Octavia II Useful Part Numbers
Just been told the wheel code should be: ZGB1Z0071499
Should have worn my glasses sorry!! the 2 should be a Z B):D
  • Replies 134
  • Views 141.2k
  • Mudflaps, that will fit the vRS even though all dealers seem to tell people otherwise Front Mudflaps KEA 600 002 Rear Mudflaps KEA 600 001 Should be around £20 a pair. Boot hook for the hatch.
  • WaveyDaveyGravy
    WaveyDaveyGravy
    Missed a number off that - it's 1Z0 863 831A - superceded the non-A version. Also 1Z0 949 102C - drivers side mirror indicator 1Z0 857 538A GRU - drivers side mirror cover (primed)
Spare-wheel "kit" for Octavia (01/2010):
Space saver spare wheel & tyre (16" steel rim + 205/55 R16 tyre): S1Z0601011A
Tool kit of jack & spanner etc: S1Z0071108A
For those whom receive their car without the factory-fit spare-wheel option.
part number request for the flexible fuel lines which are connected to high pressure fuel pump on 2.0 tfsi
Barney.
Anyone know the part number for the engine cover mounting pegs (per picture). Dealer seems to be struggling with this
Hi,
Anyone know the part number for the drivers grab handle - i.e the bit of plastic to which the electric window controls (x4) attach. It is for a FL Octavia VRS. Also, how much is this part?
have you got a picture from a bit further away?
The following list I found on www.octavia-forum.de
I have copied it straight from Google Language Tools... clearly there are some useful gems here, and whilst not all of the items will make it on to the front page, I hope it will be useful for someone looking for something.
Hope it helps someone,
Gavin
Accessories and Spare Parts
- Škoda Octavia II Combi - Skoda Octavia II Combi
- Škoda Octavia II Combi 4x4 - Skoda Octavia II Combi 4x4
- Škoda Octavia II Limousine - Skoda Octavia II Limousine
- Ablagesitz unter Fahrersitz Bestell-Nr: 1Z0881577E 47H ~15,00€ - Storage under the driver seat Order No.: 1Z0881577E 47H ~ 15,00 €
- Fach unterm Fahrerseitz 6Y0 881 577 A - Under the driver's compartment Seitz 6Y0 881 577 A
- Fach unterm Beifahrerseitz 6Y0 881 578 A - Under the passenger compartment Seitz 6Y0 881 578 A
- dazugehörige Klappe 6Y0882615A47H - Associated flap 6Y0882615A47H
- Dämmmatte Motorraum Bestell-Nr: 11 2J 1Z0 863 831 - Pad, Engine Order Code: 11 2y 1Z0 863 831
- Türclipse 6Y0 867 260 - Türclipse 6Y0 867 260
- RS Fußmatten 1Z1 863 011 C 62U - RS floor mats 1Z1 863 011 C 62U
- WiWaSi 1C0 955 485 (Audi, VW) 1,00€-2,00€ - WiWaSi 1C0 955 485 (Audi, VW) 1.00 € -2.00 €
- Dachkantenspoiler Nr.: FAA 420 001 ~132,00€ - No roof spoiler: FAA 420 001 ~ 132.00 €
- Nachrüstsatz GRA Teile-Nr. - GRA retrofit kit part no. BEA 600 002 ~89,00€ Einbau BEA 600 002 ~ € 89.00 Installation
- Taschenlampen für Zigarettenanzünder ( VW/Audi/Porsche) 19,90-22,04€ - Torch-lighter (VW / Audi / Porsche) 19,90-22,04 €
- Teileliste Passat (teilw. zum Octavia kompatibel) - Parts list Passat (partly with the Octavia compatible)
