softscoop
Everything posted by softscoop
  1. Also looking at your original picture, does the red/ green button need to be pressed in at the same time as turning the lever?
  2. Have you got anyone assisting you? Probably easier if someone is using the hammer and you're pushing down on the release lever. Get some releasing fluid (plusgas or similar) into as much of the mechanism and where it all connects as you can. Give the towball a good whack in all directions as you push down on the lever.
  3. If the locksmith left it unlocked then you don't need a key to get it off. Chances are the release mechanism is just stuck. Does the release mechanism move even a small amount as you try to turn it?
  4. Did they leave the lock locked or unlocked? As I said even when I got mine unlocked, It took quite a few whacks with a 2lb hammer whilst turning the release lever to get it to free the mechanism.
  5. Yes it looks like that one is long dead. Nothing as stunned to be a car as the Morgan aero8 though...
  6. Could be an import, but it all looks ok with full UK mot history etc. I did spot another one in the wild, I think this was 2015 I spotted it. All I have is this screenshot from my dashcam.
  7. Ah I knew I wasn't going mad: https://web.archive.org/web/20051024022312/http://www.skoda.co.uk/skoda3g/content/showroom/fabia/pricing.aspx Xenon headlights [Fabia vRS only] £500
  8. Have you got the 2005/2006 brochure PDF? None of those links on your site seem to work at the minute and wanted to check something out. I saw this earlier: https://www.facebook.com/marketplace/item/398384581800076/ An elegance with xenon headlights. Looks pretty factory, as the correct headlight switch without levelling control and washers are in the bumpers. As far as I was aware, in the UK at least xenon were a vRS only option.
  9. Are you really bothered about being able to lock it ever again? It might be possible to force the lock open with a screwdriver and hammer etc. Often locks like that aren't the best security devices. The towbar should still be able to lock in to place with the key lock "permanently unlocked"
  10. Try hitting the ball of the towbar with a hammer, so you're hitting it towards the car, i.e. it's levering it up, whilst at the same time trying to turn the release lever. If it's been on a while it could be a bit seized and a good whack can free the locking mechanism up.
  11. This is what it started out like. After a lot of scraping, it was only just visible.
  12. If it's a Thule or Brink then again the number should be stamped on the barrell. It took a lot of cleaning and scraping to see the number on mine. Daft question, but are you sure it's even locked?
  13. https://www.witter-towbars.co.uk/accessories/keys/westfalia-detachable-neck-keys Have a look here. I had similar with the Thule towbar on mine. Arrived with no key.
  14. The key number is usually engraved on the barrel of the lock. Probably covered in grime but it should still be there.
  15. The window regulator cable will have broken. It's a common occurrence in the entire VAG range.
  16. They are my daily wheels. I got sick of the 18" wheels with 40 profile tyres. A set of Michelin crossclimate tyres in 205/55/16 + the cost of the wheels was cheaper than a full set of 225/40/18.
  17. I have a set of 16" Dover wheels from a Mk7 Golf fitted to mine.
  18. You'd definitely get better value by switching to 195/65/15 tyre sizes. Just looking at cross climates, they are £30 per tyre cheaper in that size.
  19. I used to run summer and winter tyres and swap them over, but I got fed up of that. The last few years I just fitted a set of all seasons and have not noticed any drawbacks. The Crossclimate2 are one of the most consistent all rounders in recent tyre tests, in all weathers. No they are not quite as good as a full summer tyre in hot weather, but you are not driving a sports car, nor are they a full hardcore winter tyre, but they are a very good all rounder. Given where you are in the country, I'd expect you get a very good range of weather? For me it was a no brainer to fit all seasons.
  20. You would probably be better off fitting 195/65/15 tyres instead. They are a much more commonly available tyre size, and are far cheaper than 205/60/15. You can get a full set of Michelin CrossClimate2 all seasons in 195/65/15 fitted at Kwikfit for less than £280 currently.
  21. Technically there is no filler hole in the top of the gearbox, but it's certainly possible using the oil filter hole. It's no more difficult than a regular oil change.
  22. softscoop replied to SNH's topic in Octavia Projects
    Just spotted your motor going down the a57. Looking good 👍
  23. It's usually much cheaper to source wheels yourself and simply get tyres fitted. I managed to find a set of wheels that were from a Mk7 golf that were only a couple of years old for £100 on an eBay listing
  24. I've just checked and you can still get 4 crossclimate 205 55 16 fitted at Kwikfit for £312. They're a bargain.
  25. Yes that's the right operating temperature for the UK. I wouldn't bother with spending the extra for a Skoda box. Don't buy the cheapest cheap one, you can get Febi one from Amazon for £16 https://www.amazon.co.uk/dp/B00DZM877I/ref=cm_sw_r_apan_glt_i_AABQ7VNT67RT7CD4F5JF?_encoding=UTF8&psc=1
