OccyVRS
Everything posted by OccyVRS
  1. If it does it when accelerating, then it would do it all the time (3000rpm in first at 14mph is the same as 3000rpm in 7th at 90mph). I agree with the above, easiest point to start is the wheels. It's not anything flywheel or gearbox related - that would be noticeable when pulling away (unless it's an issue with a specific higher gear). That said, I would get a professional to check it out. It could be a million things, from a bad CV to an unbalanced wheel, to a loose engine mount and everything in-between. Forums are good for specific, problematic issues - IMO this is just too much of a vague issue to try and remedy without an inspection.
  2. I've sat in the Sperirling - what you can't appreciate on video is just how small the thing is! It basically has two fans that suck it into the ground, creating a sort of ground effect with about 2000kg of force from a standstill - that's why it's so fast. Not to mention it's over 1000bhp and weighs under 1000kg. That said, with full power, it won't last more than about 3 minutes.
  3. I swapped cars with Hastings once - even having only passed three months previous, they didn't ask for anything. I also update my address and other details every year, without issue. This is a very common thing to catch people out (often young boy racers) that have plastered their car with wheels, a splitter, spolier, intake and all sorts of other things, that they haven't declared on their policy. In other words, it's them basically saying 'we don't trust you and we want to catch you out'. If it were me, I'd cancel the policy and tell them to swivel. Take a look at Admiral multi-cover. I'm paying a very good price for my vRS.
  4. If it's a 2020 vRS then your only exhaust options will be a full system, which isn't cheap for a GFP car. First thing, get your DSG and VAQ serviced. Aside from sorting the intake (R600 in mine), for sound - Turbo muffler delete/diverter valve Downpipe/res delete/muffler delete (just do the whole exhaust, GPF systems don't respond well to being cut up and welded) In general - ECU/TCU tune (please get a custom job, or at least a tuneable flash map with dyno runs and a road test) Mounts/bushes/dogbone insert/etc ARB's Uprated coils/plugs Pedal box (pedal commander, burger, etc) Stickier tyres (PS5 are all you really need) Catch can Lowering springs Grabbier pads/discs/braided lines If you want to take it further - Intercooler/larger turbo combo (with the aux/DSG coolers too) Coilovers Top mounts (depending on if coilovers have camber plates) Camber arms/toe arms/etc (Hardrace) Wheels (8.5J allowing for some 245 rubber) Rigid subframe kit Fancy BBK (Revo Alcon, Racingline, AP, Brembo, YSR, APR, VBT) 5F Cupra 300 ST/B9 S4 Aside from a standing start, my vRS has no real issues putting down the power from 2nd gear and up - the diff helps hugely. You should be able to hit 330bhp without doing anything major like turbo/intercooler/etc. You may be happy with how the car handles now, however once you've added another 100bhp, you may think otherwise. FYI the standard brakes work really well up to about 400bhp. I run full OE, with DS2500 on the fronts. You do not need anything other that plain discs - they are pointless! Next on my list is/was the exhaust and a Wagner intercooler (310/350bhp switchable, rarely used the higher power). If you're into some more vRS power, care to join us?
  5. There may be something useful in here or here. Not too sure about this supposed update. @TheDaneWithSuperb was active a week or so ago, so hopefully they found a solution?
  6. IMO it looks far too copper-y to be anything else - oxidisation from the liner, blah blah, would at the best bet be dark brown, whereas that stuff looks metallic orange. Whether or not that’s indicative of your problem, or is a separate issue, is another story however!
  7. I'd put money on it being some sort of coolant additive (K-Seal). It could be rust from somewhere in the system, but given there's apparently issues with the heater matrix my guess is that. 'Permanently seals leaks in the head, head gasket, block, radiator, heater matrix and water pump.'
  8. Something @varaderoguy might be able to point you in the right direction with.
  9. Not a clue - I haven't touched head units yet. Best bet is to wait for someone else to come along, or see if @Dean can move this post into the correct section. A lot of people don't check here - perhaps @Ootohere might be able to suggest some names to tag.
  10. Very nice choice, but please be sensible with it! For a new driver, that's a very powerful car and you don't want to end your driving career before it begins - any smash in the next few years will make insuring a pushbike impossible. Insurance will likely be eye-watering, but it's eye watering for most people these days. Admiral multicover is likely your best bet. To be honest, I'm surprised you've even got a quote, fair play! Take a look here - be great to have you.
  11. Welcome! You'll likely get a better response in the Octavia Mk3 forum here. In answer to your question - that part number is for an MIB2 unit, so yes, you'll have wired CarPlay/Android Auto via the USB-A port in the center console.
  12. Agree with @Carlston You're maybe thinking of the common Mk3/3.5 move from 225/40R18 to 235/35R19 - in which case, yes, a drop in profile is needed. In order to drop down to a 35 profile, you'd want to be moving to a 255 or even 265 section. Similarly, to go up to a 45 profile, you'd be wanting a 200 tyre - it's quite a big difference! 235 is the maximum tyre that can fit on a 7.5J rim. It is recommended to have a 215/225. You don't want to be doing maximums or minimums for anything tyre related. On a 7.5J, a 205 will be stretched which will cause issues. 235 on a 7.5J is approaching instability territory IMO - the sidewall of the tyre is having to do more work. For a 235/245 section tyre, you're better off with an 8.5" wheel IMO. Some cars (Karoq, etc) have 19x8" wheels, but AFAIK the Octavia is a 19x7.5". Lot's of people put 235s on a 7.5J wheel - be it on a Cupra, GTI, R, S3 or whatever, but that doesn't mean it's right. There's a reason VW ships the cars with 225. You won't notice the difference going from 225 to 235. Go from 225 on a 7.5J to 245 on an 8.5J and yes, there'll be a change - and not always a good one. TLDR - absolutely increase tyre width if you want better grip, but you'll need to increase the wheel width to suit. @OP I would stick with 225/40R19. You aren't going to get anything that offers any benefit - stick some nice PS5s on it instead.
