Everything posted by FatblokeVRS
Left side windscreen air vent not blowing
I dont have the econ button etc. Is there a way to do it via vcds?
No, is that easy to do?
Hi All The passenger side windscreen air vent is not blowing air. I think its maybe not blowing to the edge of the door to clear the door window either. The fans working and the drivers side is OK so seems like maybe the vent pipe has come loose or is blocked somehow. Any ideas? Dave
Oil recommendations???
I normally get 20 litre drums of Fuchs, Castrol or 5 litres of Quantum. The links for Mannol are a good price. I have never used it. Is Mannol any good?
Strange coolant leak
Any water contamination in the engine oil? Any coolant in the bottom engine tray or around the bottom of the radiator?
Looking for Yeti buying info
Thanks folks. Much appreciated. Dave
Hi All My uncle is looking to purchase a 2016 2.0 CR Yeti 4x4 L&K. Its got around 20,000 miles on it. I know very little about them as an Ocravia owner so thought maybe some of you could advise. He had heard there are issues with the doors rusting lfrom the inside and panoramic roofs leaked. Can anyone advise on this ? I assume its the Gen 5 Haldex on it? Any other issues to look out for? Thanks in advance Dave
2010 2.0 CR VRS - Info required on timing belt, water pump and thermostat.
It's a manual gearbox. Must be at least 5 or 6 years and around 50,000 miles since belt was last changed.
Hi All The VRS is about to reach 100,000 miles. Its had a timing belt and water pump change but it was a while ago at 50,000 miles. I can't remember much about the kit used at the time, I think it was maybe a Gates belt. What is the current recommended timing belt / tensioner kit? Is the water pump better with a plastic or metal impellor? (I think the last one was metal). Recommendations? When it heats up now, the last bit of getting to temperature on the gauge takes ages. I wondered if the thermostat was a bit sticky so was going to get it changed at the same time as it's never been done. How easy is it to do this? Cheers Dave
Spline socket size anyone ???
Some photos / how to of the procedure would be very helpful. I will need to do mine too as EML keeps coming up for manifold fault.
Still diluting oil!!!!!!!
Get the dpf checked to see how full it is. You can take it off and get it cleaned or some garages can clean it on the car. Sounds like it's thinking it needs a regen all the time.
P2015 code😡
Mine has come up with the error again. Car runs fine but EML is on. I will try clearing it again but may need to try putting the bracket on it and maybe replace the manifold if required. Is there a good how to for taking the plastic manifold off and refitting? Cheers Dave
Best aftermarket stereo to put in my Octavia? Thanks
Had a quick look and found this...... https://xtrons.co.uk/vw-skoda-seat-various-android-10-octa-core-4gb-ram-64gb-rom-ib90mtvl Anyone fitted one? Any issues and is it easy to fit? Any better options?
P2015 code😡
I saw a post somewhere and they used a Bahco slim ratchet set to get into the bolts without taking the manifold off.
New rear washer jet doesn't fit
Just replaced mine. It was very tight. A wee bit wood on the top and a gentle tap with a hammer and it popped right on.
P2015 code😡
The brackets are a tenner or less. I think you can get into the motor bolts with a Bahco mini/slim socket set. There was a forum post or YouTube video. Get a set of small locking forceps to grip the return spring so you don't drop it.
P2015 code😡
There are 2 different brackets. If its for the plastic manifold, the bracket fits on the rear so you need to struggle to get the bolts out/in or take the manifold off. It's a plastic manifold on my 2010 VRS diesel. I had the same error but luckily it cleared when I changed the battery. Seems to have been a spurious failing battery fault.
Engine management light on - help required
I decided to check the plug on the motor (unplugged it and plugged it back in. Looked clean, no corrosion etc) and give the car a run to charge the battery. Cruised it up the motorway and as I came off the motorway to turn round to come back it was doing a regen. Cruised it home and completed the regen (back to normal tickover). I then cleared all codes with VCDS and this time it cleared the P2015 error. It wouldn't clear before. Hopefully it won't come back. I have the bracket for the motor now so will keep it until I need it. If it was just the battery causing issues, I will test it with a load tester and monitor it. The battery is a few years old and may be nearing replacement. Thanks for the responses. Dave
I am hoping to attempt the job possibly over the weekend but if I have to take the whole manifold off, are there any instructions or how to videos available? I have searched but can't seem to find anything. Is it a straight forward procedure to remove and refit? Cheers Dave
Just found this. Looks like it is doable but a PITA. Oh joy.
I have been looking into possible fixes for the P2015 error. It seems you can get a small metal bracket that screws on and prevents the motor from over-reaching when it returns from opening the manifold flaps. I have ordered one of the brackets for the 2.0 CR engine. This looked like a quick and inexpensive fix to try first. I took the engine cover off this evening to have a look at the motor for removing it. Every picture and video I have seen shows the 3 screws put in from the front of the vehicle. On our VRS they are in from the rear giving no access to remove them. How do I remove that motor? Cheers Dave
It has been sitting for a while, not getting used much. Will check and charge the battery. It starts and ticks over fine.
What happens if I drive the car? Will it makes things worse, die a horrible death and leave me stranded ?
Hi All 2010 VRS CR170 The engine management light has come on and vcds gives the information below. Can anyone advise please? 1 Fault Found: 008213 - Intake Manifold Flap Position Sensor (Bank 1) P2015 - 000 - Implausible Signal - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 2 Fault Frequency: 5 Reset counter: 255 Mileage: 157483 km Time Indication: 0 Date: 2016.04.21 Time: 17:25:35 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h Load: 0.0 % Lambda: 11.0 % Lambda: 3.2 % Voltage: 0.380 V Bin. Bits: 10000000 Readiness: 1 1 0 0 0 Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb Part No SW: 3T0 907 044 AS HW: 3T0 907 044 AS Component: Climatronic H15 0401 Revision: 00005001 Coding: 0000000002 Shop #: WSC 73430 790 00999 ASAM Dataset: EV_Climatronic A01006 ROD: EV_ClimaAutoBasis_SK35.rod VCID: 03040DA08AE792915C-8056 1 Fault Found: 9481988 - Air Quality Sensor B10AF 04 [009] - Internal System Fault Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 91 Mileage: 157484 km Date: 2021.11.29 Time: 09:25:25
Dash Needle lights & Digital Speedo help needed
