Octavia II Useful Part Numbers
Hi there,
I am not sure that this is the right area to be asking this but does anyone know whether the heavy duty bootliner for a 2006 onwards hatch will fit my new 2011 Octavia vRS. The part number is DCE610001A, if that helps. The reason I ask is I am looking to use the car to dirty mountain bike in the rear and don't really want to grind mud into the boot carpet.
I don't want to order one only to find that it doesn't fit.
Thanks for reading and I look forward to your responses.
Many thanks
Mark
  • Replies 134
  • Views 140.9k
  • Mudflaps, that will fit the vRS even though all dealers seem to tell people otherwise Front Mudflaps KEA 600 002 Rear Mudflaps KEA 600 001 Should be around £20 a pair. Boot hook for the hatch.
  • WaveyDaveyGravy
    WaveyDaveyGravy
    Missed a number off that - it's 1Z0 863 831A - superceded the non-A version. Also 1Z0 949 102C - drivers side mirror indicator 1Z0 857 538A GRU - drivers side mirror cover (primed)
Hi there,
Many thanks
Mark
The "heavy duty" boot liner has a different part no (ZGB1Z3061163) according to the Skoda Accessories site, and is *only* listed in the 2006-2009 section.
http://www.accessories.skoda.co.uk/productsList.aspx?type=a&id=7&main=Car%20Care%20and%20Protection⊂=Bootliners
The DCE610001A liner is just classed as a "plastic boot liner" and appears in both the 06-09 and >09 sections, so it should fit fine:
http://www.accessories.skoda.co.uk/productsList.aspx?type=a&id=12&main=Car%20Care%20and%20Protection⊂=Bootliners
Also a couple of threads here (from search) you might find useful:
http://briskoda.net/forums/topic/200727-boot-liner-recommendations/
http://briskoda.net/forums/topic/202684-boot-liner/
Hi there,
Many thanks
Mark
I've got DCE610001A in my 2008 Octavia - Quality and Fit is fantastic. It has pre moulded 'cut outs' for the lashing eyes (the other boot liner appears not to have these).
Only other thing to note is DCE610001A leaves a small space at the left, where you might have a cd changer. On the other boot liner, it seems to cover this area fully to the left.
Thanks for the replies guys.
I have been in contact with the dealership I am getting the vRS from and they are doing a deal for me on a bootliner which will be fitted in the car when I collect it.
Total price £45.05.
Result!!!
if i was buying a new car off them i'd want it for free!
Can anyone add the part numbers for the brake pads and discs for the FL 1.6 tdi?
  • 4 weeks later...
FL 1.6 TDI
front disks 1K0 615 301 AK
front pads 1K0 698 151 F
rear disks 1K0 615 601 AB
rear pads 1K0 698 451 J
Anyone know the part number for the new sharkfin/stubby aerial on the FL/octavia,,,
Is there a silver surround central console for the Columbus on cars with A/C rather than climate control? Every list for these part numbers only shows a black surround, not a silver one.
Thanks,
John
Thanks,
John
I just fitted a columbus to replace my bolero in FL octavia with AC and would like part number for the appropriate trim in silver too. The bolero trim leaves a big gap around the columbus.
Anyone have the part number for the drivers side rear red reflector - mine is cracked thanks Stu....
Mine too. The reflector that is inset into the rear bumper that is.
Would appreciate a part now if anyone has one.
Thanks in advance
1.9TDi 2006
038115301E - Oil filler neck - £9.84 incl.vat
This part is the extension between the rocker cover and oil filler cap.Mine kept coming undone when filler cap removed.Worth checking as oil leaks down back of rocker cover from the extension seal if not correctly sealed.
Hi all, Does anybody happen to know the part number for the original Air Filter box for a 06 VRS?
Thanks in advance
  • 4 months later...
Wee clips that hold the dash side panels to the dash body - 1J0 858 137 B
If you want the Piano Black trim for the Columbus in new style Climatronic cars then 1Z0858069CQN77 (1Z0 858 069 CQN77) is the part number you need. Skoda Parts got one for me.
I got the part number from this Russian site http://demo.saleepc.ru/skoda/parts/43/8/124019 which also had lots of other part numbers for that trim in different colours.
  • 2 months later...
need the trim above part number for the carbon affect for octavia 2012 for the columbus sat nav cannot find this anywere and skoda have not got a clue
  • 4 weeks later...
I got the part number from this Russian site http://demo.saleepc....rts/43/8/124019 which also had lots of other part numbers for that trim in different colours.
is there a part no for this trim in satin black ?
cheers
lee
Sadly that Russian site with the list of part numbers is gone for some reason. Your best bet is to contact skodaparts, tell them that you want that trim (they have it listed) but in satin black and they'll get it added to the site for you. Thats what they did for me.
:happy: thanks will give them a call
cheers
  • 4 months later...
I'm looking for this trim part number in Carbon Look please !
Trim for Columbus for FL with new Climatronic in Carbon Look = 1Z0 858 069 FB UV9
  • 3 months later...
That Russian list seems to be back online but I'm not quite sure how to use it, I've run it through Google translate but it doesn't make any more sense. I'm still trying to find silver Columbus trim for a car with standard A/C (no climate control)
Edit - Mailed Skodaparts, will see what they say
John
Edited by JohnMcL7
According to ETKA, the silver (aluminium) trim for navigation units and standard aircon (not climatronic) is 1Z0 858 069 CT 2AU
Mike
Thanks very much for the reply Mike, I assume ETKA is some sort of stock inventory system? I did a search for that part number to see if anyone else had used it but only came across this which doesn't make much sense:
All these are listed as D >> 06.11.2011 which I assume means "PRIOR to 06.11.2011"
trim for heater switch:
1Z0 858 069 CT
1Z0 858 069 CT 2AU - finely turned aluminum
trim for heater switch for vehicles with navigation system:
1Z0 858 069 DA
1Z0 858 069 DA 2AU - finely turned aluminum
1Z0 858 069 DB
1Z0 858 069 DB 2AU - finely turned aluminum
1Z0 858 069 DC
1Z0 858 069 DC 2AU
Up to 2011 would be FL or have they misinterpreted it? Also they seem to be showing DA for the navigation version rather than CT? Once I've definitely got the right part number can I just order this up from my local Skoda garage or does it have to be through someone like Skodaparts? That part number is coming up at £50 unfortunately with them although there's no picture or much detail on the site.
Thanks very much again,
John
  • 4 months later...
I've yet to find the answer on here so I'll add that if you buy the piano black Columbus surround, the numbers for the piano black ashtray and gear gaiter surround to match are 1Z2863212N77 and 1Z2857962N77 respectively.