  13. Has anyone come up with a clever way to route the CarPlay/Android Auto cable from the USB port into the glove box? I don't want a wireless dongle, and I like having the phone in the glove box a) out of the way b) charging and c) cooled. Currently, I've just stuffed it into the trim by the passengers knee and up into the back of the glove box. In my previous Leon, I punched a hole in the rubber cubby base and was able to route the cable internally. In the Octavia I don't think this is possible as there's a proper cubby there, with a solid base - I don't want to be drilling things. Not to mention I wouldn't be able to fully close the sliding lid, which would drive me mad. Pics attached are the current setup in the Octavia, versus the job in the Leon. They both come into the back of the glove box the same way, but having that cable there looks ugly and my girlfriend is forever catching her bag on it - it's about time I sorted it!
  14. I mean put it this way - most newer Octavias can do about 600kg or so. Even if you managed to put more than that, the boot would collapse at about 750kg. Add the vehicle weight to this and you're still several chunkies short of the weight limit for the tyres. I think kerb weight for a Mk1 is about 1350/1400kg. We're talking about a tonne of extra weight before you begin to run into issues - that's five 130kg chunkies, a full tank, a dog and about 200kg worth of luggage.
  15. Apologies - I was reading the W to Y and had it in my head that it was an upgrade on both counts. I'm not sure what the GVW/MAM is for a Mk1, but for a Mk3 it's just over 1900kg. With 91 tyres all round you'll be about half a ton off that. Even if you were to be transporting lead, I think something else would break before you got a tonne of weight in the boot. You'll be fine.
  16. W rated tyres are for 168mph. Y rated are for 186. 91 is 615kg and 93 is 650kg. It's an upgrade - I think you'll be alright.
  17. I wasn't talking about the Moray Firth area - the weather there is lovely and, if it isn't, it'll change in ten minutes. We're talking about the NC500 route. Having spent many winters hunting up in in the North of Sutherland, the weather changes very quickly and, if you're going off the beaten path as I said, it can be quite interesting. Certainly, I don't think there's anywhere in the UK more remote than Sutherland - and I'm not talking about Helmsdale. That particular road I was on about has snow gates (unofficial ones?), mainly due to the fact the road is impassible by anything other than a 4x4 for many months. Going over the Dava in winter is a bit different to being up near Allnabad during a storm! More to the point - you've summed up what I'm saying completely. You are from there, you are used to it. The tourists and NC500-ers are not. I've seen their antics during the summer months - I can only imagine how they'll fare over winter. My post was aimed at those that are used to Milton Keynes and not used to those conditions. You likely saw the carnage that ensued on the M25 a few years ago when it snowed about a foot - that's the market I was addressing! As with anything else, YMMV, but my family are all current/ex-military and I grew up in the hills. As I said, it's not Drake's Passage, but if you're unprepared it can come back to bite you (a quick search of hillwalker deaths will offer as much). Oh, and Findhorn is an exception to the weather rule - a lot of hot air there from the Foundation 🤣
  18. The only issue with that part of the world, as beautiful as it is, is that it's only beautiful for 3 months in the year. The rest of the time, it's miserable. I grew up in Moray - I'd move there tomorrow if I could. It's just, people only ever show the sunny, warm days, and don't really acknowledge that a lot of the time it is bitterly cold and wet. One of my favourite roads in the entire is an old military road that cuts about 20 miles through the Highlands. It has stunning views, some stunning road and is the epitome of what everything I love about the world. My current phone lock screen is a photo of my car, taken on that road. Anyway, it's absolutely lovely in the summer but, due to the weather, largely impassible for the other three seasons. Indeed, the snow gates are shut for winter. It's great fun up there, but it's not a private race track. Even though things are a bit different now, the conditions can be dangerous and plenty have been caught out over the years. Nobody is saying you'll starve to death, but go 45 minutes off the A roads, get a flat and you can look forward to several hours walking in the cold until someone coming home from work in their 4x4 sees you.
  19. It is possible that it's not the fault of the tyre place - it is recommended to check the torque of all bolts/nuts 100 miles or so after a change. That said, I've never had one loosen off, although my place does use a torque wrench and not an ugga dugga. The Haldex system can be quite sensitive - it's recommended to use four tyres of the same tyre with the same wear, as anything else can cause it to turn into a Torsen system.
  20. Yeah, at that point you're relying on the carcass of the tyre to give much of the rigidity - alright if you've got PS4S on there, but even then, it's still not going to be the best handling setup. If I was looking to run a 245, I'd probably be looking at a 9" wheel - nice and fat with plenty of support from the rim.
  21. You can do a 235 on a 7.5J but I'm not sure I'd do it - ideal is 215 or 225.
  22. Newer engines (VAG in particular) have lots of parts made of plastic. These don't tend to do so well over the test of time.
  23. There is - we just don't get it in the UK. Kind of how the options lists for UK cars is generally hilarious compared to LHD (in terms of customisation, rather than packs). Type approval costs money, an the RHD market is very small.
  24. I hated Box Hill - it used to be part of my interval training ride. Ugh. Much prefer Toys Hill, quieter and a nice pub in Sundridge to head to after.
  25. If you're EU it will probably be even more restrictive. Just a shame they don't limit the output of LED headlights like they do in the US! Are you after something like this?