- Kopfstütze hinten mittig RS ab 08/07 1Z0885902BN1FF ~205€ - RS from the center and rear head restraints 08/07 1Z0885902BN1FF ~ 205 €
- Kopfstütze hinten mittig RS bis 08/07 1Z0885902BD1FF 97,80€ - RS rear center headrest to 08/07 1Z0885902BD1FF 97,80 €
-Tempomatschalter Teilenr.: 1K0 953 513 A (8L0 953 513 H Audi/VW) Part-cruise control switch.: 1K0 953 513 A (8L0 953 513 H Audi / VW)
- Kombiinstrument (KI) RS Teilenummer: 1Z0 920 841 C - Combined Instrument (CI) RS Part No: 1Z0 920 841 C
- Kombiinstrument (KI) für FSI TN: 3UO 920 841 A 5E2 - Combined Instrument (CI) for FSI TN: 3UO 920 841 A 5E2
- Wasserpumpe 1,9 TDI 045 121 011 F (VW) - Water 1.9 TDI 045 121 011 F (VW)
- automatisch abblendbaren Innenspiegel mit Regensensor 1Z0 857 511 A 9B9 - Automatic-dimming inside mirror with rain sensor 1Z0 857 511 A 9B9
- Zündspule (1,4/1,6l) 036 905 715 E (VW/Audi) - Ignition coil (1.4 / 1.6 l) 036 905 715 E (VW / Audi)
- Pumpedüse-Einheit 03G 130 073 G (Bosch-Nr. 0414720404) ~622€ - Pump nozzle unit 03G 130 073 G (Bosch-Nr. 0414720404) ~ 622 €
- Zündgerät Xenon Licht 1UO 941 641 180,35€ - Ignitor Xenonlicht 1UO 941 641 180.35 €
- Fußmattenbefestigungen - Mats fixtures
Steuergeräte Controllers
- Steuergerät - Multifunktion 1J0907487A - Control Unit - Multi-Function 1J0907487A
- Steuergerät für Gateway 1K0 907 530 F - Control Unit for Gateway 1K0 907 530 F
- Steuergerät Parkhilfe 1Z0919283C - Park Assist Control Unit 1Z0919283C
- Steuergerät Clima/Heizung 1Z0 907 044 J - Climate control / heater 1Z0 907 044 J
Schaltknauf Shift knob
- Schaltknauf Passat 3C0 711 113 Leder 50,00€* - Knob Passat 3C0 711 113 Leather € 50.00 *
- Schaltknauf Leder schwarz 1Z0 711 141 F 34E Leder 80,00€* - Black leather shift knob 1Z0 711 141 F 34E Leather € 80.00 *
Kühler-/ Kondensatorschutz Radiator / condenser protection
- Schutzgitter 1K0 820746 4,45€* - Protective 1K0 820,746 4,45 € *
- Clipse 3D0 867646 0,17€* - Clipse 3D0 867,646 * 0,17 €
ABS Sensoren ABS Sensors
- ABS EDS Drehratensensor hinten Links 1K0927807 - ABS, EDS Yaw Rate Sensor Rear 1K0927807 Links
- ABS EDS Drehratensensor hinten rechts 1K0927808 - ABS, EDS angular rate sensor, rear right 1K0927808
- ABS EDS Drehratensensor hinten Links 7H0924804 vorne rechts - ABS, EDS angular rate sensor, right front and rear links 7H0924804
- ABS EDS Drehratensensor hinten Links 7H0924803 vorne links - ABS, EDS angular rate sensor, left front and rear links 7H0924803
- ABS Drehratensensor Hinterachse 1J0927807B - Yaw Rate Sensor Rear ABS 1J0927807B
Radschraubenkappen Radschraubenkappen
- normale Radschrauben schwarz-glänzend 1Z0 601 173 9B9 0,90€ - Normal wheel-gloss black 1Z0 601 173 9B9 € 0.90
- diebstahlhemmende Radschrauben schwarz-glänzend 8D0 601 173 E 9B9 0,76€ - Theft-wheel-gloss black 8D0 601 173 E 9B9 € 0.76
- normale Radschrauben chromfarben-metallic 1Z0 601 173 7ZS 0,90€ - Standard wheel bolts chrome metallic 1Z0 601 173 7ZS € 0.90
- diebstahlhemmende Radschrauben chromfarben-metallic 8D0 601 173 E 7ZS 0,76€ - Theft-wheel chrome metallic 8D0 601 173 E 7ZS € 0.76
