Warning: Fabia Door Leaks
Never noticed any to be honest once the door cards are clipped back on. Just make sure you've got new clips before you start!!
Had new clips ... Didn't realise they were MK2 Fabia ones though ... Thanks Skoda Dealer...
Anyone got an EBay link for the original?
JRJG
  • Replies 846
  • Views 266.1k
  • Cracking video by Colin Wilson on this subject thats worth posting imho.
  • Four suggested threads have now been added to The Extremely Useful Fabia 1 thread.   Hopefully there's no reference to insulation tape made in them - or any more in this thread either! :peek:
  • Got mine fixed...well, I've found the problem. Had a wet floor in front drivers side and after sealing all doors (one of them 2-3 times) I've found the problem.   Here's how: Ripped out in
Found some on EBay, £9 +£4 p&p for 10 .... [emoji22]
I think I'll head to the parts place I use before I pay that.
JRJG
Yeah, probably a good idea lol.
I've started a new topic having discovered another source of water ingress leading to damp carpets - one which is not connected with the faulty door carrier construction afflicting Mark 1 Fabias - please check it out here: Damp carpets - a new source of the problem - Leakage around door seal
I know I'm 5 years behind the times, but I just love the way Shbi comes from out of nowhere and posts half a dozen possible solutions, including one which sounds like he reduced the car to a bare shell, yet he doesn't know how to start a new topic. Ha ha ha, no way was this mystery man from Skoda HQ, no no no.
I don't understand - who or what is "Shbi"? Why are you quoting my posting?
Confused me too.
OK - I get it now - and have replied extensively on the other topic a long time ago.
Makes you wonder why williebob decided to post here!
Errrr, because I've just purchased a Fabia! And seeing as how I'd read this entire topic, not to mention the entire topics that are linked to here within, I thought I might pause mid(ish)thread and post a reply That ok boss?
Good effort reading the entire post :thumbup:
JRJG
The simplest answer is usually the correct answer. And the simplest answer in this thread is to seal the gap across the bottom of all 4 door windows - on the outside, obviously, with some insulating tape.
... except in this case the so-called "simple answer" is NOT the correct answer! Ignore williebob everyone and do a proper job - if you want to open the windows!
But you didn't start by pursuing the simple answer, so you wouldn't know. When this solution was first suggested you dismissed it out of hand. Instead you continued banging on about removing door cards and using some crappy sealant, people have wasted precious hours because of you and your I know best attitude. And I knew you wouldn't be able to resist replying to most post now, just like you couldn't resist replying to my initial post in this topic, you're a typical know-it-all.
  • Sponsor
:D
Why not just put the whole car inside a giant plastic bag?
:D
Oh no, now you will get called the (new) know-it-all!
Strange that this pleasant topic has turned grumpy?
  • Sponsor
I think williebob turned it strange when (#756) he started slagging off someone who hasn't even posted in this thread. :wonder:
So, after 26 pages of ideas and discussion, has the problem been resolved?
Oh my goodness why didn't I think of this idea....
I could have saved myself the time of reading the thread in its entirety and also the exceedingly long 1 hour that it took me to seal the rear door carriers with that awfully unusefull plumbers gold sealant that PERFECTLY FIXED THE PROBLEM once and for good hahaha.
Now where did I leave that "black" insulation tape incase my FIXED leaky doors ever decide to leak again? Lucky my car is black aswell.....
Yes, Seal all four door seals between the regulator and the door with plumbers gold. sorted.
What hutchy said, sorted. Use the earlier quoted "crappy" sealant and fix your winter condensation problems for good.
Moderators can't we lock this thread once and for all?
Peace, Chris
Agreed Chris. Can we get a post together and lock it that simply says
- got a leak, steamed up windows, or wet carpets? 9 times out of ten it's the door carriers, which you can verify by seeing if there is water on top of your door seal after it rains, seal them with sealant using these steps 1-X. If on the off chance this doesn't fix it, check your scuttle is clear. If it is still not fixed, read all of this insanely long thread whic contains loads of the less common causes such as washer tubes, leaks behind dashboard etc.
Then pin it!
Edited by wiredsoftware
In fact, if I can get confirmation from a mod that they will pin it and lock it if I write it, I'm happy to create an extensive post that pulls together the above, full steps (with pics if anyone has them) along with links to every other cause documented in this post and elsewhere.
Just leave the insulation tape out of it...... ;-)
