Everything posted by john999boy
Time for a change !
@JKW Don't forget to update your profile with the new car.
Winter is coming!
I think it'd be an extremely good idea to start a new thread in the projects section as those two cars would certainly attract a lot of attention.
Winter is coming!
That looks to be a nice 'project' car at the rear.
What type of odb port
How about posting photos of both the plug and socket?
18" Zenith Alloys....
There may be a slight difference with the offset but they’ll be fine.
Is it possible to activate cruise control instead of speed limiter?
Hi. Can you please only use English on Briskoda.
SD Card Gapless Playback Issues
Totally OT but any albums, artistes or streams that you recommend?
Skoda Octavia Combi, Mk III, 2015, passanger airbag signal light
It's alerting you to the car checking the airbag safety system and then reporting all is well.
How are the mighty fallen? VBH (Vicki Butler Henderson) on radio ads trolling for punters for legal action against Mercedes on emissions
I've not seen that one but there are a couple of ads currently screening featuring Lord Ian Botham which have a similar negative impact on me.
2018 Vrs Amundsen warning
Refill fuel or adblue?
Acoustic ping
Temperature warning - but a visual indicator would show too?
Emergency braking with Winter Tyres and Winter-tyres mode engaged
@J.R.you've acknowledged a new set of tyre pressures - but are they the correct ones?
245 moon white paint
You'll need something like Iron X or Devils Blood to remove that.
@Colin170CR I think the main bottleneck is actually at the server end. I have a 100mb connection and it still takes a while. I'd also like to remind people that the dedicated links provided by @MartiniB in his hyperlinks will ALWAYS be the earliest way of getting the latest updates.
How much are 19 Xtremes worth?
Needless to say a selling thread involves Freedom membership.
There's always people after those - especially if the price is right.
Replaced the Drivers door wiring loom...now the Airbag warning light has come on! Help!!
It's one of the things that 'can happen' and isn't really related to the loom design or cost. You will need someone to reset the warning light though - there may be people near you with the necessary equipment reading this as I type!
- Columbus Map Update 2021 (MIB1/2 HIGH)
Foggy windows
I hate to turn the knife after it's been stuck in but the smell has probably built up due to the lack of use!
Foggy windows
Having the a/c on and climate control in auto is the usual way to have it set. The car 'decides' the best settings to ensure fog free windows.
Map Update
Have a look for posts from @MartiniBand I'm sure you'll find some pointers.
DAB radio
Not all stations are shown by default. If you do a search then you'll find where to get the logos and how to install them.
amortisseurs avant DCC usure et fuite prématuré changé 3 fois !!
Please only use English on Briskoda.
Some astrophotography shots
How 'dark' is your location as I can imagine that would have a huge impact on either the quality or amount of time to acquire a decent image?
