varooom
Everything posted by varooom
  1. It's a Diesel, it's not about HP... Last 170 I had remapped went to around 200HP, but the torque went up 19% and that you do notice (effortless overtaking)
  2. Press and hold down the Menu or Setup button for about 10 seconds until you see the software train value. Example images above.
  3. Yes, check PM in a few minutes time.
  4. That silicate stuff is a nightmare if that has come back again. Hopefully you can sort it out, might pay to scan the car in case the flap is stuck and registering as such in a diag scan. Best of luck with it.
  5. Looks like holding down Face direction and AC button
  6. You are probably correct, but I prefer not to assume 😆 Not sure of the button combo, but someone will be along, or hit the google. If that does not help, then you may have a stuck flap, so you need to code read the car to find out which one(s) is/are stuck.
  7. You should let us know which system you have, electronic climate control might just need a reset of the flaps to change the mix of hot/cold air that passes over the heat exchanger. A picture can say a thousand words.
  8. I don't have too much time to read all the translation, I can send you 0369 and you will need to perform necessary tasks at your own risk 🤝
  9. Are you running 0346 or 0246? Because you should not load 03xx onto 02xx version of firmware. Ideally please verify if you made a mistake above in typing in value.
  10. You need this file/location # ECE 1 Andorra, Belgium, Faroe Islands, France, Gibraltar, Iceland, Ireland, Ireland, Luxembourg, Monaco, Netherlands, Portugal, Spain, United Kingdom
  11. varooom replied to Yety's topic in Skoda Yeti
    Look at top of the webpage, top right (on desktop PC) for the envelope icon. You can open and reply there https://www.briskoda.net/forums/messenger/
  12. Updating the software won't add new features, they are activated by codes from factory/dealer. MEN2_EU_SKGPx_P0080L MU 8755 Is an available update, this seems to cure some sound issues people are having. Your only other choice is to change the hardware, but this will not be easy task.
  13. MST2_EU_SE_ZR_P0369T This is available if you are on the 03xx series of firmwares
  14. The "Skoda" cards are just an ordinary SD Card, that has a special CID (Card ID) that is also programmed into the head unit, and when the two handshake and match up, it will read any old, current or future map off the card. This CID is only needed for Amundsen, if you have Columbus, any generic SD Card will work, as the map is copied to internal drive. If you are in the UK, then you won't need the 32GB card, unless you travel all over Europe a lot, the 16GB card that you hopefully already have, can be loaded with UK/France/Spain, and should suffice for most people.
  15. varooom replied to Yety's topic in Skoda Yeti
    You have a PM, I can scan the car if you like and see if I can get to the bottom of it all.
  16. varooom replied to Yety's topic in Skoda Yeti
    I think you may wish to expand upon what problem you are having, lacking details. Excess soot? Full DPF oil ash? Regens happening all the time?
  17. I don't have any updates for either radios. @pab567 Can you check your collection for the above 2x SW Trains?
  18. You can look around for MVB (Measurement Value Blocks) with your tool. Take a look at this for what information you are looking for.
  19. You've yet to convince me of that today, most danger comes from website logins that have a username as your email address, and then some sheeple put in the same password for the lot. All it takes is a lapse in concentration to input both into a forged website, and then you are caught, they can then login to all the usual places (gmail/amazon/meta etc) and scrape your address and person pics etc. I still don't get how having a WiFi password and SSID alone would narrow down your home address, a leap too far (or I need more coffee)
  20. Nice, hopefully do you well 🤝
  21. An upgrade to 1433 awaits you in your PM
  22. I am back now, so I will send file via PM to bring you to 0490 version
  23. Most of the thing you need to adjust when you place in a new Gateway is the installation list, so it needs to know if you have ABS/TPMS etc. Online coding could be done, but if the car doesn't drive to the garage that makes it fun. What tool do you have to program the Gateway?
  24. It's only half of the equation, he didn't post his SSID Also, it would take some really dedicated person to drive all over London to input that password into every visible SSID. He should be super safe 🤞 p.s. You are right though about leaking personal information into public forums, we should turn off Meta/Facebook immediately 😆
