Everything posted by Morph
Door lock barrel
There should be, lots of stories of people dropping it inside the door.
Door lock barrel
Undo the top a few turns and then begin undoing the bottom one a little at a time whilst pulling on the lock and it should pop out. I think I had trouble with the online guides because mine was stuck.
Squeal from front
Piston not retracting correctly
Rear left brake dust shield escaped, killed abs sensor?
By the looks of things I would probably be looking at doing the bearing housing (knuckle), bearing, sensor, splash guard and associated bits all at the same time.
Diff shaft
Or maybe not 🤔
Diff shaft
Ok so I decided to bleed the clutch as a slight possibility and because I was doing the brakes anyway. It seems that my clunking has gone. Fluid looked pretty s***ty when I first began to flush.
Trouble Shooting Octavia Mk2 1.6 tdi 2013 CAYC - 01314 Fault Code - No Start
Apologies I think I remembered this from a Golf perhaps!!
Relay 458 in the engine bay could be the cause.
Diff shaft
Thanks. Oil has been changed recently and is currently just seeping out of the fill hole. Both drive shafts are new from wheel to flange.
Diff shaft
I have a klunk when changing gear (mainly low speed) and slightly when lifting off the gas. Diff shafts seal area’s are leaking slightly on both sides. In my limited knowledge and based on the below video I’m thinking stub axels and or diff bearings but I would like advice before buying the parts. The video is both drive shafts grabbed at the box and twisted back and forth. IMG_6242.mov
Headlight o/s not levelling
I’ve had 1 not working after removal. Didn’t have any ecu connection methods at the time. Took a punt that it might’ve got forgotten about as such (don’t know the correct terminology or cause but it worked) so I unplugged the module and plugged it back in and it worked again.
renewing rear subframe and all components?
Yes paul many cross over parts as with all the marques across the VAG range but do your due diligence.
Octavia 2 has developed a boot leak
Pressure equalisation vents in behind the two sides of the rear bumper.
Door lock barrel
Any admin peoples who could move this post to say Ask a Tech page?
Engine bay fuse??!
https://fuse-box.info/skoda/skoda-octavia-mk2-1z-2005-2008-fuse-box-diagram/amp
Engine bay fuse??!
Just fuse 40 I believe in the panel of the dash. 40 amp
Drivers window motor part numbers and options?
I can’t say for sure what fits your model but others are definitely interchangeable. I have a Touran one on one of mine. Be careful as ones that look identical will have very small differences meaning they won’t fit, like the throw of the gear might be 5mm longer or shorter based on how big your glass is.
Door lock barrel
Trying to get my door lock barrel out of the drivers door and struggling. Followed the original service instructions and differing things from online. Anyone got a definitive way of doing it?
Coolant hose problem
Good find and it seems good but doesn’t seem like they have either to order. Any idea on the Skoda-parts link Crucian put up, my concern is that being a European website the hoses would be flipped 180%?
No, the dealer says they are correct and current numbers with no parts available.
Thank you. I think I found that and as they looked a little different and showed different part numbers I thought not.
Problem is that lots look very similar but are very slightly different.
Do you have a link please so I can see a full pic?
Noisy front end - passenger side. Sway bar links replaced. What next?
If your taking off struts in the hunt for a noise I would definitely replace mounts and bearings on both for piece of mind. Front ARB bushes are a bit of a nightmare as the bush is encapsulated in a welded together bracket so takes quite a bit of work and modifying to get off and back on. Yours look good from here.
Part numbers are 3C0121073AA and 3C0122157FB They seem impossible to get so the above vid is looking likely.
