 TSI is a good performer but maybe a bit underpowered (wife has it in her 2015 Seat Leon) The 1.5 TSI could be a good option but I haven't heard much about it good or bad. Finally, DSG maybe a good option, especially for motorway mileage cars and as long as it's been serviced at the correct time. The wet clutch boxes need servicing every 40k.
6 Year Refresh, vRS 245
Another on my list is rear ARB. Just about to do discs and pads at 92k but this will be the second time they've been changed. They aren't needing to be changed but are worn and are very rusty. Suspension is a tricky one, alot I have found wears together. Do it all or nothing at all. I did shock absorbers, topmounts, ARB links and springs. Definitely worth doing bottom ball joints and rear D wishbone bushes.
Octavia MKIII VRS damper advice.
OP, that was my thread I believe. After putting several thousand miles on all is good (bar what I believe to be the topmounts being sub-par) I intend to replace the rears as I only did the fronts with topmounts, ARB links and outer tie rod ends. I also fitted Racingline 25mm springs. Overally I'd say stiffness is up 15-20%. This doesn't worry me as I often thought the ride to be crashy and not comfy, overdamped for sure. Will B4s or B6s help with your issue? They will feel better, but without replacing all of the components around it's just a small update. Make a list and do it all together. Poor roads need compliance from suspension, often people fit stiffer thinking they will get more control and end up with less due to tramlining, less given, etc. But, the B4s with slight lowering springs is fantastic on fast B roads and really makes it better than stock to drive. On rough roads I don't know if this will be the case. Is it a Lotus Elise? No, but I had fun with my mates E63 AMG touring last year around Wales, he left me on the straights but I kept up in the corners. It did make me think the rear was VERY wallowy and would benefit massively from a stiffer rear ARB. I still plan to fit a second hand MK7 Golf GTi rear ARB, these are 21.7mm over our thinner ARBs (18 or 19mm I believe) these GTi ones can be had for nothing really, I can't justify a few hundred quid for a fancier ARB. I'll do this with rear ARB links and rear shocks at some point. The Club sport one linked above is the same outer diameter but is much thicker than a stock GTi one. Let us know what you decide!
Estate suspension sounds like creaky bed
The multi point rear suspension is common to creak across all MQB platforms I believe, doesn't mean it's right. The concentric bolts for the adjustments sit inside steel sleeved bushes so often rust together. Not sure if this is part of the issue but I know I greased up a fair few bits last year when fitting new springs and it did sweet F.A.
Town driving Skoda Octavia Vrs petrol is this right?
2015 VRS petrol estate, DSG. Lots of 4-5 mile journeys with 40mph dual carriageway and 30mph town driving, I got 260 miles out of my last tank.
How to inspect : Rear Sub-frame is corroded but structural rigidity is not significantly reduced (6.1.1 (c) (i))
Is this a VRS or standard model? Multilink suspension or torsion beam? My 2015 has a corroded rear subframe, though it's never flagged on an MOT. If it's multilink chances are the adjustment bolts for camber and toe are seized too as this is very common. The complex part is getting everything down to do a proper job. Its almost as easy to buy a second hand part and renew it but definitely not cheap. When I set up a topic on it awhile back someone said they have done a few for customers and they charged in the region of £1000. This was fully rebuilding, new bushes, arms, etc. As above though, without seeing it I can't see if it's serious or not as even opinion by MOT tester differs.
Which bolts to replace? - Brakes
Hi all, I am going to be replacing my discs and pads this month, I have settled on ATE discs and TRW pads, however I have read that the rear calipers use stretch bolts in certain places and that's there's 2 lengths. Does anyone know the correct part number? It's probably the same as most Golf's and Audi's but I want to make sure I get the correct part. I've had a look on Autodoc but this just seems to be the sliders and associated bolts, is this all that is recommended to replace? Whilst it's all apart, is it worth replacing the slider bolts and rubber covers anyway? I doubt they have been done in 44k / 5 years since the brakes were last changed. 2015 VRS TSi DSG, 340mm front and 272mm rear discs. Thanks in advance!
