Everything posted by Berisford
Engine / Ignition Switch-Off Irritations
I'm a fairly satisfied owner with 3 VAG vehicles - in the Skoda's, the Superb and Karoq I'm looking to alter the way the radio stays on after 'engine off', it might seem a trivial gripe but I find it quite distracting (I know I could simply press the off button, but then I have to press it again to switch on) as I gather up and ready myself for exiting - I want the radio to go 'off' when I switch off the engine - I've had a good snoop around the options but it doesn't seem possible - have I missed something.....? If only I could swap my radio 'on' gripe for the other 'engine off' irritation, the lack of cabin illumination, that is, having the interior lights come 'on' when I switch off the engine - I know this one is not possible and it's been discussed on here a number of times in the past. My elderly VW Golf behaves logically, as it should, engine off = Cabin lights 'on' and Radio 'off'.......... Further, does anyone know what the little '2' in a circle symbol, next to the mobile battery charge indicator means.....?
Startstop Karoq sport plugin
KAROQ in the headline.........
Tonneau cover
I'm not surprised they have an excuse for excluding it - however, it could be argued it's not trim, it's a mechanical part - would the drivers seat adjustment be excluded in the same way.........?
- Faulty door locks
Front sequential side turns
I think you need to rewrite that question in a way we can understand.......?
Increasing the visibility of the main beam warning light
On my 2021 Superb I leave the system to its own devices and it automatically switches the main beam off once it detects street lighting........
Blind Spot Detection
We have both vehicles - I don't miss the lighty up mirror thing but I do miss the rear left / right beeps when reversing out of a supermarket car park........
Squeaky brakes in reverse... but not always!
I wouldn’t worry too much…….
Heater windcreen - how do I tell if it is an original screen
Ah…..scrub that…..I’ve got my wires crossed, so to speak…..just checked our vehicles, the Superb with heated screen and the Karoq without both have the AS1 code…….sorry.
I’m fairly sure the AS1 code relates to a heated screen - when you say you can’t tell if it’s working, this time of year brings a good chance of frost, at the very least, condensation - my wireless screen works very quickly on both frost and condensation……….
music storage - no sd card - tip
So not this one then.....https://www.amazon.co.uk/PNY-Elite-X-200MB-Flash-P-FDI64GEXFIT-GE/dp/B01LFV52Y6/ref=sr_1_22?crid=218X4BUEKGS16&dib=eyJ2IjoiMSJ9.3mxozYRZw7x65MXf1gmILoxnBhgpkNVmlIEZK4uil_k1gAJyjONdJW8punAGAKjjYwZHQnTTvwnbJLz7wet6NmWDnnr2kt44oNS-K1sqEVwUK0zRJAdcNTux_b7ejsWQMbdiZhc4ZjEyOfFGxGRZuUP2IJffvuEgRjmYscj0TVEAdJSuY3pOoncrEImqu1VB1GHfucN7t7hLPI2YSoyjEadJWzIuFD2EgZHbhwiEHYg.KzzbkY4bk7tM-Z9q1FRdoDGV1GiCZIPreYXZTtgx3xY&dib_tag=se&keywords=pny%2Busb%2Bc%2Bflash%2Bdrive&qid=1762949795&sprefix=pny%2Busb%2Bc%2B%2Caps%2C151&sr=8-22&th=1
PapaDuplo, where did you source your micro PNY, when I search Amazon have ‘em but only on the USA site……?
Ignition Switch
I’m sure this has come up before and there was a fairly simple fix……?
Rear reading light switched backlit?
Same in my 2022 L&K, no backlighting for the rear overhead switches........
Pothole!
What I intended to write above.......but you can't delete or edit after just a few minutes......... ........On a 2 wheel drive Karoq I'd prefer the spacesaver to be on the rear, it can't be doing the differential any good on the front - on the 4 wheel drive I'm not sure you can fit a single wheel with a smaller circumference....?
Pothole!
On a 2 wheel drive Karoq I'd prefer the spacesaver to be on the rear, it can't be doing the differential any good on the front - I'm not sure you can fit a single wheel with a smaller circumference....?
Cluster dashboard lights
ABS sensor, quite likely to be rear offside……?
Extended Warranty do I this year ?
Do you get roadside AA, a service and MOT in with the £480....?
Rear Child Locks
For the first time since new (15 months) I had a couple of passengers in the back yesterday - I was surprised to fine the rear offside door child lock was 'on' and despite my efforts to reset it I can't, everytime the inside handle is used the child lock comes on - anyone come across this problem before? It might be that I'm not turning the 'off on' mechanical actuator far enough but I don't want to force it......?
Workshop Manuals - 2025 edition
Nice one Christophy - thanks….
VCDS or ODBEleven or ???
That is unless you upgrade from Windows 10 to Windows 11 and then you are stuffed it seems...........
Centre consol button panel - change of button order
I dare bet you'd have to extend the wiring on any button you wish to reposition - not impossible, I did it on my VWT5, but a little fiddly............
USB cable - recommendation
I find the standard wireless charging pad built in to the car creates too much heat when the phone is running Google Maps / Waze, my iphone gets alarmingly hot.......
Change dial colours on cockpit
Is the dash colour theme still connected to the ambient mood lighting….?
Car mats upgrade
The Skoda rubber mats mitigate the problem slightly inasmuch as they have a raised lip all the way around………
