Blue8793841
Everything posted by Blue8793841
  1. Nice, I've had the same problem with A3 in same area
  2. You will never remove all deposits, you should understand that?
  3. Pay around £7 on Erwin and download the manual for your car, should come in useful for future maintenance and repairs too.
  4. Doesn't sound right I'd call them and get it back in. Tell them it didn't make the noise before they did the work on it.
  5. Any photos? Can you see damage to the wiring?
  6. Sorry mine is an Octavia 5e5 manual, maybe the karoq just needs a bit more fuelling to shift the extra weight.
  7. Sounds like the starter is just spinning and not engaging the flywheel
  8. So there is a recall for it your not imagining stuff.
  9. Thanks I'll take a look.
  10. I'll try driving mine at lower rpm see how it compares just out of interest and report back.
  11. Was the kangaroo a recall? My car is 2020 how do I find out if it had been done, although I don't think it has as I can get it to kangaroo it accelerating very gently.
  12. I don't think it's anything to do with the cars I think it's your driving styles. Mine is fine always change down gear around 1250, then you got the grunt to carry on or pull away.
  13. You at least want a voucher or something for your next visit
  14. Don't be too rough with it as they can split. That's if it's not already damaged by being on an acute angle. Take it back and complain. I don't know how you could even forget to put it back on.
  15. It's breather pipe goes from cam cover to turbo. Remove engine cover and refit to cam cover. Has it had plugs in or work recently?
  16. Please can anyone help me with coding the drivers seat belt module? I've replaced the seat belt and there is a warning message on the instruments. Code in for seat belt not coded. I have snap on and autel tools to do the coding.
  17. Hi has anyone got the teron wheels in black or dark grey and can share a photo thanks.
  18. How longs it been going on? Not sure if it's only the smaller engines where the cam bolts work themselves loose.
  19. If there's no leaks then it must be burning it, probably turbo goosed. Could be other things like rings and valve guides/seals though.
  20. 05E198701A Repair kit You could try that as well as ceramic grease to help.
  21. Usually the turbo actuator/waste gate mechanism. Worse when cold preheating the gpf.
  22. Try doing a reset, press an hold the power button untill you see the Skoda logo then release
  23. What size wheels has it got on? Larger wheels give more feedback to the steering. Try driving one with smaller wheels see how it feels.