- normale Radschrauben grau-metallic 321 601 173 A Z37 (VW) 0,30€ - Normal bolts Gray Metallic Z37 A 321 601 173 (VW) 0.30 €
- diebstahlhemmende Radschrauben grau-metallic 8D0 601 173 D Z37 (VW) 0,30€ - Theft-wheel-gray metallic 8D0 601 173 D Z37 (VW) 0.30 €
- normale Radschrauben schwarz 6X0 601 173 B 01C (VW) 0,23€ - Normal wheel black 6X0 601 173 B 01C (VW) 0.23 €
- diebstahlhemmende Radschrauben schwarz 6X0 601 173 A (VW) 0,23€ - Theft-wheel black 6X0 601 173 A (VW) 0.23 €
- Ziehhaken für Radschraubenkappen 8D0 012 244 A (VW) 0,92€ - Ziehhaken for Radschraubenkappen 8D0 012 244 A (VW) 0.92 €
- Ziehhaken für Radkappen und Orginal Passat-Radschraubenkappen 6X0 012 243 (VW) 0,48€ - Ziehhaken for hubcaps and original Passat Radschraubenkappen 6X0 012 243 (VW) 0.48 €
Freisprecheinrichtung (FSE) Einbau Speakerphone (FSE) Installation
- BT-Antenne 3P0 035 503E 10,00€-12,00€ - BT antenna 3P0 035 503E 10.00 € -12.00 €
- Steuerteil-5P0 862 335 C ~160€ - Tax Part-5P0 862 335 C ~ 160 €
- Mikrophon-3B0035711B mit Schnittstellkabel 16Euro - Microphone 3B0035711B with Cut Control Cable 16Euro
- Anschlussstecker für Steuerteil mit Pins-4E0 972 144 6Euro - Connectors for control unit with pins-4E0 972 144 6Euro
- Steuerteilehalter-1Z0 035 815 6,50Euro - Control parts holder 1Z0 035 815 6.50 Euro
- Abdeckung IF schwartz 1Z0 971 813 62U 4,50Euro - IF cover schwartz 1Z0 971 813 62U 4.50 euros
- Handyhalter(ohne Handyadapter)-1Z0 858249+1Z1 857371 B+Anschlusskabel 35Euro - Mobile phone holder (no phone adapters)-1Z0 858249 +1 Z1 857,371 B + connection 35Euro
- Telefonverlängerungkabel-1Z1 036 723 F 12Euro - Phone Extension Cable 1Z1 036 723 F 12euro
- Dachtantenne fur Telefon und Radio-1U0 035 505 G - 10Euro - Dachtantenne for telephone and radio-1U0 035 505 G - 10Euro
- Kabelsatz Z 137 000 66 59€ - Cable set Z 137 000 66 59 €
- Basiskit Z 137 001 75 95€ - Basic kit Z 137 001 75 95 €
- Konsole Z 137 000 68 49,90€ - Console Z 137 000 68 49.90 €
- Ladeschale für Sony Ericsson K800/810i ATC 600 027 ~105€ - Charger for Sony Ericsson K800/810i ATC 600 027 ~ 105 €
Ladeluftkühler (LLK) Intercoolers (LLK)
- Ladeluftkühler (Audi S3) 1k0 145 803 P 243,02€ - Intercooler (Audi S3) 1k0 145 803 P 243.02 €
- Druckschlauch (Audi S3) 1k0 145 834 AA 27,09€ - Pressure hose (Audi S3) 1k0 145 834 AA 27.09 €
- Verbindungsrohr (Audi S3) 1k0 145 832 L 55,45€ - Connecting tube (Audi S3) 1k0 145 832 L 55.45 €
Scheibenwischer Wiper
- Scheibenwischer vorne 1Z1 998 001 - Windshield wipers front 1Z1 998 001
- Linkslenker, 650mm AERO 1K0-955-429-B - LHD, 650mm AERO 1K0-955-429-B
- Linkslenker, 700mm AERO 1K0-955-429-C - LHD, 700mm AERO 1K0-955-429-C
- Wischermotor mit Gestänge vorne 1Z1 955 119 A - Front wiper motor with linkage 1Z1 955 119 A
Umfeldbeleuchtung Surround lighting
- Blinkleuchte mit Umfeldbeleuchtung Links (ein Aufnahmepunkt fehlt) 1Z0949101D Einbau - (Blinking Light with surround lighting left a recording point is missing) 1Z0949101D Installation
