Everything posted by ile7
Gearbox in emergency mode
Im sure you will need unit or repair yours soon or later. It is well known problem and we are affected...
Update! Error is back! Time to repair mechatronic unit, one day went without problems today after 10 min of driving error came back, luckly I came home safe with manual changing..
Hit it few times that day until battery changed during the trip because was dead. Might be faulty mechatronic since it's well known problem, easly.
Still driving since then, without errors. Tomorrow will do 500km trip and report. Done around 5000km since August when error randomly appeared.
- Gearbox in emergency mode
Hello, Superb 2.0 TDI 140kw dsg7 here. During trip this error appeard and lose odd gears with eml light on, somehow manage to get on the location and swap OEM battery which was dead around 13% of life, but the error persists. Since I was on vacation and car been parked for 10 days with new battery, few times started for couple of mins only, EML light gone. After we had to back home and did 400km run without any problems. P173600 clutch 2 position pressure sensor was stored and cleared via diag tool. This could be mechatronics problem for sure or bad battery cause electronic went crazy who knows. Want to check the clutch 1 and 2 valve pressures but need reference numbers for it, if somone know. Negative pressure is bad valve but how much in positive it goes, thank you !!!
Å koda Superb III 2020 2.0 TSI SportLine DSG oil change
Can someone check my gearbox type pls. It is 11/2018 2.0 140kw dsg 7 VIN: TMBJJ9NP0K7032985
Diy DSG oil change
Yes but need all parts required for service interval. ( Oil, filter, plugs and rest of the stuff )
Diy DSG oil change
@Ootohere2.0 TDI 140kw dsg7
Diy DSG oil change
Hello, can someone give me part numbers for dsg oil change pls? VIN: TMBJJ9NP0K7032985
Rear Shocks OEM
@Crasherthanks bro, as I expected no aftermarket 🤣
Rear Shocks OEM
@Crashercan you please provide me with rear shocks, I've got nivomat TMBJJ9NP0K7032985
noise cold start mk3 engine
Anyone here with same problem today? It is oil vacuum pump but should I replace it or not? It is not coverd by warrenty Skoda worshop says..
Mib 2.5 retrofit
Sent you dm
Mib 2.5 retrofit
It's nasty job to swap shark right? Can i check somehow which one I have without stripping interior?
Mib 2.5 retrofit
@ApertureShey, does all shark fins has gps? Have non navi superb 11/2018 and consider about retrofit. Atm got bolero ( i guess ) with DAB+ and cantona
