Urgent Advice Needed! Think My Turbo's just let go!
Only 10mins after having a conversation with a friend tonight about how many miles the turbo's done (just short of 125k!) or at least i believe anyway.
Pulling through the rev range then all of a sudden it was like hitting a brick wall the car lost power.
Managed to get it off at the next junction of the M1 and took a look around, ended up pulling the boost hose off as it was sucking flat and there was no thick smoke pouring from the exhaust as id have expected and still isnt.
The turbo doesnt sound like its spooling and it just feels like it keeps wanting to keep on rolling, on the over run.
Came to a hill so started building some speed for the long hill, managed to keep my speed but had to keep the foot to the floor. At which point the EML light has come on.
Is there any possible pipes that could have come off that controls the VNT system, which has now closed and not allowing the turbine wheel to catch any gasses?
Or does it sound like its seized?
I just cant get to grips that the engine isn't pouring smoke out, as ive heard people mention when a boost hose pops off they plume smoke!
Any suggestions would be greatly appreciated, as its coming up to christmas and im not going to have a car. That i feel i can drive without causing more damage.
I've still got the omega, but its declared SORN and not sure with having any NCB i could insure it for a couple of weeks, just to get me around.
Many Thanks In Advance!
Browny_37.
Edited by Browny_37
You need to look up the Brisky map of people with vagcom and scan it.
When I disconnected the MAP sensor I had the same symptoms - no smoke but turbo not working. There was also a new turbo noise at low revs.
HTH
Bas
If worse comes to worse I may be able to source a cheap 1.9TDi turbo.
If the omega was still taxed, then you could have insured it temporarily with dayinsure.com. However you cannot get a tax through that insurance, so it kind of rules it out.
I taxed my Leon with one of those day insurance places. The cover note arrived at home, car arrived at work, untaxed, so I went online, got a cover note, went to the post office, came out with a tax disc.
Could you temporarily add the Omega to your policy while the Octy gets sorted?
Regarding the Octy, I agree with Basil. Get it scanned, check all the hoses first.
I think it will have the fault code because ive actually took the boost pipe out before/after a sensor. As it was sucking flat and causing me to struggle even more.
As for the hoses, i dont think it is them. As they were sucking flat, indicating to me there was no boost. You cant physically hear the turbo spinning.
Edited by Browny_37
Saturday,20,December,2008,12:15:38:09347
VCDS Version: Release 805.1
Data version: 20081017
Chassis Type: 1K0
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56
Mileage: 201180km/125007miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 DJ HW: 028 101 188 3
Component: R4 1,9L EDC 0000SG 6250
Revision: 12345678 Serial number: SKZ7Z0D2619929
Coding: 0003031
Shop #: WSC 66565 257 00032
1 Fault Found:
16683 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 000 - -
Freeze Frame:
RPM: 2772 /min
Torque: 168.0 Nm
Speed: 69.0 km/h
Load: 64.3 %
Voltage: 14.29 V
Bin. Bits: 11000000
Absolute Pres.: 2203.2 mbar
Absolute Pres.: 877.2 mbar
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 N
Component: ASR FRONT MK70 0103
Coding: 0017025
Shop #: WSC 73430 790 00000
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 S HW: 1K0 937 049 S*
Component: Bordnetz-SG 1.0 H29 0704
Revision: 00029000 Serial number: 00000001251789
Coding: 00880F020004140000110D000000000000
Part No: 1Z2 955 119 A
Component: Wischer SK351 012 0401
Coding: 00065525
Shop #: WSC 73430
2 Faults Found:
00188 - Control Circuit 1; Relay for Supply Voltage Terminal 50
010 - Open or Short to Plus - Intermittent
00187 - Control Circuit; Relay for Supply Voltage Terminal 75X
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 K HW: 1K0 909 605 K
Component: 04 AIRBAG VW8 024 0700
Revision: 07024000 Serial number: 00378D055H0F
Coding: 0012340
Address 16: Steering wheel Labels: 1K0-953-549.lbl
Part No SW: 1K0 953 549 HW: 1K0 953 549
Component: Lenksäulenmodul 012 0030
Coding: 0000002
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1Z0 920 900 D
Component: KOMBIINSTRUMENT VD1 3558
Coding: 0003401
Shop #: WSC 22013 576 90947
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 270010480206A5
Coding: 3D0F0140071303
2 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 5
Reset counter: 159
Mileage: 201182 km
Time Indication: 0
Date: 2000.00.00
Time: 01:39:51
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 159
Mileage: 201182 km
Time Indication: 0
Date: 2000.00.00
Time: 01:39:56
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO 3558
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0166
Coding: 0000052
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 G
Component: EPS_ZFLS Kl.1 1301
Address 46: Central Conv. Labels: None
Part No: 1K0 959 433 BJ
Component: KSG 0301
Coding: 19F802003F098505095B010004
Shop #: WSC 20022 576 12536
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1T0 959 702
Coding: 0000052
Address 56: Radio
Cannot be reached
End ---------------------------------------------------------------------
Thanks to Shark_90 for meeting me to see if we could get any where with the fault codes, took this log then cleared and took it for a rather boostless drive.
The EML Light did come on about 5miles after id taken the boost pipe off the intercooler pipe though. Which was put back on for testing of the car.
But after clearing the faults and going out with Ben to do some live reads of the boost pressures as above the car was asking for 2000+ millibar of boost but was sat at the same reading all the time. Whilst driving there is no turbo spoolin noises what so ever, and im not sure if the EGR governs the boost pressures.
