Octavia II Useful Part Numbers
Hi there, long shot how do i get a replacement one of this which holds rear wiper for an 2008 08 octy mk2 vrs hatch? Ryan
Edited by Octavia_VRS
  • Replies 134
  • Views 141.2k
  • Mudflaps, that will fit the vRS even though all dealers seem to tell people otherwise Front Mudflaps KEA 600 002 Rear Mudflaps KEA 600 001 Should be around £20 a pair. Boot hook for the hatch.
  • WaveyDaveyGravy
    WaveyDaveyGravy
    Missed a number off that - it's 1Z0 863 831A - superceded the non-A version. Also 1Z0 949 102C - drivers side mirror indicator 1Z0 857 538A GRU - drivers side mirror cover (primed)
Anyone have the part number for the drivers side rear red reflector - mine is cracked thanks Stu....
1Z0 858 069 AC BE9 Trim panel for Columbus and New style climatronic, silver with cross hatch finish (MY2011 Elegance)
1Z0 858 069 AA BE9 Trim panel for Bolero and New style climatronic, silver with cross hatch finish (MY2011 Elegance)
  • 4 weeks later...
Radiator 1K0121251DM £165
Cooling Fan 1K0959455ES £152
06F 906 283F for the N75 valve and the clips (3 needed) are N10 203 601
4 Piece Textile Floor Mat Set - with vRS logo
ZGB1Z3061246
Octavia vRS 2006 > 2009 (Twist Fixings)
ZGB1Z3061247
Octavia vRS 2006 > 2009 (Stud Fixings)
just thought i'd add these since i just ordered a set and it took me far too long to find them :p
Part number for Octavia II headlight switch.!!with auto function.
auto headlight, 2 function fog light etc.........>>>>>>>>>1Z0 941 431 A 3X1
Hi, all,
Anyone know the part number for the centre cappings on the 18" wheels fitted on my 56 plate VRS?
Or better still where to get a set from?
Thanks, Lee
Telephone control buttons for MFSW
I've just finnished installing OEM bluetooth module (1Z0 035 729B) on my 2007 Octavia L+K.
Car was supplied without bluetooth, so the set of 4 buttons on left side of steering wheel operate head unit only.
I wanted full functionality of the bluetooth module and found only being able to use the buttons at the end of the wiper stalk tiresome.
This is what I wanted:
Part no is: 1Z0 959537 A
Dealer price is £93.92 + vat (£112.70)
You can buy for half that by contacting Ales Prochazka at www.skodeteile.cz
That's where I got mine from (arrived in 2 weeks). I wouldn't have had a clue what the part no was until it actually arrived!
Centre wheel caps for 18" Zenith Alloys 6U0601151LMHB - £7ea
Tailgate Skoda badge 1U0853621CMEL - £15
These both fit my 56 plate VRS.
FL Front Chrome Grille Surround - 1Z0853661A739 - £46.95 + VAT
Badge for the centre of the above surround - 3U0853621BMEL - £12.57 + VAT
VRS badge for above - 1Z0853679BAQ - £8.33 + VAT
Fuel temp sensor for 2.0 PD140 TDi
038 906 081V - £15.49+vat
Edited by corradoboy
Gear knob for an 06 VRS 6 speed octavia.
Price ad part number would be great if anyone knows. Got the age old problem f the chrome effect wearing off :)
All for a 1.9TDi:
Cambelt + kit 038198119A £94.61 + vat
Water Pump 045121011HX £34.91 + vat
Stretch bolts for engine mounting x2 £2.05 + vat
Bracket for boot mounted cd changer 1Z0 035 221
Repair parts for brake warning sensor, end of car loom.
Contact housing - K1J0973802 (1 needed)
Wire set, single wire but has connector each end, - K000979132E (1 needed)
Grommet, rubber to cover wire & seal connector, - K1J0906102 (1 needed)
Grommet, small to go on single wire into connector, K357972740E (2 needed, but don't have to use)
Total cost @ £5
Easy fix, takes 5 minutes + time jacking car up/down wheel on/off. Took me less than half hour.
Kevin
Silver Columbus dash trim for Octavia II vRS with New style Climatronic:
Octavia II vRS Limited Edition
1Z0 858 069 BK 2AU - flat/matt silver finish
Octavia II vRS Facelift
1Z0 858 069 DK DF1 - light tonal brushed finish
Can someone please tell me what is the price for the second dash trim - for Octavia vRS Facelift. Here in Bulgaria the price for a normal dash trim - for the PreFL Octavia was about 7-8 EUR. Today the local dealer told me that the price for this one (for vRS FL - with new Style Climatronic - 1Z0 858 069 DK DF1) is about 58-60 EUR. Do you think this is normal price ?
Thank you in advance.
