Given the choice......
43 members have voted
  1. 1. Given the choice (i.e. funds are limited to only one) which would you have....
Please sign in or register to vote in this poll.
As the poll says. ;)
Although I should mention that Maxidot would be a retro-fit.
Thanks guys :)
Edited by RainbowFore
Alex, if you're after VCDS, have a look at the link I posted in the group buy a few weeks ago. :thumbup:
Maxidot, easy.
Get that fitted and you'll be able to do most of what you want anyway probably. If you want a scan done or something else changed there are plenty of friendly members who'll help out.
Given a 50/50 choice, I'd go for VCDS. It's a tough one as they're both useful, with VCDS giving you the benefit of checking the car for faults and running logging if desired.
I have voted for maxidot as I am on the prowl for one as we speak, but VCDS is on the wishlist. Although thinking about it, if you get the diagnostic cable it could easily pay for itself by doing little favours for members?? :wonder:
VCDS can be used on multiple different cars and taken with you when you change and is therefore a better long term investment.
Buy VCDS now and save up for maxidot as a future mod.
Maxidot new is a £120 no brainer, but not a £650 retrofit! also as above, you can do other cars for a beer with vcds :yes:
VCDS has been invaluable, and as said you can take it between cars. Also helpful if you have friends and relatives with VAG motors. Plus with the HEX+CAN lead it covers a huge range of vehicles.
When I've had a few issues at the roadside it's been really helpful to work out what's happened. In one case with one of the Fabias, it was fairly obvious from the error code that it was a boost hose clip, which I managed to get sorted at the side of the road. Without VCDS that probably wouldn't have been possible, or practical - especially as it happened at night :)
Yes, everyone else is right of course! I'm flip-flopping!
I've gone VCDS on the basis that it does more than Maxidot can even if the maxidot functions are a bit more accessible (i.e. you don't have to boot up the laptopn etc.)
I've got both but managed (and could manage) quite well without VCDS.
Just to confirm, maxidot can be had for just over 300 quid fitted and coded........but I get your point! ;)
I've gone for maxidot. I prefer my car to have the options easily available and I'm sure VCDS would be used once in a blue moon in reality. Your dealer can do any coding you need at service time or quite cheaply (and in my experience foc if you're a regular) when required.
As said before great if ordered from new, but not retrofit,as the OP is doing , by the way Lee ,Shark wanted 650, new clocks etc, also the dealers cannot do all coding just common things, and want £90 just to scan , Ross -tech is a much more comprehensive
Mike Holroyd has just had a new maxidot cluster fitted and full coding done by a stealer for £90! He paid £224 posted for the cluster from Skodateile......
