Shadows Entity's MK1 stage 2 + r32 setup
Got the car back yesterday.... doesn't even feel like the same car, Clive has made it into an animal. 5th Gear actually does something now, don't even have to drop down to overtake just a twitch on the throttle is all you need.
Actually slightly scared of what my car can do now, being very careful with the throttle while I get use to it.
Gear change is easier and smoother with the SMF conversion
Handling is out of this world, never driven anything that felt so connected... just none stop grip
  • Replies 162
  • Views 23.7k
  • Shadows Entity
    Shadows Entity
    Pictures that Clive sent me when it was in progress         This is what massively delayed me getting my car yesterday....       Yes that is a horse box on it's side and a landrover
  • Shadows Entity
    Shadows Entity
    Got some new wheels thanks to vRSy which imo are millions better and nearly new so not all corroded like my old ones, tyres on them are insane as they're Falken road slicks feels like you could go rou
  • Shadows Entity
    Shadows Entity
when you taking me for a spin then :devil:
Yes that is a horse box on it's side and a landrover in the air..................................
And here's some i've just taken of how the car looks now
First post updated with total modifications at the bottom
Exhaust no longer rattles :) new backbox mounts and it sits perfect
raised it a bit too as the speed bumps at work were getting a bit tedious slowing down to 1mph and braking on the crest... fitted some fk spacers too so they're flush with the wheel arch... Looks good will take pictures tomorrow
Whats the ride like on ap's?
fast use perfect... normal road use can be bumpy. Can't really compare as they're the only coilovers I've had but the ride is no worse than standard setup to me
Spacers
And here is the car raised a bit... front is probably close to standard height but the back is lower than standard so it sits level
Good job I raised it up.... After putting in all this:
it's sat just as low as before....
In Norfolk along the broads, hoping to get some nice pictures while I'm here
Looks epic hope your enjoying buddy
Not really an update but one of my tyres decided to get a slow puncture... 10 psi loss in a week.
As they're semi slicks can't really only replace one so getting two. they're getting pretty worn anyway but still had a couple of thousand in them.
Gone for Dunlop SP Sport Maxx RT as they have good reviews and will be alright for what I want and a lot better wet grip.
Going from a 40 to a 45 too for a bit more comfort
will see if they're any good this wednesday
Had another go at getting my exhaust sorted so it would stop rattling and catching and knocking.... And also make it legal
So I picked a night to get it done and it happened to be raining...
Thought I'd give it a long shot and ask my bosses boss if I could use what is called our 'Skidding shed' as that's where they used to keep WW2 guns to skid out and build up on the White cliffs of Dover... Luck would have it that so long as I didn't leave a mess or die it was fine.
So I had lights, a dry floor and flat which helps and loads of room unlike the roadside which is what I'm used too... So thought i'd take some pictures.
BTW I keep jacks in place with slightest bit of pressure to reduce effort of axle stands on underside if anyone wants to be funny, also double back up
So result, 3" downpipe with sports cat and a non rattley exhaust, does knock occasionally on big bumps but that is ok in comparison
Thanks to my boss, not that she'll ever read this...... :)
mot today, let's see how much is wrong this year
failed on emissions and front tyres and front passenger wishbone Bush too much play....
leaking exhaust between turbo and down pipe so before lambda which is making emissions worse
could be a loose bolt on wish bone and it's there a gasket on the down pipe? Will find out tomorrow
ordered two more Dunlop SP sport maxx rt and got a new gasket anyway
Refitting downpipe gasket and getting it tight on tonight and looking for loose bolt on passenger wishbone, retest on Tuesday a long with 2 new front tyres
result tightened wishbone bolts and no knocks and took the downpipe off and the gasket came apart in two bits of metal so the paper inbetween had completely disintegrated... refitted and tightened and exhaust now sounds fluid, so smooth it's almost silky :)
Dipetane helps with emissions you can buy a bottle of it for around a tenner, I always throw a half bottle in before the nct test and I've never had a problem with it passing
Put in cataclean but hopefully with the gass leak sorted it will be giving the lambda the correct values to stop over fuelling
retest fingers crossed
good luck m8
  • 4 weeks later...
Hope it goes through ok mate :)
I think its in peices...
yea its not in a good way :sweat:
Uh oh, not good