Ben then did another fault scan and nothing was logged after the drive.
We may now think it maybe the EGR Valve that is stuck in one position, anyone in the know that can shed some light on the above faults (apart from the radio) then i'd be greatful!
Think i may know what the Intermittent faults are with the relay (clifford hard wired in as the can bus adaptors wouldnt play ball.)
Many thanks to Ben, very helpful and friendly guy!
Glad to be of service :thumbup:
Measuring the boost the car was requesting boost but the turbo was producing next to nothing, there was a change though of a few millibars. I think it was Block 011 I was logging, not sure.
Any ideas anyone?
Faulty N75?
N75? Not sure, the turbo doesn't spool at all. Or at least it doesn't appear to (no spooling noise).
Is the N75 a recirc dumpvalve? If so my petrol turbo split that but it still boosted ok.
But then again this is a diesel, why does VW have to put the exhaust manifold on the rear?!
Should be on the front, would be really easy to get to the turbo then.
Edited by Browny_37
Can anyone else shed any more light on the situation? Could the Variable vane system be stuck?
Will get a video soon, when you come onto over run you get backlash through the gearbox which clunks but the car will keep rolling regardless if you gear down, while on a decent.
The N75 is the actuator for the VNT mecahnism. AIUI, the vanes will default to 'no boost' if the control is lost- like if the wastegate is stuck open on a non-VNT turbo. It's a valve that controls vacuum to the actuator on the turbo. There's no dump valve with a diesel, as there's no throttle to block the inlet, so it's not needed.
Hi thanks for the reply, i think i may have tracked the N75 down....got a pic that i will upload shortly.
Just need someone to clarify it, it does look though as if it comes out of the fuel pump on the end of the camshaft into a body, where a vacuum line comes off of the vacuum box and the other head dissapears right upto and under the bulk head.
I had my arm down the back of the block, tried forcing the actuator rod down. But i didnt have the strength to shove it from where i was looking. Made sure the pipe was on the actuator and had a feel around on the pipe. But wasn't sure where it ran to, it seamt to tail off to the left and forward under the turbo/block.
Ive tried cleaning the MAF out, to no avail....took it a drive with a passenger in and the EML light has re-appeared after it gave a slight kick (presuming it went to limp mode) Although it already feels like that from starting it up!
New Vacuum block on and although the vacuum is much better to the EGR, ive still got the problem. Im wondering now if the vanes have got wedged open. I tried getting a hammer in to give it some gentle persuation earlier on the actuator rod! Didnt suceed in reaching it because of the ruddy EGR Pipe in the way.
Anyone give me any advise, i was expecting VRS Stu to have a comment regarding this.
Im tearing my hair out, as ive no car for over the christmas period.
Game over for the turbo, was taken to a specialist (AT Autos) near parkgate...went on the diagnostic machine, then off with the turbo pipe (exhaust side).
No vanes left on the exhaust side, was told they appeared to be melted away.
Thought there was something wrong about 3 months since when the turbo would start whirring away after 2mins until you blipped the throttle. Looks like its been on its way for a while.
Gets fixed next monday thankfully.
Quick update:
The car still isn't fixed, but this appears to be down to the time of the year and the supplier of the turbo not making the garage aware. That they didnt send one out yesterday, because they dont have any on the shelf.
So heres the following pics.
[/url]Turbo005.jpg
Quick update:
Blimey... thats not right at all :eek:
Nope it dont lol, having to laugh about it.
Because if i dont, i think i'll cry...getting expensive now.....and think i may have whats left of the compressor wheel/shaft lodged in the front of the catalytic convertor.
Hopefully it will still pass emmisions and run right, as the car was pretty much still driveable.
Shame i dont work for the previous company anymore, they had a endescope that i could have shoved down the front section of the cat.
that's possibly the most fooked turbo I've seen :D especially on the intake side. :eek:
Hope no damage has been done elsewhere. :)
Well, ive had any other problems apart from a lack of boost.
Inlet tracks have only got oil residue in them, and i never noticed anything when i took the EGR off to see if it was sticking.
Engine ticks over nice and smooth albeit a distinct smell of diesel fumes hahaha!
All being well if the turbo arrives early in the morning the guy down at AT Auto's is going to hang back and get it all back together with fresh oil. My only concern then is the catalytic, as the MOT runs out next week.
You could gut the cat right out and it will still pass the MOT. It's only a smoke test you know? ;)
regards
Jason
decatted for over 4 years :D
Approx what rev range do they hold it in for the smoke test? Thats my next concern once the brand spanker is put on.
Dont want them holding it in the upper rev range for too long whilst the new turbo is still settling in.
Use to pour smoke out whilst getting anywhere near 3400rpm, hope the new turbo sorts some things out.
For the smoke test they bounce it off the limiter for a second or so - seriously.
If you're worried about smoke just securely attach a block of wood under the throttle pedal to limit how fast / high it revs up. Nothing they can do about it, and can't fail the MOT on it either.
For the record, if mine can pass a smoke test (without a block of wood needed :D) almost any derv car in good condition should.
LOL, its the turbo im worried about....not the smoke lol.
Haven't just put a new turbo on just to bounce the thing off the limiter ahahahaha!
Im really hoping the parts arrive early morning and i can get the car back, cant complain about the service im getting from the actual Skoda Specialist. Polite mannered and doesn't like to see people stuck, i believe he was still at his unit when he phoned to give me an update last night (6:45pm).