- Blinkleuchte mit Umfeldbeleuchtung rechts (ein Aufnahmepunkt fehlt) 1Z0949102D Einbau - (Blinking Light with surround lighting right recording point is missing) 1Z0949102D Installation
- Blinkleuchte mit Umfeldbeleuchtung Links (zwei Aufnahmepunkte) 1Z0949101B Einbau - Flashing light with surround lighting links (two receiving points) 1Z0949101B Installation
- Blinkleuchte mit Umfeldbeleuchtung Links (zwei Aufnahmepunkte) 1Z0949102B Einbau - Flashing light with surround lighting links (two receiving points) 1Z0949102B Installation
- Kabel 000979131 Einbau - Cable Installation 000979131
Tagfahrlich (TFL) Daytime running TFL) (
- Tagfahrlicht vom Audi S6 266,95€ - Audi S6 daytime running lights from 266.95 €
Aussenspiegel Exterior Mirror
- Spiegelglas links blau getönt 1Z1-857-521-K Einbau - Blue-tinted mirror glass left 1Z1-857-521-K Mounting
- Spiegelglas rechts blau getönt 1Z1-857-522-K Einbau - Blue-tinted mirror glass to the right 1Z1-857-522-K Mounting
- Abdeckkappe Aussenspiegel schwarz unlackiert links Skoda: 1Z0 857 537 B41/ VW: 1Z0 857 537 9B9 Skoda:26,60€*/ VW: 7,05€* - Cap mirrors black left unpainted Skoda: 1Z0 857 537 B41 / VW: 1Z0 857 537 9B9 Skoda: 26,60 € * / VW: 7,05 € *
- Abdeckkappe Aussenspiegel schwarz unlackiert rechts Skoda: 1Z0 857 538 B41/ VW: 1Z0 857 538 9B9 Skoda:26,60€*/ VW: 7,05€* - Cap mirrors painted black right Skoda: 1Z0 857 538 B41 / VW: 1Z0 857 538 9B9 Skoda: 26,60 € * / VW: 7,05 € *
- Abdeckkappe Aussenspiegel schwarz unlackiert links Skoda/VW:1Z0 857 537 A GRU Skoda:23,10€*/ VW: 21,95€* - Cap mirrors black left unpainted Skoda / VW: 1Z0 857 537 A GRU Skoda: 23,10 € * / VW: 21,95 € *
- Abdeckkappe Aussenspiegel schwarz unlackiert rechts Skoda/VW:1Z0 857 538 A GRU Skoda:23,10€*/ VW: 21,95€* - Cap mirrors painted black right Skoda / VW: 1Z0 857 538 A GRU Skoda: 23,10 € * / VW: 21,95 € *
Brillenfach Eyeglass compartment
- Brillenfach 868 565 E Y20 perlgrau 18,60€* Einbau - Glasses compartment 868 565 E Y20 perlgrau € 18.60 * Installation
- Brillenfach 868 565 E 4K1 ivory 18,60€* Einbau - Glasses compartment 868 565 E 4K1 ivory 18.60 € * Installation
- Brillenfach 868 565 E 47H onyx 18,60€* Einbau - Glasses compartment 868 565 E 47H onyx € 18.60 * Installation
Schalter Switch
- Schalter Parksensor vorne (auch gerne als Garagenöffner genutzt) Bestellnummer 1Z0919281A3X1 ~15,00€ Einbau - Parking sensor on the front switch (also often used as garage door openers) Order 1Z0919281A3X1 ~ 15,00 € Installation
- Schalter Reifendruckkontrolle (auch gerne als Garagenöffner genutzt) Bestellnummer 1Z0 927 127 A 3X1 ~15,00€ Einbau - Tire Pressure switch control (also often used as garage door openers) Order 1Z0 927 127 A 3X1 ~ 15,00 € Installation
- Außenspiegel Verstellung Schalter 1Z19595685A 12,45 Euro - Mirrors adjustment switch 1Z19595685A 12.45 Euro
- Wasserstandschalter 1Z0 920 812 D - Water level switch 1Z0 920 812 D
Radio & Navigation(Blenden usw.) Radio & Navigation (diaphragms, etc.)
