- Are pre and post catalytic converter lambda/Oxygen sensors interchangeable?
over heating Skoda octavia 2014 mk3 tdi 150bhp
Test the removed thermostat in a big pan of boiling water? Seems to me that if removing it solves the overheating, then it may be the problem?
Couple of questions, SS & ext mirrors related.
So that the car can keep track of how much charge has gone in since it was last 'in charge of charging', I believe.
No mate, the gizmo just senses the current going in/out of the battery and - when engine is running - can instruct the alternator to modify its output voltage accordingly. The gizmo can't stop current from an external charger going in. It's not a switch.
Take the stat out and see if problem disappears.
Rear wiper won't stop/intermittent - No screenwash
Well done fella. I had a feeling you might find something like this. Loom shorts to chassis seem to be getting accidentally/carelessly 'designed in' more and more often, sadly.
That doesn't sound probable to me. When the battery is being charged by an external charger, the car doesn't have control over the voltage being applied. So although the 'gizmo' can measure the amount of charge being added, it isn't able to control it in the same way that it could if the alternator was supplying the charge (by varying the voltage setpoint of the alt). I believe further charging by the external charger will improve the state of charge of this battery.
Map sensor location
There's another hose it's well worth looking at while you're under the bonnet tomorrow. Just above the red square in my edit to your photo is the brake servo vacuum hose (the brake servo being the round black thing at the back of the engine bay). Follow that hose across the back of the engine bay towards the other side until you reach a one-way valve. Have a close look and feel where the rigid plastic hose meets that valve, cracks and leaks there are very common. They seem to often crack on the underside first, which is why I suggest feeling as well as looking.
Map sensor location
Have a look at the looped hose on the left in your picture. Here's one with a big leak that lead to very jerky running on a car with the same engine as yours (60 bhp, 6-valve engine) Viewed/photographed from below with phone camera.
Map sensor location
Doubt it. Can you post a photo of your engine so we can at least know which variant you have?
Map sensor location
Well it's item 4 here on the 60bhp engines intake system; throttle valve control element - Fabia(FAB) [EUROPA 2009 year] (7zap.com) Or item 7 here on the 70 BHP ones intake system; exhaust gas recirculation; activate... - Fabia(FAB) [EUROPA 2009 year] (7zap.com) What do you mean by "stop starting"? Actually cutting out or running jerkily, or what? Need to get the fault codes read really, to see why the car has put the EPC light on. I'd be pretty surprised if that behaviour is being caused by a faulty or dirty MAP sensor, but without fault codes it's all guesswork really.
Map sensor location
What's given you that impression? There are lots of faults that can look like a problem with the MAP sensor, which aren't solved by changing it or cleaning it. I think you'll find it on the end of the inlet manifold closest to the brake fluid reservoir. Which variant of the HTP engine 60 bhp or 70?
Put it on charge for several more hours. Nowt to lose.
Control System For Exhaust.
Or a sensor has a problem, or the EGR does; or simply that they've failed to connect up everything properly while finishing off the jobs done. Have a look around the engine bay, especially at the belt end, looking for dangling connectors. Needs a diagnostic scan to determine the meaning of the fault light. Have a look on here to see if there is a member local to you with VCDS, a software system that is ideal for this scanning. VCDS owners map – Google My Maps
SOLVED: Fabia cranks but won't start - sometimes!
My 'like' reaction was to your "beer, relax and plan"; not the bad news of the compression test results, obviously. It's becoming clear only recently to me that when the twin-cam HTPs lose the timing correlation due to chain slipping, valve damage seems common, possibly even inevitable.
Rear wiper stopped working
Hi Andy, can you post a photo of the circuit board?
Should i walk away?
Fair comment.
Should i walk away?
Because it was a main dealer, and they're not allowed to let any car/owner leave the premises without upselling attempts!
Would a new caliper O seal sort the problem of piston not winding back?
Duplicate of Tech1e's post
That's good.
Check for residual pressure in the expansion tank when the engine is stone cold.
There are a few fasteners like that - with tool size sounding wrong relative to the thread size but actually being correct. It doesn't surprise me to see such a mismatch.
Snip Snip...
May want to take a break from your running for a bit!
Car self-locking itself and lock opens and closes unexpectedly
Sounds similar to something I found this summer on my partner's Fabia. Locking misbehaviour, another possible cause - Skoda Fabia Mk I - BRISKODA The lock unit is probably a bit different on your car, but if it is a similar solder joint failure you might be able to put the system in/out of odd states by physically thumping the door near the lock, either on the inside or outside?
Strange windscreen wiper behaviour
The wiper motor does have a bimetallic strip type thermal trip near to the brush connections, but I would expect that to self-reset fairly quickly after the motor stops, and the stalk is put back to the off position if it were that triggering.
