Everything posted by Urrell
Bria
Does the low oil pressure light stay on when you start?
headlights Upgrade to LED
No Yeti has headlights suitable for LED. They are either Halogen or Bi-Xenon
Yeti diesel filter leaking.
You don't say, have you tightened those 4 screws that were loose and still got a leak?
Dash icons
Get yourself a voltmeter that goes into the 12v socket in front of handbrake and note the voltage before starting car in the morning, anything around 12.5 volts is not good. Something like this. https://www.amazon.co.uk/Cigarette-Lighter-Battery-Voltage-Voltmeter/dp/B00DI4ZS7U
Yeti strange noise
Is it the air outlet flaps at the rear behind the bumper, see if it stops with a window open.
Hard wired dash cam.
What's the need to cross the mirror mount? Just bring it down beside it, cannot get neater than that and much easier as no need to fish cable across under the dash, straight up from fuse box to the drivers "A" pillar and tuck under headlining. The cable is barely visible.
Get a 12v to 5v converter hardwire kit and piggyback into a live or switched live (whatever it needs) in the fusebox by the drivers door. Easy then to remove drivers A pillar trim by lifting as you pull it inwards at the top so you don't damage roof trim then feed it under the headlining by the windscreen to the rear view mirror.
Amundsen emergency update
Strange as the 2015 Amundsen II does not have a disk.
Tyre pressure warning and other lights.
So did that mean the TPMS light came on so you checked and adjusted the tyres to the correct pressure before resetting the TPMS?
Amundsen sat navin a 2017 yeti
Usually caused by water getting into the aerial.
Yeti Passenger Seat
Swivel seats work on a flat floor, something the Yeti does not have.
Strange beeping noise from front of car – any ideas?
When instrument cluster lights come back on is there any message in the Maxidot? Have you left any lights on, including indicators?
That sounds like it could be the culprit.
WOW; our Yeti is eight years old.
Ours was 9 years old on January 12th. I gave it a polish last week and it looks like new, the roof rails looked a bit jaded so I treated them to a rub down with Owatrol and they look new again. 57,500 miles and going as good as it's ever done, excellent roadholding with about 60 mpg if not pushing on too hard, the annual road tax went up this year to £35, my motorcycle is £117! It's a keeper 🙂
Luv out light on trailer module and reverse
That is when he joined, this thread was only posted last week and he visited here yesterday.
Excessive Vibrations at between 1500 - 2000rpm under load
They said earlier the DMF has been replaced.
Any magical cures for a 1.8 TSi 4x4 using oil and coolant?
Don't think there are any magical cures, it seems to be a trait of that engine as well as a very good power delivery.
Haldex Failure
Could it be just a blocked filter not allowing the pump to come up to operating pressure I doubt if the previous service would have even checked that, most don't even know there's a filter in there.? A lot cheaper to change than the pump.
Skoda Yeti 2016 - 2L Diesel 4x4 - Condenser Replacement
You really should get the refrigerant vacuumed out before disconnecting the lines.
Water leak, AC Condensation?
Sounds like condensate from AC.
Which OBD system???
Rear wiper problems
If you put the front wiper on and then reverse a bit does the rear wiper start?
Rear wiper problems
Is the boot showing as shut on the display between the dials? If yes does it show as open when boot is open?
Park assistance buzzer
Just behind the 12v socket in the boot is a grill, it sounds to be coming from there and another on the other side.
Best tyres for my green line
Nope, the 215/60/16 has a significantly higher sidewall, Read again, I said one of the highest side-walls, higher than any of the 17" wheels, that's why so many people tried to get 16" wheels fitted at build for a more comfortable ride
