Everything posted by sepulchrave
- Skoda Fabia MK1 End of life??
TDi Tuning box
Holy wall of text batman! TLDR: I used to do this stuff for a living so I doubt there's much you can tell me. So you're saying this is not an interceptor, rather a glorified ebay resistor of power?
TDi Tuning box
All this nonsense is about toys for boys anyway 🙄
TDi Tuning box
If it's an interceptor then it's not inferior, it's just a remap applied dynamically rather than rewriting the static map, it's algorithmically derived to provide the same end result.
1.2 tsi dsg paddles
Do you already have paddles?
1.4 mpi 8v timing chain....help!
I wouldn't worry about it, the old one will be fine until you finally weigh it in, they never need doing in this country because our fuel is clean. Diesels need doing every year, petrols never.
Where would you get these signals from
Wino is right, your new box doesn't say what kind of signal it wants, I'm guessing it's looking for analog square wave pulsetrains for RPM and vehicle speed and maybe a DC resistance value for throttle position. But speculation is pointless because you'd have to tell the box in software what it was looking at in order to calibrate it.
Headlights - A lesson learned!
I just experienced the exact same thing, the other bulb blew two weeks after the first, it's a MTBF thing, modern bulbs are so accurately made that if you replace them as a pair they'll last about the same time.
Fabia VRS Mk2 Brake Upgrade
It's factual rather than just opinion, there are equations that back it up. Big back brakes are a RICE, ricer.
This is nonsense by the way, the stronger the front brakes, the greater the weight shift and the less work the back brakes can do before locking, bigger back brakes are only needed when breaking from very high speeds or if the vehicle is particularly heavy like big fat German supersaloons with big engines or track cars. A Skoda Fabia is neither of these things.
Low level rumbling after pads/disc change.
Excellent work, that scraping could well be the culprit, worth investigating further.
You need to helicoil the threads to repair them, they're M9 x 1.25 which is an unusual size so you need to buy a complete kit. Understand that that you lack mechanical sympathy and follow the instructions carefully, don't rush and don't bodge! You're not an idiot but you clearly lack experience.
TDi Tuning box
A custom remap is really only necessary on modified engines, by modified I mean modified for performance by improving the pumping efficiency of the standard engine, not modified by sticking a load of pointless junk all over it.
The importance of greasing the pins is wildly exaggerated, they're chrome plated and protected by rubber bellows to prevent them sticking and they're not even a tight fit because they don't really carry any load, they're purely to keep the floating caliper aligned. The pads and the carrier take all the strain of braking.
Copaslip is fine on the backs of the pads, but not on the pins.
Timing belt kit for ASZ engine
Sixty in a thirty is fast, go with a gates belt kit, any water pump will do.
Fuel pump, petrol
Check that the filter screen on the pump isn't clogged first, then change the fuel filter itself, if the pump is still noisey then you can change it.
Wind deflector trouble.
Have you reset the windows correctly?
Which Key do I have?
The button is for a light, try changing the battery.
I really wouldn't worry about that bearing, just do what TMB suggests and top up the gearbox oil or get it done for you.
- ABS Wiring Removed?
Fabia interior light stays on
Reasonably common, it's not a Skoda thing so much as a 'listening to primitive music far too loud' thing. Replace the speaker and turn the volume down if you start to hear distortion.
