Blue8793841
Everything posted by Blue8793841
  1. I got 4 contis for a good price and no complaints
  2. Heat gun could help but you'd have to be careful
  3. Did they replace top mount and bump stop too, I always lube the shaft and bump stop as it can stick and cause noises.
  4. Usually the guy that fitted them just slapped them on, never cleaned up any corrosion. Could also be a wheel bearing issue or sometimes worn suspension bushes don't help.
  5. You can change it so it displays in the instruments with the right kit
  6. Try a reset and see how it goes
  7. 20mph is a crap speed it's high for 2nd and low for 3rd
  8. So it's done twice the work of the original clutch? Check around clutch pedal/master cylinder for dampness. After that remove the gearbox and asses the clutch.
  9. £180 near me north east uk
  10. T-Roc drive a loc nicer
  11. No chance
  12. They are doing this on a lot of cars now, a money maker for them
  13. I wouldn't put XL on that car as the 60 profile and weight doesn't need it
  14. XL=extra load
  15. Or just drive the car
  16. Might have to recalibrate the steering angle sensor
  17. Feckin right, they don't need to be that tight tbh. Just a little nip and then a bit more.
  18. Common for wiring problems
  19. Is get the AC done. Modern systems are so poor. In our place we recharge the system and clean the evaporator.
  20. You sure it's not just the ACT kicking in?
  21. Id say no, what do you mean jerking? The kangaroo effect? He won't of drained it properly, I think you're barking up the wrong tree.
  22. 2.3 dry, 2.1 partially repaired and 1.9 normal refill.
