Everything posted by logiclee
Leaking Panoramic Roof - The Cause and the Cure
Not checked the Yeti but on the Octavia it's combined with the rain/light sensor on vehicles with climatronic.
You have an old and outdated view of aircon and to be fair the button should be relabeled. On old systems the button would run the compressor continuously, drying out the air in the cabin and causing issues you have mentioned earlier. On modern climate systems pressing the button is just allowing the climate to use the compressor if it needs it. If the temperature selected is higher than ambient (Like now and through winter) the climate system will only run the compressor to achieve a comfortable humidity level and stop the windows misting up. I can't detect any change in economy on my 2.0Tdi 150 through winter. You are creating a problem by not letting the system have the ability to run the compressor. When you switch the aircon button off and the condenser temperature returns to ambient any moisture in the system is blown into the cabin that's why you mist up. My previous car didn't even have a button for turning off the A/C. Let the electronics do their thing and save yourself big bills down the line.
It's a false economy nowdays. The climate system is clever, by having the aircon button on it's just gives the climate system the ability to use the aircon compressor. The climate control will only use the aircon compressor when it needs it to maintain temperature or humidity levels. Thus the fuel economy impact is actually very small. And is certainly cheaper than any aircon repair. The only time I turn my aircon off is when I'm driving with the windows open which is probably a few days a year.
I can't answer your question on the leak but only using the aircon when it's hot is a sure fire way of causing expensive problems. The refrigerant is a lubricant and without regular running the seals dry out and the pump can fail.
No, they will be picking up the bill as the car leaked on collection in Autumn last year. A repair was attempted but only lasted a few months.
Well just had word back from Rainworth Skoda, my 2017 requires a replacement cassette.
How tough is the Yeti suspension?
If you use the Yeti for towing and intend an 85mm drop then you will need to consider the tow bar height. Will that drop you below the type approved minimum and will your trailer be too nose down.
My 2017 Yeti is currently back with Rainworth Skoda. Bought in August 2020 but leaked at first rain and was "Repaired" in October. Started leaking a couple of weeks ago. I'll report back on the findings. I've asked for an extended warranty on this repair.
Yeti Specs and offroad button
An iphone 12 problem ?
As far as I know the software is already in the MIB2 head unit. You just purchase an activation key. I've had Four MIB2's with smartlink and all have been perfect but all will the flagship Samsung phones.
99% of these issues are the lead. I've just had the same with Android Auto on my works Citroen van. Tried three different "quality" aftermarket leads and no joy. Fetched the genuine lead from my Yeti and connects solid every time.
To be fair to Rainworth they fixed mine F.O.C as I bought mine from them but unless Skoda stumps up they can't do that for everyone.
Some discussions ongoing on various other forums and social media about Rainworth Skoda Mansfield. They have a tech who has developed a repair technique and they have a mockup cassette to show customers. Apparently proving very successful and now getting referrals from other dealers. Seats out, sunroof out, repair, refit and reseal. full electrics check for water ingress, carpets lifted and dry out, refit seats, 2x air fresher cycles. Around £1400
While I'd agree that the 1.4 150PS petrol is a good choice, especially for short journey low mileage users the torque is significantly less 250nm vs 340Nm. That and no DSG was the reason I went diesel as my Yeti is used extensively for towing.
Obviously a 150 would be Euro 6 and is a new engine so wont need the "Fix" Having lived with a 170 and 150 I'd go for the 150. There is hardly any midrange difference between the two 340nm vs 350nm and the 150 is more responsive, more refined, more economical and less likely to be caught up in ULEZ charges.
So. Off Road button standard on SE-L 4x4 and above, optional on lower 4x4 models. City/Urban and Outdoor basically have different exterior trim, wheels etc plus limited engine choices in some models. 140/170 Euro5 emissions replace by 150 Euro6.
Missing heated seats Yeti Elegance
It's not UK elegance spec and it's a City but 4x4. Did they ever offer a 4x4 City in the UK?
Amundsen Infotainment question
If it's a 2017 with a Bolero (No Sat Nav) you still have smartlink. Get smartlink enabled by the dealer (If it isn't already) connect a Android or Apple phone and you can have google maps on the Bolero which is far superior to VAG satnav.
Windscreen condensation problem
Yes Ford introduced them and held the patent for many years. That's why they ended up being standard on a Fiesta but an expensive option on many other brands. When Ford owned Jaguar and Volvo many of their models has heated screen as standard to. Through the 90's and 00's I had four Sierra's and five Mondeo's and all the V6 sizes. 2.5, 2.8, 2.9 and 3.0 The Sierra 4x4 system was superb, 34% Front / 66% Rear continuous torque split and a viscous limited slip diff in the rear axle. Very predictable and drivable. The first Subaru Impreza's used the same setup. Lee
Leaking Sunroof
£2000 is cheap it's usually around £3500 from a main dealer including labour. Rainworth Skoda Mansfield specialise in a repair service at around £1000
Dash board squeaks
All three of my Yeti's have done this on poorly surfaced roads.
The phantom fuse.
Why are you looking for it?
Yeti 1.4tsi 150
And manual only which ruled it out for me.
Missing our Yeti Urban, did the facelift improve on things like rust and DPF ?
I've had three Yeti's and driven the 150 and 170 extensively. The 150 and 170 have near identical maximum torque. 340 vs 350 NM. So midrange performance is very similar. The 150 being a later engine is smoother, quieter and more responsive and is the nicer unit. The only time the 170 feels stronger is pushing past 3500rpm when the extra power is felt. For me I'd always go for the 150PS as it's a nicer unit to drive with, avoids any complications with the emission systems fix and is compliant for many ULEZ areas.
If you want to avoid the "Fix" issues and want a diesel 4x4 then you need a 150 Tdi. These are a completely new Euro6 engine. As for electrics and zinc inclusions, still some reported issues but I guess time will tell.
