varooom
Everything posted by varooom
  1. You may have issues still if your bank address doesn't match the fake address. Best of luck though, hope you do make it work.
  2. I can send you a possible update, it will either work or not as their updates are weird to say the least.
  3. You can get updated to 0253 version. This can be sent via PM.
  4. I can send you 0490 version, link by PM
  5. I can send you the update via PM
  6. I said it's printed on the part. Nice attitude BTW 👌
  7. 06Q 103 925 L is actually what is printed on the part. If you scroll up a few posts, you will see the values posted by me beforehand.
  8. So a little swap of the metal heatsink/brain thing and you're golden again! Nice work if so 🤝
  9. I did ask a question of you to find Software Train. Smart link can be done one of two ways, an expensive code from the dealer, or a free method, that needs you to have VCDS of similar tool, so that you can place the radio in developer mode.
  10. I will send you update to download and some destructions to install it.
  11. Firmware link from me, they expire after 24hrs? The Skoda card, format it FAT32 and check it's OK, then you can put maps on it.
  12. Does the plug come off the "brain" part, and if so can you carefully test with suitable thick power cables if the replacement motor will spin when hotwired? Have you got multimeter you can check voltages etc, see if the car is trying to power the fan. Several angles of attack, depends what you are comfortable checking.
  13. @langers2k Check your post, the copy/paste went wrong 🤝
  14. It is a needle in a haystack to find, it is best if you can post your details from a car scan. Flashing the car, you will need the tools to be able to do so. You will need stable power supply to do this too. And you can break your car if you don't have above two sorted.
  15. Welcome, you should press and hold the Menu/Setup button for 10 seconds to enter the hidden engineering menu. MST2_EU_SK_ZR_P0241T <-- Hopefully you find this version MST2_EU_SK_ZR_P0253T <-- Available The screen you find is the update location also, so it will be a good idea to find it now.
  16. Yes there is a big leap to 1433 version, I will send link by PM.
  17. I used ImgBurn a free tool, and then write file to disc, touching nothing special.
  18. Evening @pab567a definite hardware fault by the sounds of krkkrkrkrkrkkr drive noises no doubt. Hoping you can assist him 🤞
  19. erWin Skoda, you can download your workshop repair manuals, this information lives in wiring diagrams. EDIT: Forgot to say, it costs 7 Euros roughly for the 1hr of access you will need.
  20. Look up 3x posts, I do not think there is an update for your SW Train. MHIG_EU_VW_S1054 <--This is yours MHIG_EU_VW_P1054 <-- This is the supported train.
  21. Every day is a learning day, CUNA & CUPA Page 5... 🤝 Engine Codes Skoda.pdf
  22. 30 Amp Green/Pink colour. F50 - Fuse 50 on fuse holder C -SC50- 30A - Control unit for tailgate -J605- 30a
