Everything posted by Cedwing
Order and delivery times for MK4 Superb
Ordered at teh dealer July 30th. Currently allocated week 48 for build. L&K 2.0 TSI Estate/Combi with HUD
Software failure not so Superb
If you read the Passat forums it has the same problems. As does Kodak and other VWs built on the same platform.
Superb Mk4 Owner's Manual Now Available
Did anyone find a PDF?
Superb Mk4
Finally got a build week of 48 from an order at the start of August. How long does it take from build to UK delivery?
Trim Levels
Enjoy the new car. Still waitng for my build slot target is for end December. Agree that with eBikes a tow hitch rack makes sense.
Trim Levels
From my perspective only if you want/need most of the features. What is worth considering is the second hand value. Most valuations are based on the model/ trim level, not the individual options added. So I’d expect an L&K to hold its value a bit better than an SE L with similar options added. So if you want a car with a similar spec to the L&K then it’s worth considering if the extra cost for the options you don’t want are offset by the resale value.
Superb Mk4
@Rifleman Have you got a manufacture date yet. I ordered at the end of July and still no news.
Superb mk4 Sportline launched
Be interested when it appears on the UK configurator. I like the carbon fibre interior. Not so sure about the gloss black external trim. I have a L&K order with the dealer but the factory haven't confirmed it yet.
MyŠkoda app - How does it work?
Does your car support connection over Wi-Fi? I know lot of VW group systems can. Try connecting via a laptop hotspot with a network analyser. I’ve always assumed the app works as you suggest but ny current car doesn’t support it. When I get the replacement I’ll try this.
Inputs and outputs
Still waiting on my order but from my memory of the test drive…. No SD card slots any more and only USB-C ports. So either get a USB-C to A adapter and a USB-C SD card adapter. Or move to playing music through blue tooth,CarPlay, Android Auto from your phone. You can get at the on line manual via https://www.skoda.co.uk/apps/manuals/models. Though there is not much detail. By the way when did you order?
Superb Mk4
How did you get the reference to set up Škoda connect? It would be good to try this out on my order.
New Superb Mk4 estate owner
It seemed on the demonstrator I tried that if you pushed the left directional slider all the way to the right and the right all the way to teh left it cutr off the rear air.
Superb Mk4
I went for black interior. I stuck with the default wheels. I've currently got an A4 which had a reputation as a vefry quiet e=interior and I think the Superb was similar. With the DCC Pro it was a smooth ride.
Superb Mk4
Also managed to find a dealer with an L&K demonstrator for a test drive. I had the same thought with the wierd square drivers display. I couldn't see the ugly corners when I was driving as the steering wheel blocked the view of them. The ribbed dashboard isnt to my taste but you cant have everything perfect. On a postive note the cooled seats were very effective in the heat we had on Monday. Have put in an order for an L&K 2.0 TSI plus HUD. Sadly quoted 21 weeks lead time. So it looks like a christmas present.
Nice looking cars. Did a test drive today but couldnt get the Adaptive Cruise Control to take notice of spped limit signs, Do yours change the cruise control target speed when you go into say a 30 limit?
PHEV engine
BMW i5 is available as an estate. But it's another step up in cost.
PHEV engine
Any PHEV seen in the UK yet? I’m interested to try one to see if it’s a good compromise towards electric drive. Other than ID7 I don’t see much in the way of similar capacity estates that are pure electric.
Superb Mk4
Interesting to see there is a 2.0l 4x4 petrol as well. I wasn't expecting that.
Superb Mk4
Looks great. Did you see if the dealer had any demo stock?
Superb Mk4
The UK brochure lists a USB-C by the mirror as standard.
Superb Mk4
I still feel the need to test drive before ordering myself. But I’ve never owned a PHEV before. I’m also not convinced about the rectangular drivers display under a curved hood.
Superb mk4 Launch info and video
The spec sheet I downloaded shows a WLTP range of 77 miles for the Superb which is not bad. I guess a Golf does better.
I built this example L&K spec up while the configurator was available. Yes its the 1.5 TSi + electric car-card-C99L98YY.pdf
It breifly appeared in the configurator this week but its gone again. Probably someone enabled the model too early.
Superb Mk4
Good to hear things are moving at the factory. It will be interesting to hear what you think of the performance of the 1.5 compared to what you have.
