Rbz5416
Everything posted by Rbz5416
  1. You can get tents that attach to the open tailgate, so you can easily access the vehicle contents. Or just go for for a regular tent in a roof box. There's all manner of pop-up versions that don't require an afternoon of puzzling over faded instructions. Although they may require that same afternoon to get the buggers folded away!
  2. I believe the Karoq has a fairly weedy 75kg roof load. Given the tent weighs 55kg, that leaves 20kg for the occupants. Also raised rails are a potential issue. Thule has a compatibility check on their web site & they rule the Karoq out.
  3. A 72 plate comes out at £87.18 at Colchester. Looks like they set pricing depending on whatever they think they can get away with!
  4. 25 Plate Karoq SEL Edition.
  5. This is Skoda Colchester. Edit: Checking Mitchell in Chester I get £74.92, no idea why the discrepancy. So I'd be inclined to look at another dealer, Audi or an independent. Just make sure you get an invoice to keep as evidence, as it won't show on the Skoda app.
  6. I've seen a suggestion to lubricate the "plunger" with silicone spray. This may be useful in an emergency: The list of "known issues" on the Karoq seems to grow longer by the week...
  7. Looks like they've fixed it then, although must be fairly recent. 👍
  8. It's speed related. Even if your turn it off after setting off, the next time you slow for traffic it will re-lock. As alluded to above, older vehicles have an option in the menu to turn it off, but Skoda have removed it. I doubt any apps can disable it either, as VAG have locked the software down on all vehicles now.
  9. The last two threads asking the same question went unanswered, so maybe have a look at the Facebook Karoq groups.
  10. Buy
    Rbz5416 replied to wd20's topic in Skoda Karoq
    Be aware that 2.0 is only available with DSG in the 4x4 Sportline, which will take you over £40k & into "luxury" car tax.
  11. No, mine launched a myriad of updates on the way home after picking it up.
  12. I think the message is just bluetooth wanting to pair, as @NottsIan alludes to. Just accept the pairing rather than trying to cancel. If it then launches Android Auto, just use the Skoda icon to return to the inbuilt system. There are also start-up options in Android Auto on your phone.
  13. @Barneyboy48 Maybe post your location in case there's someone nearby who can assist. I find it hard to believe that you need Android Auto enabled, as that implies that you could never pair a phone that doesn't have it. I agree with @NottsIan that you should try to remove any existing pairing & then try again from the bluetooth menu.
  14. On your phone go to Settings > Apps & scroll to Android Auto. Tap on it to open & at the very bottom left of the screen is a Disable option.
  15. The issue for me, & apparently the OP, is more that it also triggers the SatNav screens to flip to night mode making them harder to see in daylight.
  16. Fair comment but there's no reason why Skoda can't make this work properly. I had it on my 2015 Polo & it worked flawlessly. So quite how Skoda have managed to make a pigs ear out of existing, basic, working technology is a mystery.
  17. Low is less sensitive, so should be what you want. But note that they setting can apparently be reset after an OTA software update. Even then the switch is way too early in my opinion. No idea why Skoda have set it so.
  18. Never had it on any car so don't miss it. As @sussamb says, given how the other Skoda "aids" are prone to error, I wouldn't trust it either.
  19. Not checked my Karoq but my Polo had one. It was little more than a thin plastic sleeve & I really can't see it doing much in the way of extra insulation, compared to the thick case of the battery itself. Google threw up this, which suggests it's more relevant to AGM batteries. Battery Heat Shield According to the VAG ERWIN Self-study guide, guide No.504 “Vehicle Batteries- Design & Function”, the engine bay is considered a high temperature place for the battery. This can adversely affect the durability of the battery due to:- “Corrosion of the positive grid, water consumption, & self-discharge increase.”. They also state that AGM batteries must retain the heat shields they have been installed with as they are more susceptible to heat damage. Conversely if your car wasn’t fitted with an AGM battery there is a chance that it won’t have the required heat shields & you will have to retro-fit them.
  20. On my SEL Edition with Columbus: Menu > Vehicle > Settings (bottom right) > Light
  21. Just to add, I revisited the setting today as the screen was again dark & headlights on in bright sunshine. I found that it had reset to "medium", so can only guess that the recent software update reset it to default.
  22. Anecdotal evidence suggests a failing battery can generate numerous assist faults. So it might be an idea to get it tested.
  23. I think the daylight sensor is just over-sensitive to low light. When I bought mine in June it would switch early evening, in bright sunshine. There is a setting for sensitivity & reducing that helped, but even on it's lowest setting it's been on pretty much all week in the dull weather. Note that changing the setting doesn't appear to be dynamic, in that it doesn't take immediate effect. You have to change the setting & then it takes effect next time you start the car. As for the app, could your subscription have expired?
  24. If you haven't already, I'd try removing the shelf & going for a drive, just to verify that is indeed the cause of the rattle. I would have thought that even with the missing part, the other half would keep it in place.
  25. Thanks guys, sounds like it was from the MY24 Edition builds, so hopefully a retrofit should be possible.
