FMIC Kit - Group Buy - £200 Delivered
We need 15 names :)
  • Replies 482
  • Views 49.1k
  • It shouldn't really make a massive diff will it?
  • If you go on there ebay listing it has a landline number to call. It took a few goes as they are busy but got through in the end!
  • joe_vrs_tdi
    joe_vrs_tdi
    fitted mine on the weekend and i took some photos http://www.briskoda.net/forums/topic/239134-tx-autosport-intercooler-work-now-complete/ take a look. some have had no issues but i had to make some b
This should really be a FMIC discussion and a new thread made for the group buy I think its got a bit out of hand now! But I will be putting better pics of my intercooler install up at the weekend hopefully cause ive got to have the bumper back off to fix a small leak on the map port I made.
I have the solution to all your intercooler piping problems.......
But I don't think the bonnet will shut....
Think about the lag... :wonder:
Will possibly fail MOT as driver's view is obstructed.
lol
This is how mine would look after trying to attempt the Ebay kit.
Just got my forge map pipe! Very impressed with it and would recommend to anybody who decides to put their own kit together only £37 delivered comes with adapters for all different sized sensors.
and some mikalor clamps because they are 1000000% better than jubilee clips
Hi people
Not been on here in while as fabia off road for winter but this intercooler I've got money waiting...answer few question and Ill take one if I can?
Do I need to buy anything or is it all in the kit?
Any cutting required of car body or parts?
Does it come with mounts to bolt to the crash bar?
Is this simply off with the old and fit everything of this one?
Many Thanks Euan
Answers in bold:
Hi people
Everything you need is in the kit
You will quite likely need to trim the bumper a little bit and you need to do some modifications to 1 or 2 existing intercooler pipes I believe. Nothing big but does mean going back to original will mean you need to replace the pipes you modify if that bothers you.
Comes with all the bits to mount it but make sure you have some sharp drill bits for drilling through the crash bar as its rather hard!
Pretty much little bit of cutting on the pipes as mentioned and maybe a little trim of the bumper but pretty much off with the old and on with the new
Many Thanks Euan
Everything is in the kit that you need however as its for an ibiza you will have to have a afternoon set aside to fit it but once fitted correctly very little modification to your car is needed :)
Thanks lads
What do you have to do the the pipes on the car to make this fit? Also have they changed the piping to 2"?
Euan
Above : You see the pipe on the left that goes into the top of the intercooler I believe the metal part of this needs cutting off so you are left with a normal rubber hose you can push the map connector pipe into as shown below
This bottom pipe that runs next to the sump looks to have been cut down to remove the push clip fitting to allow the pipe to be pushed over. On mine i heated the pipe up and pushed it over the larger push clip connection so I didnt have to cut the pipe but not sure if possible on this kit?
Tiz is that lower pipe that the red hose is connected to made from rubber? or is it metal?
When I fit my kit I am going to mount the IC and then take my time with the pipe work and get any pipe work that can be hard mounted welded with brackets.
The one below the crank pulley that runs along the side of the sump? Its an alloy pipe
When I did mine it looks like there are some decent spots to bolt a bracket or 2 to. I am going to weld brackets on mine at the weekend as its just temp cable tied up at the moment while testing but all my pipework is going to be black with blue hoses. I will try and get some pictures of where it could bolt to the engine I dont think there would be any value in bolting it to the plastic under the rad like in your pic would there as its not very strong?
Edited by Tiz.H
Thats sound then.
Is that mounted as standard in any way or is it just hanging from the above joint?
its just hanging hence people complain about them a lot when they pop off under high boost they just flap around everywhere.
I will have a look to see if that can have some form of bracket welded to it also then, cheers Tiz.
Are you out of the group buy for this kit? I need update the names.
Might be a pain getting a bracket welded on there. I would just brace the long pipe going across the front of the sump. Ive already covered 500 miles with my temp cable tie effort and had no problems at all. Plus its an alloy so harder to get somebody to do a decent weld on it rather than the stainless pipe which is easy to weld.
I am out unfortunately but only because I had these bits laying about in the end
In Lee's paint diagram, what is that black bar he has illustrated the welded brackets going to? material also?
With only 9 names it looks like we may be struggling with the group buy, anyone else fancy this group buy?
1. HuxleyVRS - Black Piping
2. Wilsy7 - Black Piping
3. vrs'burks - Black Piping
4. Crocket - Blue Piping
5. kraig - Black Piping
6. Eskimo - Black Piping
7. lemadrell - Black Piping
8. tagrap2003-black piping
9. Dav-Vrs - red piping
10.
11.
12.
13.
14.
15.
