Everything posted by sepulchrave
changing front spring
Go for it, the safety police will be along shortly to tell you off but Hilka stuff is OK.
EGR Valve Vacuum Pipe
The ECU calculates the fuel correction using information from the EGR cycle time because it's controlled by PWM, the MAP and the TPS, so it knows everything it needs to know to apply an algorithm. These things are not a matter of faith or belief, they are cold hard facts. You are not controlling the engine, the ECU is, it's completely FBW.
I read your reasons, put politely they're incoherent which is why I threw you the link. If you follow it up you'll find that what you're looking for is more EGR, not less or none. Ask me why performance tuners delete the EGR system.
Here is some very useful practical information: http://origin.autospeed.com/cms/title_Tuning-for-maximum-fuel-economy/A_113199/article.html
EGR is an efficiency strategy on petrol engines, it significantly reduces pumping losses on part throttle giving real improvements in fuel economy during lean cruise. Deleting EGR can never improve efficiency for this very reason.
You'll notice a drop in fuel economy, an increase in emissions and no improvements at all, a remap might increase power fractionally, but probably no more than 5%. You're barking up the wrong tree.
Engine making loud ticking noise and shaking heavily
Yes, an extra £200 would have been worth it for peace of mind.
Map sensor location
Faulty coil pack is favourite.
Control System For Exhaust.
It means your DPF is clogged.
SOLVED: Fabia cranks but won't start - sometimes!
The pistons should be ok, it'll be the valves that are bent and not seating properly.
All four-valve engines are the same, even with perfect timing the valves run very close to the piston crown, hence the cutouts.
Random beeping issue!
Check battery and earth connections for tightness, clean and grease connections where necessary.
ABS kicking under normal braking and engine revving
Switch off the ASR, the hesitation should vanish.
1.9 TDI bsw Fabia - lack of power
That's a lot of oil leakage, it suggests the turbo is very worn and the intercooler is probably full of oil as well, I wouldn't be surprised if the impeller is showing signs of wear and there's excessive end play in the shaft. Take off the TIP and have a look.
Multiple codes showing after yesterdays heavy rain and low power/limp mode?
This ^^
I would check compression if were you, the valves may well have been damaged by the slipped timing.
WARNING TO ALL
You make it sound simple, but it isn't. Even with a car right in front of me I can't always accurately diagnose a problem because modern engines have become so complex and so many systems have complex interactions which are not easily separated from each other. Back in the old days you could say, "it's the ignition" because there was no spark then break it down further and eliminate components until the problem was found. Imagine how much harder it is doing this remotely where your eyes and ears are a person five thousand miles away who has no experience to draw upon and very few tools or skills and often cannot even articulate themselves properly in English.
- Skoda Fabia MK1 End of life??
Fabia vRS - Bilstein B12 Alternative ?
KW are a quality alternative, Koni even more so.
