Am I Being Too Fussy About My Vrs
Have had my vRS for nearly 11 months now. Only done 6000 miles, but when I think about it I have had it back to the dealer maybe 6 times. Alot less then my Alfa, but it makes me wonder about the long term reliability of this car. Below are the list of issues I have had. Was wondering how this compares to other peoples experiences. My friends have told me I am just way too picky. What you reckon ?
Currently
- on roughish road surfaces loud vibration from back of car. Sounds like rear centre brake light surround is vibrating off window. Also, plastic door grip on drivers door still flexing when you open door and central locking pin noisy. Dealer taking a look next Wed.
Last month
- top of resistor on fuel gauge sensor cracked causing fuel gauge to read zero on full tank. Dealer broke seal under drivers seat and replaced sensor.
May
- tracking out, despite hitting no potholes
- right rear brakelight bulb went
March
- boot sensor light needed adjusting as boot light would go out straight away.
- light in glove compartment would stay on when closed. So sensor needed adjusting also.
- padding in base of drivers seat had to be replaced as it started to tear along the side of the seat, resulting in the metal frame pushing against the leather.
Feb
- drivers door grip started flexing again when you open door. Dealer refitted grip.
- Centre armrest noisy. Dealer inserted foam, but sometimes armrest still rattles on rough roads.
Nov.
- rattle in drivers door. Caused by cable vibrating against door lock. Dealer greased cable and inserted foam into door. But door grip now flexes when you open door. Dealer tightened it up.
OK, 20 months, 97,000 miles the odd one or 2 of which have been on track (about 8000 at the last count).
Mechanical problems to date:
5 coil pack failures
Water temp sender unit went AWOL
2 near side front wheel bearings replaced (that'll be the track use then)
Front, inside wishbone bushes cracked
And that's it :D
Hi,
Had mine almost a year - done 12,500 miles.
Only problem I've had is a brake light going (which I don't really see as a problem, nothing lasts for ever).
It's been back for a recall for the rear-wiper.
Not sure what you mean about the door grip flexing, will have a look next time I use the car.
On the whole I've had no problems at all, I usually have the CD player on so probably wouldn't hear any rattles though.
Sound like you have been a bit unlucky !
JAne
PS What armrest ????
:eek: :confused:
I don't think there's anything wrong with your see-through-solid-materials sensor, though... :D
Well - I'm probably the only one to have needed a spanking new turbo... Thats my only major problem with my car, but at least it gave me the chance to see what a 1.9 SDI would drive like, and it made me glad I have the TDI. :D
...........May
I've got an ongoing issue with a steering pull so.... Did the steering start to pull? How bad was it? What did they do? was the problem fully resolved?
No I don't think you are being fussy, I think these items can be very annoying, but there does seem to be inconsistency in how often cars suffer these problems. Is this a function of manufacturing quality control?
Had two rear brake light bulbs go, but they are "consumables".
Temperature gauge sender went as did Jon's, but that's fixed under warranty.
How did you know the light stayed on when the glovebox is closed? All a bit Shroedinger's Cat... :D
Rob.
According to Skoda the steering pull is a characteristic on all their Octavias. This is what the dealer told me and he showed me a letter to that effect. What happens on my vRS is that the car will start to drift to the left after 3-4 seconds. I have driven 2 other Octavias that have the same 'feature' and I know an Octavia and a Bora owner in work who have this as well.
What was interesting is that when I brought it to one Tyre 'specialist' they told me the tracking was out. The car was 2 days old at this stage and I didn't want to drive 50 miles back to the dealer. I then brought it to another 'specialist' who told me the tracking was fine, but the camber was out. I subsequently found out the settings both 'specialist' were using to check wheel alignment were way off. One guy was using the settings off an Octavia 1.9TDi, the other a 1.6 petrol. None of them had the program for vRS. When I brought it to my dealer he used a local tyre specialist who actually had a Skoda tech. manual which he used to reference what reading he was getting. Turns out my wheel alignment was perfect. And the camber apparenly is non adjustable. So I have got used to the slight 'pull' to the left now. Don't even notice it anymore.
It was actually a passenger that noticed it. Apparently driving at night the light was sort of shining out through a vent in the passenger footwell.
Personally I count myself lucky as the problems I have had are cosmetic. Every car except the Skoda has been a nightmare. My last was an Alfa 156. Bought from new. 0 miles. Showroom car. Turns out it must have fallen off a lorry literally as another Alfa dealer noticed filler on the roof, and the boot and drivers door weren't alligned properly. Plus I must have been back a dozen times with every electrical problem in the book. Italian cars are a pile of sh*te.
There are a few people in here who will happily s1ag off FIAT... Me included.
Yeah...I had 'em for years. Since '96 I've had a
Punto SX
Punto HGT 1.8
Bravo 1.4
Bravo 1.6 GT
Alfa 147 1.6
Alfa 156
The Alfa's gave me the most trouble would you believe.