- Triplex Antenne 1U0 035 507 A - Triplex antenna 1U0 035 507 A
- Radio Stream Teilenummer 1Z0 035 161 B / AAO 60 002 A - Radio Stream Part No. 1Z0 035 161 B / AAO 60 002 A
- Radio Symphony 1U0 035 161D - Radio Symphony 1U0 035 161D
- Radio Audience 1Z0035156B - Radio Audience 1Z0035156B
- Navigationssystem 1Z0 035 191 - Navigation 1Z0 035 191
- Armaturenblende Octavia II für Klimatronic und Navi 6,84 € Bestell-Nr. - Diaphragm valves Octavia II Klimatronic and Navi 6,84 € Order no. 1Z0-858-069-C -9B9 Einbau 1Z0-858-069-C-9B9 Installation
- Doppel-DIN-Ablagefach vom VW Bestell-Nr. - Double-DIN storage compartment from VW Order no. 1K0-857-058 3X1 18,85€ Einbau 1K0-857-058 3X1 Built 18,85 €
- Einlage für Ablagefach vom VW Bestell-Nr. - Insert for storage compartment of the VW Order no. 1K0-858-169 9B9 3,48€ Einbau 1K0-858-169 9B9 € 3.48 Installation
- Springmuttern vom VW Bestell-Nr. - Spring Nuts from VW Order no. N-906-989-01 0,79€ Einbau N-906-989-01 0.79 € Installation
- VW Golf V Radioadapterkabel ISO/Quadlock incl. Phantomspeisung FACRA von design 4 more Bestell-Nr. - VW Golf V Radio Adapter Cable ISO / Quadlock including phantom power FACRA of design 4 more Order no. 70087.1 19,91€ ( Radioblenden.de ) Einbau 70087.1 19.91 € (Radioblenden.de) Installation
- RTA Mobile Zündplus-Adapter Audi/VW 11,80€ (audi-eqipment) Einbau - RTA Mobile Ignition Adapter Audi / VW € 11.80 (audi-eqipment) Installation
- Verstärker RS 1Z0 035 456 DSP - Amplifier RS 1Z0 035 456 DSP
- Tieftöner RS 1Z0 035 411 D - Woofer RS 1Z0 035 411 D
- Tieftöner RS 1Z0 035 411 L - Woofer RS 1Z0 035 411 L
- Mitteltöner RS 1Z0 035 411 J - Midrange RS 035 411 J 1Z0
- Mitteltöner RS 1Z0 035 411 K - Midrange RS 1Z0 035 411 C
- Hochtöner RS 1Z0 035 411 M - Tweeter RS 1Z0 035 411 M
- RS/ Ambiente Blende für Climatronic & Navi ohne Telefonvorbereitung (Bj. 10/05-03/07)- 1Z0 858 069 L 2AU 19,60 €* Einbau - RS / aperture setting for Climatronic & Navi without telephone preparation (Bj 10/05-03/07) - 1Z0 858 069 L 2AU € 19.60 * Installation
- RS/ Ambiente Blende für Climatronic & Navi ohne Telefonvorbereitung (Bj. ab 04/07) - 1Z0 858 069 R 2AU 19,60 €* Einbau - RS / aperture setting for Climatronic & Navi without phone preparation (ab Bj 04/07) - 1Z0 858 069 * R 2AU € 19.60 Installation
- RS/ Ambiente Blende Climatronic & Radio ohne Telefefonvorbereitung 1Z0858069J2AU 19,60 €* Einbau - RS / aperture setting Climatronic & Radio without Telefefonvorbereitung 1Z0858069J2AU € 19.60 * Installation
- RS/ Ambiente Blende Climatronic & Navi mit Telfeonvorbereitung (bis 03/07) 1Z0858069Q2AU 36,70 €* Einbau - RS / aperture setting Climatronic & Navi with Telfeonvorbereitung (until 03/07) 1Z0858069Q2AU € 36.70 installed *
- RS Blende Climatronic & Navi mit Telfeonvorbereitung (ab 04/07) 1Z0858069S2AU 36,70 €* Einbau - RS Aperture Climatronic & Navi with Telfeonvorbereitung (from 04/07) 1Z0858069S2AU € 36.70 * Installation
- RS/ Ambiente Blende um Radio Climatronic & Telefonvorbereitung, ohne Navi)1Z0858069N2AU 36,70 €* Einbau - RS / aperture setting to Climatronic Radio & Telephone preparation, without Navi) 1Z0858069N2AU € 36.70 * Installation
- RS/ Ambiente Blende Climatic ohne Telefeonvorbereitung 1Z0858069H2AU 19,60 €* Einbau - RS / aperture setting Climatic without Telefeonvorbereitung 1Z0858069H2AU € 19.60 installation *
