Benja77
Everything posted by Benja77
  1. Hello Everybody! As said in the object, is it possible? I have on my 22 a 8 inches monitor (the Amundsen) and want to swap with the bigger one of 9,2 (the Columbus): both are from a MIB3, the one without DVD/SD unit but only with the 2 USB-C in front of the DSG shift lever. May it work? I do have as well the unlock code as the seller (a salvage shop) provided it to me. Is there any code I need to do after?
  2. With the generator, can You set up more than one set of tyres? I mean: can I make a unique file that contains, for example the Summer tyres (18 inches wheels) AND the Winter ones (17 inches), and select the ideal pressure when travelling with passengers only or with passenger and trunk full of luggage (as the label near the fuel lid)? The generated file can be uploaded via VCDS or can be also via OBD11 or ODIS? Once I generate it, is it better to download for each of these platform (having therefore 3 files in total)?
  3. But before installing direct TPMS did You have indirect one? Actually my infotainment screen shown only if the tyre lost pressure but doesn't tell me how much it lost, marking in yellow whch of the four have (it can be even more than one) has a different one since the last time I reset the switch. Last but not least: indirect TPMS (the one factory fitted) should work with ABS, while direct on each single wheel, am I right?
  4. I found a car with panoramic roof but 2 pieces rear seats: I wanted to retroft the varioflex but it was more expensive than I thought, then I found (and bought!) a car with varioflex, much better!
  5. Benja77 replied to stuupnorth's topic in Skoda Karoq
    Torch: 3T0947471E and 9B9 if black Holder: 3t094757509A and 9b9 if black I bought the holder separately BUT it's not very nice to se when torch is attached as the 12v socket stays on its own; it's much better look for a pre-owned full panel with the support. Last but not least: when boot is open torch light is halogen yellow, while white led only when detached, not too satisfiied of
  6. @JR RS Does this mod, work on Karoq FL too??
  7. Hi there! on my 22 FL I retrofitted the park assist buying the whole kit except the control unit (seller for other parts hadn't it available) which I got somewhere else. I also fit the rear camera with dynamic guidance lines. When engaging the reverse or activating the front sensors the car doesn't appear on the screen automatically (as before the retrofit) but it does if I press the top left corner of the screen. Mechanic told me it may depend by the control unit which was initially codififed for an Audi A3 even if the part code is always the same. So I went to Skoda dealer who made work the Park Assist (resetting the control unit) but the car doesn't appear automatically: is it matter of coding or what else? I'm also going to retrofit as well, in the next weekds, the area view 360 and blind spot mirrors, replacing again the rear camera: can anybody help me with coding?
  8. Hi there! I'm planning to retrofit on my 22 FL the power outlet (for home plugs), usb C and 12V for the rear seats replacing the 12V installed by default. I bought from a damaged car on the front the whole set of plugs including the inverter (the whole kit has part code 5Q0907155H) and ordered in Skoda the connectors (mainly for the outlet and usb, these on both sides) and cover panel. I also bought the USB inverter, 5G0035953D, which has an extra connector (the black one) to power the rear USB. Dunno why but according to mechanic only the 12V can be powered but not the outlet or the USB: does anyone know why? He also opened the inverter of the the 5Q0907155H and there's no short circuit on it. Dunno if the usb must be powered with a cable similar to LVDS or not (the connector is round). Please help me!
  9. Very easy to fit; just a pity you cannot fit front ones with the side steps (OEM as aftermarket)!
  10. Fitted similar cable on my 22 FL and works fine! S&S can be enabled too and cable keep memory of last activation/deactivation
  11. So it's impossible to swap just the 8 inch Amundsen screen with the 9 Columbus one without coding? or do I need any coding? Otherwise, do I need to replace the unit in the glove box too?
  12. Could You print and ship a longer one (I’ll pay You for it? Starting from OEM consider 1cm longer (or even 2), so I can screw the cover! I’d say I’ll buy 2 of which one is 1cm longer and other 2cm). i mean long 19 and 20cm instead of 18 as the standard one Let me know!
  13. What's the part number for left hand drive cars for the right dipping mirror?
  14. Does this work on FL too?
  15. Hello from Italy, My name is Ben and I'm a happy owner of a 2022 Karoq 1.5 Petrol Style in Graphite Grey
