Injector needs replacing probably! How much am i looking at?
Wife just dropped car off this morning at VW Rescue. Lastnight it was fine apart from the juddering...
Then this morning, the wife could not even get out of second gear the juddering, EML and ASR were all kicking off.
Before my spinchter tightens and i get a quote. How much do you reckon i should be paying to get either the wiring loom or a new injector replaced?
Really need to prepare myself for the cost as my research concludes the cost of replacing an injector can be anywhere from £500-£1000...
If its in the £1000 mark, the car is getting shifted.
Edited by Beancounter1980
Where abouts in the midlands are you?
The car is at VW Rescue. Heard very good things about these guys. I dont trust the Main Dealers...
Could Morrisons Fuel be the cause? I started filling the car only on this stuff for around 5 months.
Yep. Morrisons' fuel is (or used to be) not compatible with VAG engines. BSEN590 fuel (standard forecourt diesel) is allowed to contain up to 7% biodiesel (from memory) but Morrisons' used to contain more. Compare this with your handbook which probably says not to use biodiesel at all.....
Seriously? FFS...what about Sainsburys? The car has been running rough ever since i started putting that **** in my car. I only used to fill up for convenience.
Lesson learned, I'm sticking to Shell...
As far as I'm aware, Morrisons are the only supermarket who don't comply. I've used Tesco in my Fabia (and my Leon before that) with no problems, although I'm currently back on Shell as I think Tesco's winter blend diesel knocks my economy (Fuelly shows a pretty big, consistent decrease after November compared to what I was getting in it between March-November when I first bought it, whereas my last tank with Shell was pretty good and this one's looking pretty good too).
Have a look on the pumps to see if they're standards marked, if they're BSEN590 then you should be fine, if they're not marked then it's a "custom" blend which isn't approved by British Standards etc.
I'm not sure, but I have 4 injectors there if you're after any
And sorry to hijack i've been getting my fuel from asda recently anyone know if this is any good? i've been getting about 27mpg :( and sounds a bit rough also? onl go there cause its cheap!
faulty wiring loom cost me around 140 quid - hope in your case its just the loom as the garage said its common on these engines
I think morrisons is up to 12% afaik
Morrisons' diesel is BS EN 590 but contains the maximum 7% biodiesel. It says this on the pump. Many brands of diesel seem to contain about 2.5%.
Morrisons' B30 diesel is not of course BS EN 590 and is not compatible with many VAG engines.
ps
Tesco is 5%
It is entirely possible that I'm wrong. Personally I haven't been there for years after first reading that their fuel was out of spec and they'd removed the BSEN590 branding from their pumps. No point saving 50p/tank over Shell if it's going to lead to big bills later on.
From what you say, it sounds like either way their fuel does still contain more biodiesel than their competitors, so could still be the problem...
Injector cost from a good VW Specialist is around £250 - £300.
I whacked 50 quid of asda fuel in my car and got 330 miles :thumbdown::thumbdown:
I steer clear of Morrisons' diesel. When most of the PD injectors were designed, the limit was 5%, so I wouldn't want to use diesel with more than that. On some Morrisons' forecourts it is easy to put B30 in by mistake. At night, they use orange lighting and the B30 pumps have orange writing on them.
Hey up guys, its the wiring loom....
Slightly out of pocket. But piece of mind is pricelss.
Great customer service and also wife got a polo to pootle around in and keep her mobile.
Cheers VW Rescue....
Indeed. I probably haven't actually used it since my non-PD Golf tbh, although that was mainly just because it wasn't convenient. Whereas since I found out about the change, I started actively avoiding it.
Is Sainsbury's ok then? 142p a litre at my local shell. 11p more than petrol!
Used to work at a Sainsburies petrol station.
We used to have deliverys come in a BP tanker, which then serviced the BP a mile down the road!
Have used sainsburys diesel consistently in two modified PD engined cars (including my current Fabia) with no problems
Aren't they next to P-torque? And they recommend each either other I believe.
Edited by trebormint
Since 1st April 2010 BS EN 590 must contain a minimum of 3.5% (used to be 2.5%)
Mind if I ask how much?
Hook up to Vagcom - £40.00
Wire loom Jobby - £140.00
On the same estate in Wombourne - P-Torque do the tuning and VW Rescue do the hard work (sorry Will)
Both very good - had mine done there twice and can't say enough good things. Glad to see they have a nice little polo to run around in though as I kept getting that cr*ppy R reg golf (still better than nothing)
