VRS - Removing the lower (honeycomb) grille?
After an hour of gaffing around chafing my fingers and swearing, I have decided to come back in, and ask you clever folk.
I very cleverly drove into a low concrete wall (it's a short, but boring story), which has broken a clip on the lower grille on my VRS, as well as making some of the other clips pop out. So the lower grill is now a bit wonky.
Because the plastic is so stiff, I'm unable to pull it back far enough to re-seat the clips that popped out.
So, I've been trying to figure out how I remove the thing, so I can put it back in properly - only I can't figure it out.
There are a load of really stiff clips, which no matter what I do with my stubby fingers doesn't seem to make any difference at all - I just can't budge the thing.
Has anyone removed it? Any tips?
I don't want to have to go to Skoda with my head hanging in shame...
Louis
Edited by louisv6
Is it the chrome lower grill? If so its a pain in the a$$, absolutely loads of clips. I lost my temper and just wrenched it out on mine when i swapped it for the black pack grille
+1 tried to remove it the correct way for 5 mins, then just ripped it off
I'm still finding chrome shards on my drive lol
No - not the chrome bit - the black plastic 'honeycomb' lower grille.
Anyone tried to get one off (without hitting a wall)?
infront of the intercooler?
You need to remove the tray underneath, then it can be unclipped. Not the easiest job on your back, best if it's on a ramp.
Why are you removing it ?
Only need to remove it to re-fit it.
Some of the clips have come out, and I can't bend it out far enough to get them back in. So I figure if I remove it completely I can take a look at what I'm dealing with...
Didn't think I'd have to get it on a ramp!!
Will have to find a charitable friend with too much time on their hands and a spare ramp...
Thanks for the tip.
That's the one.
They are just stiff clips, if you get a flat blade behind it you should be able to gently lift them out without damaging the bumper...
Edited by Ad Lav
  • 3 years later...
bump for Naths-VRS,
this is on the bottom grill, but there are other threads on the grill with the vRS badge on,
and there is a Pinned thread on Monte Carlo grills in the Fabia Technical section.
Pictures have gone though.
