'Water Ingress Problem'........SOLVED!
Bump for the post 19th may 2017. For @mitchell76
Edited by toot
  • Replies 150
  • Views 107.6k
  • Bad news.. It's trickling down the bulk head. First thing to do open bonnet and remove the bonnet sealing strip and pull the trim under the windscreen off. This will expose brake servo, battery and w
  • Well I got started on re-sealing and checking the whole car today. Didn't manage to pull the carpet up as it took me 3 and a half bloody hours JUST to seal the pollen filter area and do the drain plu
  • Drains are under the battery plate and under the brake servo.   Water ingress, if it has happened will be under the carpet in the passenger side.  It can hold gallons before you see it above the car
