engine transplant
think ive put this in the right place
im thinking of doing a engine drop into the octy its currently a 1.6 but i was thinking more like a 1.8t +extra bhp to make a mean track car
so if anyone has advise on how to do this including links, costs, tricks of the trade and anything i will need to know
thanks hopefully i can get this project off the ground soon
shreads
1.8t bam engine + wiring away you go
+ diff + brakes :thumbup: :thumbup: :thumbup: :thumbup:
you make it sound so easy
i was thinking today do i need to change the whole rear axle or can discs be added to existing one as ive seen mounting hole
also how much different is the rear suspension on a vrs
cheers
shreads
cheers
shreads
Rear Axle? The Octy is FWD (unless you have a 4x4 or Scout)
To be honest I suspect you'd be far better off swapping the car than trying to change the engine...
ok il re phrase that the rear beam on the back does it need changing
im not doing it because its easy or cheap but because i love cars and i want sumthin i can be proud of
This is potentially me being dumb, but doesn't the Octy have independent rear suspension, so no beam across the back?
no it has a rear beam...
engine transplant wouldnt be to hard if you can source and engine with all the bits and the wiring loom with it
so you need a bam engine with engine mounts
the full wiring harness and ecu
gearbox and drive shafts
possibly front hubs not sure
have fun
hmm interesting how do i go about setting up independent suspension then as the 1.6 has a beam
would a mk 2 engine fit on the same mounts?
cheers shreads
All the MK1 Octys have a rear beam, except the 4x4 which was the only model with independant rear suspension due to the driveshafts.
ok confused now can some check there vrs in the morning and see how the rear suspension is fitted
but mainly back to the original question will rear discs go on the 1.6 rear beam or does it need switchin
cheers
shreads
No need to check, I have swapped it.
It is a rear beam not IRS :thumbup:
is there much difference in the beam and mountings
cheers
shreads
I doubt there is any real difference. If you want to create a 1.8t track car, if you're leaving it 2wd, you don't need to touch the rear of the car. :)
wat about rear discs tho surly i need to uprate the stopping ability with more power in the car
shreads
You have drums at the moment do you? Oh right.... Hmmmm
Would imagine a complete beam from a mk1 vRS will fit on. :thumbup: If its anything to compare, the fabia rear beams are all the same where discs fitted.
I've gotta ask..
Wheres the name Shreads & Shreadings come from mate?
Rob :D
cheers jason im gona crawl under my neighbours vrs when it gets dark with a torch an see wat it looks like :giggle:
the name comes from my work as my name is nick readings
one day they were rhyming my name with things and they came up with **** shreadings it just sorta stuck then shortend to shreads, shreaddog or shreaderbob
my new colleges call me fresh so it didnt get any better
shreads
come on surely i you are going for an engine drop you can do better than a 1.8T.
if your going fro a 1.8T it would have to be the S3/Cupra R k04 engine as its stronger and more tunable.
What about the likes of jabbasport or backdraft motorsport, id be on the phone to them seeing what they think would fit in there and what they would do if they had the chance.
Edited by vRSy
as above ive looked at the BAM 1.8T 225bhp engine
is it possible to add a bigger turbo
shreads
Please don't take this the wrong way, but due to the questions you are asking i'm going to take a wild stab in the dark here and say i really don't think you have the required talent to pull this conversion off, there really is a hell of a lot more to it than what has been mentioned, have you ever seen a bam/apx wiring loom? If you haven't i could show you one, i guarentee it will not be easy to splice into your current wiring.
Judging what you have asked allready i would doubt you could tell a spanner from a screwdriver ;)
wiring is easy as im an electrical engineer and ive worked on some complex jobs so im sure il get the hang of it
as far as cars go its a learning curve this is my first ever engine conversion
so no im not fully vehicle trained or have i worked on a skoda before now
so by asking the stupid questions im getting the stupid answers and there for getting it right the first time round
cheers
shreads
spanner does nuts and bolts (also good for slackening the belt tensioner)
screwdriver does screw
In that case it will be easy for you, the wiring is the hardest bit of the job, i would forget about the little things for now and concentrate on getting the engine in and running right, from there you should start sorting the brakes ect, glad you took my original post in good humor too :rofl:
im just asking questions for now really
and dont worry about it ive had to work with the the extremely rich and BAE system both of which are massive bunch of ****s (sorry if anyone works for them ive just had bad experience with them) and i can take the comments and give a monumental amount of sarcasm back when required
and everyone on briskoda is very nice and doesnt mean any upsets
shreads
Got your Nick name a different way to me then... but.. We share the same nick name (hence my interest).
I was Shread all through school........... My surname IS Shread, lol ;)
ok kk its a good nickname most of the time i get called neadingzzzzzzz which is the first letter of first name and added onto my last name the guys i work with are geniuses they need to be given a gold star on there chart for that one
