Skoda Fabia Inspection light
Hello All,
I hope you could help.
I drive a 2008 (57 plate) Skoda Fabia. The garage where I bought it did a service but forgot about the inspection alert. A coupleof months later the inspection alert started coming up every time I turned on the car. I contacted the garage (that is in Southampton and I live in Manchester) and they told me that the only way to get the inspection light to come off was to use a special computer and I would have to drive down to Southampton (4 hours) to get it done otherwise I'm on my own.
is there anyway I can do it at home? I've tried to use the method below but when I hold the button and turn the ignition the only thing that comes up is how many miles/days I am overdue for a service. Any ideas? My car is just the standard Fabia 1 1.2L.
thanks,
joe.
TO RESET INSPECTION OR OIL CHANGE DUE DISPLAY.
A) SWITCH OFF IGNITION
B) PRESS AND HOLD IN TRIP BUTTON
C) SWITCH ON IGNITION
D) WAIT FOR APPROX 10 SECONDS, UNTIL '-------' APPEARS
E) SWITCH OFF IGNITION
F) RELEASE TRIP BUTTON
G) SWITCH ON IGNITION -- NO INSP /OIL DISPLAYED.
H) IF 'INSP' OR 'OIL' IS STILL DISPLAYED, REPEAT FROM A)
You need press and hold the clock reset button on the clock face and turn the iginition to ON wait until you see "------" then just let go :)
Like I said in my original post, I have tried that a few times and it doesn't seem to change. I've just taken it to another garage and they've have said that its a computer job too.
try holding reset button switch on ignition
whilst still holding reset button turn to the right and hold for a few seconds
see if that does it
It is also possible for you to reset the Service Interval Display with the reset button
? page 11, fig. 4 as follows:
• Press the reset button ? page 11, fig. 4 with the ignition switched off and
and hold it down.
• Switch the ignition on, release the reset button and and turn the reset button
to the right. All counters will be reset to 0.
It is only possible to reset the Service Interval Display, if a service message or at least
a pre-warning is shown on the display of the instrument cluster.
link to manual
https://mediaportal....wnersManual.pdf