Luke's 3.5 vRS
That's really interesting, since fitting Febi-bilstein topmounts my car clicks lock to lock. It did it before, but does it more now! You're right about gearbox maintenance, really won't hurt for the fee hundred it costs. Not like you are doing it every service.
Just check how many wires you have on your wiring loom, not the old switch. My switch has 10 pins but the loom has 9 wires. The switch I bought is part number 3V0941431 and seems to work perfectly.
Very, turn it to off position, push it in, turn it right and it'll sit at the auto position. This releases the catches and it slides out. For the mirror mod I believe anything facelift can take the Golf frameless mirror. Before this the bracket is different, but it would have been a nice mod to do.
A small interior mod, a Superb MK3 light switch with added chromey bling. It is white and green instead of all green. It was all of £23 from eBay, I just confirmed I matched up functions and number of pins. I started looking at other items, such as Golf mirror adjuster, window switches and facelift climate control. I also looked at a frameless Golf interior mirror. I decided against all of it due to the level of work and that the mirror won't fit due to the connection. Also, I seem to have a combination of white and green already, my steering wheel buttons are white but everything else is green. I also really need to get other bits sorted so I'm looking at ball joints for the front end. Does anyone know the ball joint size for VRS'? On Autodoc there is multiple sizes, M12 x 1.5mm or M10 x 1.5.
Replace old front shocks on combi 2.0 diesel, are vrs shocks a straight swap
If you want some free VRS springs your are welcome to mine, just cover postage. They have come off a car with 55mm struts. As above, struts are in two sizes, 50 and 55mm. VRS struts will make it feel stiffer so depends on what you are after.
Headlight switch - 9 pin or 10 pin?
Hey all, I am wanting to install a headlight switch with a silver trim and keep the green illumination. Simple things to smarten up the interior. I figured I could get this from a MK3 Superb. The issue I am having is I currently have a 10 pin switch and I can only find 9 pin switches in the configuration I would like. I've included photos below for reference. I can't imagine VAG putting a pin in if they don't need it, but what are the likely differences/what would I be missing? Mine has Auto wipers, front and rear fogs, winter pack, non cruise radar, satnav, etc. Thanks in advance.
Skoda Octavia MK3 5E brake pad sizes
@Carlston, thanks for the useful information. I'm looking at refreshing my brakes as they are due a change soon. From your experience are you saying the ATE coated rotors are better than the black painted TRW rotors? I like the look of the black but know that within a few washes it will be covered with dried rust coloured residue. I'd like the bells and edges to stay as non rusty as possible, would you recommend the ATE discs for this?
Interior light doesnt come one when opening
Common problem, the circuit board has probably burnt out. The rear lights go through the front light unit so they all turn on together when the doors open. It's becoming increasingly common on Octavia's and is already common on mk5/mk6 Golf's, Audi A3s, Passat's, etc. It can be fixed if you know what you are doing or buy new (over £200) or just live with it.
That's disappointing! I think just like DSG sometimes it's luck of the draw with the Haldex although more of the time to fails due to someone's poor maintenance. This is why I change oil regardless of little mileage year on year and I'll get my DSG oil changed more regularly than the 40k. I hope you don't have water pump failure, it's something I'm always thinking about as mine has never been changed and it's on 91k now. I wish I had got everything for the suspension and changed it in one but I was impatient and wanted it lower. Still looks good though 😁 I also need new discs and pads, not desperately but can't justify mapping before suspension and brakes really. I'll only stick to OEM units as for most of my driving they seem ok. I reckon dealer prices are going to pull my pants down on that though.
Rear Anti-roll bar upgrade for MK3 VRS
I've only driven with +5mm up front around town, not really in anger whereas I have with chucked the car around the Welsh hills with just the +20mm on rear. There's also a big difference between wider front wheels and widening the track with spacers. I don't know everything when it comes to handling though and it is just my perception. These cars from factory are overly soft at rear so maybe making it wider at the rear than the front helps counteract that slightly? This could also be why they went to the effort of changing the rear hubs on facelift cars, I can't see them doing it just for aesthetics.
