Stonekeeper
Everything posted by Stonekeeper
  1. Thanks, have done that.
  2. So is it better to not activate it on any then i can use whichever app is the cheapest at the time?
  3. Stonekeeper replied to Nikg's topic in Skoda Karoq
    I bought this, no problems at all with my usb stick.
  4. Bienvenu. La plupart des messages sont en anglais. J'espère que cela ne vous posera pas de problèmes
  5. It might be worth checking the files held on your computer first. Assuming you didn't rip them straight to the usb stick Then redo the usb stick . A folder for the artist and a folder within it for each album. My preference would be a First folder with "music" as it's title as the first after F: F: Music like @HappySam suggested
  6. check the contents of the folder and check track data as earlier described
  7. @wyx087 Quick question regarding plug and charge. I have the skoda powerpass and an electorverse app plus the Tesla app. If i activate Plug and charge on the powerpass app and the Electorverse one . Or if i only activate it on one but decide to use the other later would the one with plug and charge activated charge me as well? How do i ensure only one bills me?
  8. The previous versions tab is not for that purpose I don't think. I have amended many and not resulted in a change there. Did you see what was wrong? The screen shot looks like the "folder" properties" not the track
  9. Carrying on from where we were up to. On your computer look at the file for a track. In windows media player for example you can right click and search for file location and go to it. If you already know how to list the tracks in windows Right click on the track, and click on "properties" you then get a box with general details with the file name (usually the title of the song). The top line of the box has options to look at "security" "Details" "previous versions" if you click on "details" This shows the actual entries in description and Media in the meta data. For the tracks that you say show something different on your computer to what the car says. You may be able to see where the car gets it's info from. As an example if you changed the file name on the general box the meta data would not change. What you are experiencing tends to happen when the user creates a folder on their computer and gives it the Artist name, then puts folders within the folder for the artists albums.Then drops files with the tracks on into those folders that have been ripped from cds and asking Windows media player to locate album info and album covers from the internet. WMP sometimes finds the wrong album for the data
  10. For the folders you created on the card did you use the Artist name or the album name. Maybe the meta data for the track differs from what you see in your computer music application. Happens in windows media player on my computer.
  11. Is it possible the media system is re-sorting into alphabetical order? I will have a dig and see if there are settings for filing.
  12. The float on the sender unit is on a very thin arm and could very easily have been compromised if that was where the fuel was accessed from Make a note of your mileage and fuel filling and see if it ever starts to drop the needle.
  13. I can answer points 2 and 3. When you get the car you set the limit you want the car to be charged to. If you always want 80% as the max.You set it and forget it until the day you want to charge more, When you go into the charging screen and change it. Then change it back afterwards. K is a slide bar that you movee to where you want.
  14. I have the myskoda app for my car and in the "inspect" section you can download the digital certificate. This contains a graph for mileage. So for example i can see the graph started in nov 2022 It also contains a digital service log that shows on 13/12/22 it was serviced at 5 miles then it's PDI was done by the dealer on the 16/12 when the odometer was reset to NIL Doesn't give the exact day of production but it must be close for me think it was built in November? It also gives you the manual for the production run i.e is the issue date of the manual. Mine is 29/8/22 So for another ball park thought My car was built sometime between 29/8/22 and 11/22 The registered date has little bearing on when the car was built. My car is a 72 plate registered in January 2023
  15. If it happened immediately after changing the battery and it appears to affect systems in different circuits i would check the Earthing points around the battery.
  16. I understand the problem was found to be Is that correct?
  17. Because 'Electricity of France'), commonly known as EDF, is a French multinational electric utility company owned by the government of France. Our Govt sold everything off and passed Billing on to Shareholders and Business for profits.
  18. I always put my DSG in N if going to be sat still more than a few seconds too. I know it is said that you don't have to because nothing is happening but: When you put it in N the engine tone changes so there must be a difference? In theory if your foot is "Firmly on the brake pedal it should be ok?
  19. Some good deals on the 60 at the moment I think there is a facelift or new model due soon https://www.autotrader.co.uk/car-details/202409164090753?sort=relevance&twcs=true&advertising-location=at_cars&make=Skoda&model=Enyaq&page=3&postcode=m45 6dj&fromsra
  20. When i was looking before buying mine i found this https://www.zap-map.com/ev-guides/model-charging/skoda-enyaq-iv