- RS/ Ambiente Blende Climatic mit Telefeonvorbereitung 1Z0858069M2AU 19,60 €* Einbau - RS / aperture setting Climatic with Telefeonvorbereitung 1Z0858069M2AU € 19.60 installation *
Schaltwegverkürzung vom Audi S3/TT Shift from the Audi S3/TT
- Schalthebel Audi TT mit 8.5mm Stiftdurchmesser 8J0 711 051 B ~23,00€ Einbau - Audi TT shifter with 8.5mm pin diameter 8J0 711 051 B ~ € 23.00 Installation
- Seilzugarretierung mit 8.5mm Stiftdurchmesser 1K0 711 761 B ~7,00€ Einbau - Seilzugarretierung with 8.5mm pin diameter 1K0 711 761 B ~ € 7.00 Installation
- Sicherungsscheibe N 908 159 03 <1,00€ Einbau - Lock Washer N 908 159 03 <1.00 € Installation
GTI Pedale GTI Pedals
- Kappe für Bremsfusshebel 1K0 721 131 7,67€ Einbau - Cap for the brake foot lever 1K0 721 131 7.67 € Installation
- Kappe für Kupplungshebel 1K0 721 601 7,67€ Einbau - Cap for Clutch Lever 1K0 721 601 7.67 € Installation
- Gasfusshebel mit Elektronikmodul 1K1 721 503 N 79,95€ Einbau - Gasfusshebel with electronics module 1K1 721 503 S 79.95 € Installation
- Gaspedal Automatik/DSG 1K1 723 503 N 62,73€ - Accelerator Automatic / DSG 1K1 723 503 N € 62.73
- Auflage Fussstütze 1K1 864 551 11,69€ Einbau - Reprint footrest 1K1 864 551 11.69 € Installation
Abgasanlage und Auspuffblenden Exhaust system and exhaust tailpipes
- Halter Lamdasonde/AGR Ventil 06F971858K - Holders Lamdasonde / EGR valve 06F971858K
- Auspuffblende 1,9TDI/ 2,0FSI Bestnr.: FDC 610 001 Einbau - Auspuffblende 1.9 TDI / 2.0 FSI Bestnr.: FDC 610 001 Installation
- Auspuffblende 1.4MPI, 1.6MPI . - Auspuffblende 1.4MPi, 1.6MPI. Bestnr.: FDC 610 003 Einbau Bestnr.: FDC 610 003 Installation
- Auspuffblende FDC 609 002 für 2,0 TDI Einbau - Auspuffblende FDC 609 002 for a 2.0 TDI installation
- Auspuffblende FDC 609 004 für 1,6 FSI Einbau - Auspuffblende FDC 609 004 for 1.6 FSI Installation
- Auspuffblende 1,8TFSI Bestnr.: FDC 609 001 Einbau - Auspuffblende 1.8 TFSI Bestnr.: FDC 609 001 Installation
(Die Teilenummern FDC 609 001-2 werden laut Auskunft der Skoda Österreich Seite nicht geschweisst sondern nur verschraubt in Verbindung mit dem serienmässigen Stoßfänger. Siehe unter Skoda Österreich Zubehör . Leider gibt es diese TN noch nicht im Skoda Deutschland Zubehör Katalog (Part numbers 609 001-2 FDC are not welded, according to information from the site but only screwed Skoda Austria, in conjunction with the standard bumper. See under Accessories Skoda Austria. Unfortunately, there are those not yet in TN Skoda Germany Accessories Catalog :x . .
Die "alten" Teilenummern FDC610001-4 / FDC620001 werden weiterhin geschweisst in Verbindung mit dem Skoda Stoßfängerspoiler. The "old" part numbers FDC610001-4 / FDC620001 continue to be welded together with the Skoda Bumper spoiler. Bitte ändere bzw. lösche den Link zur Montage, da dieser nur für die Teilenummer FDC610001-4 gilt - Danke an Juschwien) Please change or delete the link to the assembly, since it applies only to the part number FDC610001-4 - Thanks to Juschwien)
Haltegriffe mit Silikondämpfung Handles with silicone damping
- 1J0 857 607 R B41 Haltegriff, klappbar satinschwarz - 2 Stck 21,50€* - 1J0 857 607 R B41 handle, foldable satin black - 2 pcs € 21.50 *
- 1J0 857 607 S B41 Haltegriff, klappbar, mit Mantelhaken satinschwarz - 2 Stck 21,50€* - 1J0 857 607 S B41 handle, hinged, satin black, with coat hooks - 2 pcs € 21.50 *
- 1J0 857 607 R Y20 Haltegriff, klappbar perlgrau - 1 Stck 15,20€* - 1J0 857 607 R Y20 handle, foldable pearl gray - 1 pcs € 15.20 *