I've created a list of some part numbers for common parts on the octy II.
Please note all part numbers should be checked with the dealer/supplier before ordering as parts may be vehicle specific.
Common:
  • Space saver spare wheel (without tyre) - S 1K0 601 027 K03 C
  • Centre cap for pegasys alloy wheel (each) - 6u0 601 151 LMH B
  • Rear Wiper Blade - 1k0 955 429 A
  • Estate Rear Wiper Blade - 7E0 955 425
  • Aero Wiper (drivers side) - 1Z2 955 426 A
  • Fuel Filler flap (Primed) - 1Z5 809 857 F
  • 312mm (VRS) Front Brake Disks - 1K0 615 301 AA
  • Extinguisher Holder - GCA 600 001
  • Fire Extinguisher - GCA 000 001
  • Stainless Sill Covers - KDA 600 002
  • Carpet Mats (Black) - DCA 600 102
  • Front Mudflaps - KEA 600 002
  • Rear Mudflaps - KEA 600 001
  • Dash trim for MFD2/3 with Climatronic (black) - 1Z0 858 069 C 9B9
  • Dash trim for MFD2/3 with Climatronic (silver) - 1Z0 858 069 R 2AU
  • Dash trim for MFD2/3 with Climatronic and phone cut outs (silver) - 1Z0 858 069 Q 2AU
  • Dash trim for Stream/Stream MP3 with Climatronic (black) - 1Z0 858 069 A
  • Dash trim for MFD2/3 for VRS LE and FL Octavia with New style Climatronic. - 1Z0 858 069 BK 2AU
  • Single DIN Radio Adaptor kit - AZO 600 003
  • Speaker trim (tweater, drivers door) - 1Z2 867 4369 B9
  • Boot Hook (Hatchback) - DMA 610 007
  • Underseat storage box (RH seat - Onyx) - 1Z0 881 578 E 47H
  • Underseat storage box (RH seat - Ivory) - 1Z0 881 578 E 4K1
  • Wheel nut cover - 1Z0 601 173 Z37
  • Wheel nut cover (locking nut) - 1Z0 601 173 A Z37
  • Under bonnet sounds insulation sheet (As found on diesels) - 1Z0 863 831 A
  • Improved design engine cover grommets - 03G 103 184 C (note this is a single grommet)
2.0 TDI
  • Oil Filter - 071 115 562 C
  • Air Filter - 1K0 129 620 D
  • Pollen Filter - 1K2 319 652 B ( Charcoal Type)
  • Fuel Filter - 1K0 127 434
  • Sump Plug - N90 913 202
1.9 TDI
  • Pollen Filter - 1K0 819 644 B (Standard type)
  • Sump plug - N90 813 202
  • Fuel Filter - 3C0 127 434
  • Front Brake Discs - 1K0 615 301 AC
  • Front Brake Pads - 1K0 698 151 A
  • Rear Discs - 1K0 615 601 AB
  • Rear Pads - 1K0 698 451 J
  • Brake disc screws - N10 648 301
  • O/S/F Hub Assembly - 1K0 407 256 P
  • Hub Bolt(strut to hub pinch bolt) - 1J0 615 219
2.0 TFSI
  • Diverter Valve - 06H 145 710 D
  • Coilpacks - 07K 905 715 F
  • Air Filter - 06F 133 843 A
2.0 FSI
1.8 TSI
Related Guides
Extinguisher fitting guide:
http://briskoda.net/forums/topic/88620-octy-ii-fire-extinguisher-how-to/
Storage box fitting guide:
http://briskoda.net/octavia-ii/how-add-underseat-storagebox-pictures/78479/
Feel free to update this list as and when you have part numbers.
Hi, i wonder if you could help me. i am wanting to put a MDF3 in to my 55plate Octy 2. It doesn't have Climate control and i wondered if you knew what the facia part number would be?
Regards.
Chris
Hello all. I'm looking to get a part number for the motor that opens the boot. Any help is very much appreciated
Gar
Wing mirror housings, pre-facelift only and NOT FOR LE!!
Drivers side: 1Z0 857 538 A
Passengers side: 1Z0 857 537 A
HTH :)
Looking for part number for Octy FL Clima (not Climatronic) Columbus trim.
Octavia Scout bits (MY 2007)
Front brake pads: 1K0698451G
Rear brake pads: 5K0698151
Left rear bump stop - buffer: 3C0511359
Left rear bump stop - ring: 1K0513167
Common:
2.0 TDI
1.9 TDI
2.0 TFSI
2.0 FSI
1.8 TSI
Related Guides
http://briskoda.net/...guisher-how-to/
http://briskoda.net/...pictures/78479/
dont know if you want to alter the pollen filter (charcoal type) as its 1K2 819 653 B
