Everything posted by varooom
VCDS forced regeneration help/advice ??
I interpret that as your exhaust has used half of it's life in terms of oil ash stored. So that's good, and you can also see the soot thresholds of when the lamp will illuminate etc. So really I would say your car is performing ok, as it ages the regens will become more frequent, but you don't seem to have got to the stage of car going into limp mode. Just drive, and monitor values from time to time.
Update my car from 0156 to 0306
Thank you for the updated information, I have directed @ediXo to read all the information as he is stuck on 0155 and the dealers are reluctant to do their job. Maybe if they are not a million miles away, you might be able to assist in getting their system updated, or assist in their journey as they probably could do with the leap to 0324. Once again, thanks for taking the time to write up all the information, and the post about the chinese clone is good, it helps people to avoid!
Amundsen MIB2 Firmware Update
@ediXo You may wish to visit the thread again by @Lennart as he has written an update to his process in there. If you was to find an independant garage that has access to the ODIS Service software online, they can assist you probably better than dealers, so that you could update to the new version. Files can be supplied for you to do this, if they don't have them. Just they will need to input your new Map activation code if I have information correct. @Cherry182 I am glad you got the new 0480 loaded now, just for my own curiousity, does the page in Engineering mode now show the value "MST2_EU_SK_ZR_P0480T" that was just "---" before on 0475?
Show image of Software Train, and also contents of you SD Card.
It should be fine to update, can we verify Software Train? Hold down your Menu button for 10 seconds.
Infotainment System Restarting endlessly
Try holding it down for 10 seconds, that's the usual value
- infotainment update
CarPlay not working
I will send you a link/destructions on how to update. Dust off an SD Card.
As mentioned in PM Take all the files and folders in D:\Car, and move to D:\ which is called the "root" 📂
Skoda have not yet released a standalone update so that we can check what SW Train they have used for Skoda, but I don't think they would use VW. Maybe we need a few more people on 1900 to show their SW Train to compare? The last release for Skoda as a standalone was 1896, after they used OTA to update to reach 1900 currently. Skoda a lagging behind SEAT and VW, release could be any day, or a few more weeks.
@djmartzianWhat has got you confused and groaning?
I think I would be asking them why your car is on a VW SW Train, they won't know... but they can push this off to technical to find out.
Problem
It's not, but if you have say a bad media, then Red Emergency mode will be shown. Then you use a new SD Card and apply again to fix.
As you are on a VW SW Train, you should be able to go to 1941 in theory. I should add to this, you really shouldn't be on a VW SW Train of course.
2016 superb style radio volume
@pab567 This sounds like something you can answer. @jimmyw147 Find your VIN, and be prepared to send it if asked.
CarPlay not working
Press and hold your Menu/Setup button for about 10 seconds, this will take you into the Engineering mode where you can look up Software Train. If MEN2_EU_SKGPx_XyyyyZ format, then MEN2_EU_SKGPx_P0080L version 8755 will be the fix for crackling audio.
Karoq cam belt change - start saving now !
Personally I wouldn't change it, but there's no exact definition of a "lifetime" so it boils down to you weighing up the risk, or perceived risk.
Sadly you know the dealers are lying to you, it should in stages be able to update to 0324 (eventually) But in upgrading from such an old version, it will erase your Sat nav licence iirc.
Press and hold the Menu button for about 10 seconds to find the Software Train installed. Then post this back.
That sreen looks interesting, missing SW Train version. I have sent you 0480 version to load.
You might wish to check this post as to why they are reluctant, though they should be able to do this task.
Press and hold down the Menu button for 10 seconds to find the Software Train from the engineering menu.
Be nice if you can confirm in your car what the oil ass mass/volume limit is compared to your readings (curiousity is killing the cat here!) Then you can set about maybe resetting this in the car to fool it, and see how it performs after this change.