- 1J0 857 607 S Y20 Haltegriff, klappbar, mit Mantelhaken perlgrau - 1 Stck 21,24€* - 1J0 857 607 S Y20 handle, folding, pearly gray, with coat hooks - 1 pcs 21,24 € *
Stoßfänger Bumper
- Rs vorne 1Z0 807 221 E (ohne Einparkhilfe) - Rs front 1Z0 807 221 E () with no parking aid
- Rs hinten 1Z5 807 421 C 262,99€ - Rs Rear 1Z5 807 421 C 262.99 €
- Rs Anschlußblech links 1Z5 813 345 11,07€ - Rs connector plate left 1Z5 813 345 11.07 €
Verkleidungsteile Fairings
- Limo komplette Kofferraumverkleidung links 1Z5 867 427 G 1BS anthrazit 79,92€ - Limo complete trunk lining left 1Z5 867 427 G 1BS charcoal 79.92 €
- Abdeckung anthrazit links 1Z9 868 885 1BS 7,38€ (inkl. MwSt) - Cover the left anthracite 1Z9 868 885 1BS 7,38 € (incl. VAT)
- Abdeckung anthrazit rechts 1Z9 868 886 1BS 7,38€ (inkl. MwSt) - Cover anthracite right 1Z9 868 886 1BS 7,38 € (incl. VAT)
Zierleisten/ Blenden und Abdeckungen Moldings / panels and coverings
- Zierleiste RS 1Z0 835 517 links vorn 27,87€ (inkl. MwSt) - RS Zierleiste 1Z0 835 517 left front 27.87 € (inc VAT)
- Zierleiste RS 1Z0 835 518 rechts vorn 27,87€ (inkl. MwSt) - RS Zierleiste 1Z0 835 518 right front 27.87 € (inc VAT)
- Zierleiste RS 1Z0 835 535 links hinten 27,87€ (inkl. MwSt) - Zierleiste RS 1Z0 835 535 left rear 27.87 € (inc VAT)
- Zierleiste RS 1Z0 835 536 rechts hinten 27,87€ (inkl. MwSt) - RS Zierleiste 1Z0 835 536 right rear 27.87 € (inc VAT)
- KGA600002 Seitenschutzleisten RS (4 Stk) 69,00 € - KGA600002 side moldings RS (4 pcs) 69.00 €
- RS Blende um den Lichtschalter: 1Z1858417E2AU 11,40 € - RS aperture to the light switch: 1Z1858417E2AU € 11.40
- RS Blende rechts neben Lenkrad: 1Z1858415E2AU 7,50 € - RS aperture to the right of the steering wheel: 1Z1858415E2AU € 7.50
- RS Zierleiste über Handschuhfach (mit Telefonvorb.) 1Z1858418G2AU 18,10€ Einbau - RS trim strip above the glove compartment (with Telefonvorb.) 1Z1858418G2AU 18,10 € Installation
- RS-Zierleiste über Handschuhfach (ohne Telefonvorbereitung) 1Z1858418F 2AU 16,96€* - RS-trim strip above the glove (no phone preparation) 1Z1858418F 2AU 16.96 € *
- Lenkradlogo RS 1Z0498003 (nicht mehr erhältlich) 4,80€ - Steering wheel logo RS 1Z0498003 (no longer available) 4.80 €
- Fach Luftdüse mitte 1Z0 820 951 C 3X1 ~60€ - Specialist air nozzle center 1Z0 820 951 C 3X1 ~ 60 €
Lichter und Leuchten Lights and lamps
- Deckenlampe RS (Himmel) vorne Bestell-Nr: 3B0 947 105 C 47H ~30€ - Ceiling Lamp RS (Heaven's Next) Order No: 3B0 947 105 C 47H ~ 30 €
- Superb Innenleuchte Einbau - Superb Interior Installation
- W8 Ambienteleuchte Schiebedach (rot/blau/grün) inkl. Adapter 75,95€ Einbau - W8 Sunroof Light Ambience (red / blue / green) including adapter 75.95 € Installation
- W8 Ambienteleuchte (rot/blau/grün) inkl. Adapter 49,95€ Einbau - W8 ambience lamp (red / blue / green) including adapter € 49.95 Installation
- Adapter W8 Ambienteleuchte 12,95€ Einbau - Adapter W8 light ambience € 12.95 Installation
- Superb Griffbeleuchung 3U0 919 174 rechte Seite (vorn und hinten) 15,51 € Einbau Superb - Griffbeleuchung 3U0 919 174 right side (front and back) 15.51 € Installation
- Superb Griffbeleuchung 3U0 919 173 linke Seite (vorn und hinten) 15,07 € Einbau Superb - Griffbeleuchung 3U0 919 173 left side (front and back) 15.07 € Installation
- RS Rückstrahler hinten links 1Z0 945 105 19,40€ - RS reflectors, rear left 1Z0 945 105 19.40 €