I do believe. I have no trouble with that. Dad had a company Fiat TD runabout, and the engine ate itself spectaclarly & totally at 30000 miles (and at 80mph too!) Needed a 100% rebuild. :mad:
I see Fiat advertising their Stilo's in Exeter for stupid prices, and I just think, "yeah! RIGHT!" Will last about 6 months if you're lucky.
Punto SX
Punto HGT 1.8
Bravo 1.4
Bravo 1.6 GT
Alfa 147 1.6
Alfa 156
At which point did you realise "Italian cars are a pile of sh*te." ?! :D
Flanno - had same problem with the glove compartment light - dealer sorted it last weekend at its service. Must admit I wasn't that bothered about it - as you say a cosmetic (probably contact) issue so easily sorted and doesn't really effect use of the car. :)
... in defence of (old) Alfas our family had 4 Suds and a Sprint one after the other and had almost no problems in that time. Admit that we did look after them and get them properly waxoyled & serviced etc but 3 of the Suds & the Sprint were when we lived in Kenya and they survived the cr*p roads quite happily and the seaside around Mombasa. :p
Will always love Alfas and am currently negotiating buying a concours condition Sud so i can enjoy the rasp of the engine again. Mug? maybe - but if you accept their faults and ensure you deal with the weaknesses before they arrive they are brilliant fun. Also, the Sud was is a style breaker in that it popularised the hatchback and was a seriosuly radical style for the time. :cheers:
Originally posted by KentStu in this post
[bWill always love Alfas and am currently negotiating buying a concours condition Sud so i can enjoy the rasp of the engine again. Mug? maybe - but if you accept their faults and ensure you deal with the weaknesses before they arrive they are brilliant fun. Also, the Sud was is a style breaker in that it popularised the hatchback and was a seriosuly radical style for the time. :cheers: [/b]
As someone brought up with Flat Four Suds I can also appreciate why they lasted much better in Kenya's weather. Superb cars but always remember the look of horror on my Dad's face when he fancied trading in our year old 1.5 Super for a used Audi. The depreciation worked out at 70% in one year.
I presume that you are buying a Ti ? I have a number of Sud articles if you want me to dig them out ?
Ah yes! Fiat's (lack of) build quality goes back a long way.
I still have fond memories of my 1975 Fiat 124 Sport. It had a lovely free-revving 1800 twin cam engine. The progressive twin-choke carb was great - it felt a bit like a turbo spooling up as the second barrel opened up.
I could cope with the clouds of rust particles it left in its wake, but when bits started falling off I decided it had to go :(
Fabpreza - actually not a Ti - a late model Green Cloverleaf (has the 1.5 veloce engine). My mum had one of these in Britain and it was great fun until my younger brother wrote it off. :rolleyes:
I had a 1.5 Ti Green Cloverleaf
My earlier cars wher all japonese, 3 Mazda's and 1 Honda. The Honda had more problems then my Mazda's in general.
My first european car is my car at present and it's a Skoda Octavia vRS -02, been driving around with a huge grin on my face for about 15 months now, and I still haven't gone to my dealer.
I'm very happy with the vRS and hope to be so for as long as I want/need the car.
Cheers,
FD
FD
Italian cars and Jap cars share one common trait (or at least the moderately sporty ones do)...they have cracking engines! That old Fiat twin cam was a cracking motor and sounds so sweet getting a good caning , as do some of the more high revving japanese twin cams (Integra type R , for instance) Actually , thinking about it they share another trait....the bodies will go crusty and need to be swept off the garage floor long before the engines and gearboxes die!
I agree wholeheartedly, however, I think we can slag them off more now than years ago.
I owned an F plate Panda, had done 100,000, I owned it for 3 years, only thing ever went was the tyres, it left me with 150,000 miles and is still going somewhere locally, and I sold it over 5 years ago !!!
The rest of them are of course, sh*te.
Same here, FD. Honda and Subaru (all of them rock-solid) for me before taking the plunge and buying European.
I'm afraid you're right there, Duncan. I still get to see one of my earlier Hondas on a regular basis - it's a 1990 1.6i, a normal 3-door hatch with the CRX engine - as it's now driven by my sister-in-law. My in-laws haven't really been taking care of it, using it as a town runabout, and it is starting to show. The paint is flaking, the floorpan is suffering - but the engine is still very throaty and powerful!
Should have put in a garage three or four years ago, either that or had its major components powdercoated to stop the rot. Now it's too late...
Sad ending to a great car that has given me some wonderful memories.
  • 4 weeks later...
I thought this Thread was supposed to be about Octavia vRS reliability issues....! Enough about Pandas & Jap Crap etc.! I've only had mine 10 weeks (& 3.5k Miles) and so far no problems, touch wood! Maybe the sidetrack issues on other cars is an indication of vRS reliability and build quality??!! Anyway, I've had one of those Ear To Ear smiles (as mentioned here so often) since I purchaced, stone chips being the main bogie....
