Automatic boot - Completed
Thanks for the video, will have to see if I can get mine working!
Sent from my iPad using Tapatalk HD
  • Replies 364
  • Views 117.4k
  • MartinKaer
    MartinKaer
    I have just finished my automatic boot project Here's a guide: Works on Skoda Octavia Combi FL: For starters, make sure that your tailgate "pops" when you hold the middle button on your rem
  • Right. Thanks to J306TD for the upload offer but as the email size was too big I couldn't even email it. My son has had to upload it for me.     But here it is.
  • HOT TIP: Just tried the Blue (medium duty) springs, unfortunately not enough grunt to open the boot all the way :( so back on with the red ones, I will probably use the blue ones on the work horse.
Your welcome Craig. I don't mind helping out a fellow member. I think this is a great mod. Is it harder now to shut the boot?
Sent from my Galaxy S5
Yes I have to admit I have to use both hands and it is a bit of a positive close rather than just let go like it used to be. But i don't mind because I like to see the look on peoples faces when I press the button when it is raining and it just pops up while they are still fumbling trying to get into the boot of their car  :clap: .
That's better then. As mine currently drops from a certain height. If you don't mind me asking how much did it cost in total?
 £40 See post #216 & #243
Has anyone used the struts for a non VRS? I'm assuming the spoiler adds a fair bit more weight to the boot! Making it harder to close!?
I need to replace mine as they are a bit weak! Tempted to get these regardless whether the springs work or not!
I just fitted mine a week ago - the renault gas struts and the red springs... Worked fine a couple of days but now it's only every 2. time it pops open! And the boot was hard to close, but now it's a bit more easy... So I don't know if it's because the struts had to be used a couple of times to settle in or if it's the temp. outside - in Denmark its around 10 degrees celcius. The springs also seems a bit less "springy"?! Don't know the correct word for it in English ;) But when it's doesn't open I just have to push very slightly up with one finger, then it pops. So it's not much energy it needs...
Hope it helps!
Just to reiterate, these springs are called die springs and are NOT really intended for use the way we are using them for! Their designed usage is a slight rebound/suspension, thousands of times, not a large compression, this is more than likely why they're not working so well after more than a few times as they're not really meant to be used this way. Ambient temperature does play a big part of how well they work by the look of things.
Bummer.
I'm quite sure it will work, the gas springs are really strong and they really need little help from the extra springs.
You might need a stronger and longer 'pop' from the springs due to the added weight, so perhaps a longer spring is wise. There is about 40mm space for the compressed spring on these Laguna gas springs.
So these might work?
http://www.bearingboys.co.uk/R16x64_Heavy_Load_Die_Spring-31136-p
I can't guarantee anything ofcourse, you'll have to try.
Can someone please explain how and WHERE on their site I can register for an account ? Since I cannot find ...
Progress through the checkout and you register there.
Yup, do a search at the top of this page just in this topic for the word 'Yellow' to find out how successful they weren't.
Edited by blackspaven
Just had a quick read, and no one has actually bought the R16 64 yellow springs, as they tended to go for the shorter ones due to having more "strength"!
Seeing as the Red R16 64 are the ones to go for, I might be tempted with a set of each. But first I need to get my boot auto delatching from the keyfob. Anyway near Trafford centre with vagcom or is this a dealer visit?
Has anyone had any problems after installing the Laguna struts on the hatchback?
Edited by frobe2002
No problems for me. They are still working great. Boot pops every time too, I just hope it hold up during the cold weather.
Mine are still waiting to be fitted...
But have several version of springs...those red ones...and some that I have ordered as custom-made locally, so will test them all and see results....
From what year are we taking here, I'd love for my boot to pop up just from pressing the fob?!
Sorry everyone I am now confused.........
Are the red die springs (from bearing boys) the correct ones for a pd estate? Can someone who knows post the exact spring id number....Please?
This is a fantastic mod and the originator needs to be congratulated.
It particularly helps me as my boot lid doesn't always open enough to be free of the boot catch as my boot release switch doesn't work.
Thanks etc
Tom
They'll all fail if it's just a spring put on the piston. THey're not designed for that job. Tried many, many types, cold weather kills them all.
  • 3 months later...
hello im new here. So i ordered red ones have them fitted but boot dont open fully :( SAD
The temperature is to low or/and you need new dampers.
Don't know why I bother, people just don't listen. :wonder:
I replaced my dampers and added the red springs. Mine are still working fine even in the cold weather.
Sorry, yes, if you fit new or other dampers it should work fine, but what I meant was just adding springs won't cut the mustard.
Mind you, when it's colder, mine only pop up a little bit, but that's fine for me as I don't get dirty hands on the handle anymore. :)
  • 2 months later...
Done this mod to my octavia but the trunk just pops 15-20 cm, it doesn't have enough power to push it all the way up.
I've got the blue springs, should I get new red ones or should I change the shocks?
The car has done almost 80000km