- RS Rückleuchte links 1Z5 945 111 A 74,97€ - RS left tail light 1Z5 945 111 A 74,97 €
Anhängerkupplung - AHK Trailer hitch - AHK
- Stopfen 4,17€ (Netto 3,50€) - Plug € 4.17 (net € 3.50)
Felgen/ Radkappen Rims / Hubcaps
- 18" vom Audi A8 Typ D2, auch als "Gullideckel" bekannt 4D0 601 025 AL Z33 - 18 "from the Audi A8 Type D2, also known as" Gullideckel known 4D0 601 025 AL Z33
- Radkappen 15" 1Z0 601 147 A 28,99€/Stück - Hubcaps 15 "1Z0 601 147 A 28,99 € / Unit
Zubehör und Teile Accessories and Parts
- Link Teilenummern Stahlgruber (AT) - Link Part Numbers Stahlgruber (AT)
Sonstiges und Links/ Downloads Miscellaneous and Links / Downloads
- Schriftart Octavia Sulphur - Font Octavia Sulfur
Woah - big list!
Edited by willskoda
Someone elses car but here are the front two pegs from a distance:
UPDATE - found the part numbers:
WHT 000 898 is the peg (actually called a 'ball joint' in ETKA)
For info, rubber socket / grommet on the engine cover that it goes into is -036 129 689 B (called a 'buffer')
Edited by muckipup
Anybody got the number for passenger side driveshaft for Octavia II 1.9tdi DSG??
Any idea what the part number will be for front brake pads for my Octavia 1.6CR "S"?
Regards Kyle
anybody require any part numbers pm me your reg and i'll sort you one as soon as i get round to it :thumbup:
Does anyone know what is the year 2010 Octavia factory installation of Webasto TeleStart T90 package spare part number?
Here's my contribution to this treath.
Safety bolt set - YCFA071004
Hope It's Useful.
Edited by Quico
  • 4 weeks later...
Anyone got the part numbers for the silver colour coded centre consol plastics from the FL Vrs? I'm referring to the ash tray cover and the gear gator surround.
Can anyone tell me the part no for 2.0 CR oil filter is it the same number as the 2.0 PD ?
what are the costs?
Part numbers for a FL 2010 vRS
Tow Eye Cover 1Z0853665F9B9 £5.09
Radiator Bracket 1Z0121367B £3.45
Nearside Headlamp Panel Stay 1Z0806083B £3.90
Nearside Upper Rail 1Z0810365A £12.51
Nearside Headlamp Mounting 1Z0805071A £14.11
Octavia 1.9 TDi hatch 2006.
Rear Discs - 1K0615601AB - £28.66 + vat each
Rear Pads - 1K0698451J - £32.50 + vat
Flamenco Red Metallic touch up pencil and laquer pencil (set) - HFB380078 - £5.96 + vat (£7)
1z2998001 Aero wiper set £28.37 + vat
7e0955425 Rear wiper blade (hatch) £5.72 + vat
1z06011737zs wheel bolt caps £0.61 + vat each
8d0601173e7zs locking wheel bolt caps £0.73 + vat each
Storage box fitting guide is broken. Quite like the idea of fitting one under the drivers seat. Does this guide still exist?
Sure it does, but I've not got the time to tidy this thread up at the moment.
If one of the Mods want's to do this and clear up the posts, it would be much appreciated.
Hello , I need a number for the dryer element.
I have found something but is not for my car.My car has an element from cotton whit balls inside.I do not need 1k0 298 403 A....
My Octi II is from 2005, MY06
Edited by gabi2004
Mudflaps, that will fit the vRS even though all dealers seem to tell people otherwise :D
Should be around �20 a pair.
Boot hook for the hatch. There should be one on the left, but another can be popped in on the other side.
DMA 610 007, about �6.
Steve
Steve, bought these for the fL vrs and the fronts fit, the rears don't ( not yet anyway....where there's a will.......) ;)
